No air pressure on start up - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: No air pressure on start up (/showthread.php?tid=1047) Pages: 1 2 |
No air pressure on start up - Dan Darst - 07-13-2005 12:32 gotter done, not napa, 17 bucks. even if thats not the fix, it is cheap enough to do. Thanks dandarst86fc35rbhuntleyil. >From: "Harold" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Re: No air pressure on start up >Date: Wed, 13 Jul 2005 13:25:33 -0000 > >Dan, > The governor you want is called a D-2 Governor. They are available >from most heavy truck stores. Should cost from $10 to $20. Napa will >most likley be the highest priced. I have an extra that I carry with >us. It is easy to change. Two 7/16 bolts, a couple of allen plugs to >put in the new one.(they come with it) and 2 hoses to undo and reattach. >Good luck >Harold >'85WLFC35 >Upham,Ca. > >--- In WanderlodgeForum@yahoogroups.com, "Dan Darst" >wrote: > > Thanks for the replys. I saw the governer last week while changing >the fuel > > line. If anyone has the part number handy for Napa, would >appreciate it. > > > > > > dandarst86fc35rbhuntleyil. > > > > >From: "Dan Weaver" > > >Reply-To: WanderlodgeForum@yahoogroups.com > > >To: WanderlodgeForum@yahoogroups.com > > >Subject: [WanderlodgeForum] Re: No air pressure on start up > > >Date: Wed, 13 Jul 2005 01:42:56 -0000 > > > > > >I second that. NAPA carries the governor, it is mounted on the air > > >compressor under the doghouse. > > > > > >Dan > > >94 BMC 37', previous 83 FC35 > > > > > >--- In WanderlodgeForum@yahoogroups.com, "dthollis1961" > > > > > > > Dan, > > > > > > > > I would replace the air pressure governor. About a $15.00 part. > > > > > > > > David Hollis 78 FC33 Springfield IL > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "dandarst" > > > > > wrote: > > > > > Started the Cat and no air pressure would build on the gauges >or > > > > > suspension (first time ever). Shut cat off and turned on > > >auxiliary > > > > air > > > > > compressor. Everything aired up as usual. Shut off auxiliary >air > > > > > compressor and restarted cat. Air pressure would build >normally. > > > > > > > > > > What is starting to fail? > > > > > > > > > > Thanks. > > > > > dandarst86fc35rbhuntleyil. > > > > > > > > |
