Synthetic vs. Dino - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Synthetic vs. Dino (/showthread.php?tid=2375) Pages: 1 2 |
Synthetic vs. Dino - Bob & Carol Howald` - 04-11-2006 02:50 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > Bob, I normally change coach oil once every year. The truck get's a little more use and I change it twice depending on use. Iam also using the amsoil in my 04 Honda pilot, I use the k & N filter's in the dodge truck and pilot. Jeff answered your concern about the drain time. It's sure nice being on the road and not to worry about changing oil...Bob 93pt40 Jackson,Wy. (soon to be back in Il.) > Hi Bob, > Your 80k miles on the 6v-92..is that without an oil change? > Just put in dino in the engine with synthetic in tranny (Amsoil). > I wonder if I decide to switch to Amsoil in engine how many miles I > have to have on it before draining the dino oil. At present, I only > have 5k miles on the rebuilt engine. > Bob Lawrence > 84 PT36 (Scratching my head) > Tacoma, Wa. > > > > I put eighty thousand miles on a 6v-92 using amsoil 15/40 and have > 50 > > thousand on my 8v-92 using amsoil. I also use the amsoil syn > > transmission fluid along with the rear dif, fluid. My Dodge diesel > > pickup truck has 100 thousand with amsoil in it from the first day. > No > > complaint's. I have the oil analysis once a year on all vehicles and > no > > problem's. I would never go back to Dino.. Still snow on the ground > > here in Jackson, Wy..Bob&Carol. 93pt-40 Bunker Hill, Il... > > > Synthetic vs. Dino - Bob Lawrence - 04-11-2006 13:50 Thanks Mike for allour posts on switching. I am printing them off and will switch at around 7-8k miles. Thanks for all your info. Bob Lawrence 84 PT36 Tacoma,Wa. > Bob, > > I have been using Amsoil in every internal combustion engine I own > since 1979. At 5,000 miles, with modern ring technolgy everything is > broken in by now and you are OK to switch, but since you just had the > oil changed, switch at 8-10,000 and get your money's worth out of the > last oil change. When you switch, make sure you get a good quality > synthetic oil filter also: Amsoil, Mobil-1 or the new Donaldson line. > The synthetics don't break down, but they will load up with dirt and > soot just like dino oil. You need excellent quality filters to > preserve your synthetic oil investment. The paper based filters are > are a waste of money and synthetic. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > Synthetic vs. Dino - Bob Lawrence - 04-12-2006 10:21 Thanks, Jeff, I think I will be switching to synthetic in the engine in 8k miles. Thanks for your input. Bob Lawrence 84 PT36 Tacoma, Wa > If your engine rebuilder gave you special break-in oil change > requirements (shorter interval), use the cheap oil to the first > change. if not, you can change at any time, breaking in an engine > with syn oil in it is fine and recommended by Mobil. >> Lots of money, and as many will argue the coach will run fine without > it. > > - Jeff Miller > in Holland, MI > |
