CrossFires Dual tire equalization system? Pros, cons? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: CrossFires Dual tire equalization system? Pros, cons? (/showthread.php?tid=2882) Pages: 1 2 |
CrossFires Dual tire equalization system? Pros, cons? - Pete Masterson - 07-03-2006 06:53 On Jul 3, 2006, at 11:23 AM, Scott Forman wrote: > Is it possible to check the pressure with a gauge or add air without > removing the Crossfire? I have never seen these in person. > Scott, See <http://www.dualdynamics.com/dualcrossfire.html> where the device is pictured and described. It has a pressure gauge built in and displays a black 'flag' for under inflation and a red 'flag' for over inflation (plus or minus 20%). It appears to have a valve stem built into the pressure gauge to inflate the tires in unison. Note that it comes in various pressure ratings, so it would require you to select a 'normal' pressure for your vehicle and buy the appropriate unit. With the plus or minus 20%, a tire set for 100# will show as "full" from 80# to 120#... of course, this range is probably required to compensate for heating (and heat-induced pressure increase) while on the road. Pete Masterson aeonix1@... '95 Bluebird Wanderlodge WBDA 4203 El Sobrante, CA CrossFires Dual tire equalization system? Pros, cons? - Wallace Craig - 07-03-2006 07:17 Yes, only remove valve cap. crossfire display will tell you whether you are high or low on pressure ----- Original Message ----- From: "Scott Forman" <sforman@...> To: Sent: Monday, July 03, 2006 1:23 PM Subject: [WanderlodgeForum] Re: CrossFires Dual tire equalization system? Pros, cons? > Is it possible to check the pressure with a gauge or add air without > removing the Crossfire? I have never seen these in person. > > Thanks > > Scott Forman > 82 FC35RB > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > >> >> Fellows, >> Tell me where you found the Crossfire Equalizers and what price to > expect. Is >> it the concensus of the group that the Crossfire are the best. >> Thanks, >> Howard Truitt >> Camilla, Ga. >> 86 PT40 >> >> >> [Non-text portions of this message have been removed] >> > > > > > > > ------------------------ Yahoo! Groups Sponsor > > > Yahoo! Groups Links > > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > > |
