HWH leveling jacks - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: HWH leveling jacks (/showthread.php?tid=2883) Pages: 1 2 |
HWH leveling jacks - Stephen H - 12-12-2006 15:58 Gardner, I just had to replace one of my Actuators on my bird. The one rear jack would go about ¾ the way down, and stop and bog the pump motor down. I called HWH, and they told me it was the actuator assy. He sent a remanufactured actuator assembly- I replaced it, did the trick! Works like new! Very smooth, and goes out very easy now. Give them a call. 1-800-321-3494 Cost about $88.00 including shipping for my model (100 Series). Stephen H 81 FC-33SB Plant City, FL 70âs runnin the A/C! (no longer emulating Flamingoâs!!) _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Gardner Yeaw Sent: Tuesday, December 12, 2006 10:23 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] HWH leveling jacks I plan to call HWH, but maybe I can get the answer here. My jacks have worked perfectly and this weekend I used them twice. The third time the right rear jack would not drop down. It would move a little, but stop. I noticed that the jack was extended about 2 inches. I tried several times but no good. When i packed up and retracted the rest of the jacks I noticed the 'bad' jack was retracted. I suspect it will work now, but don't want to take the chance that it would deploy and not retract. How does the jack actually work. I understand that there is a system for lowering the jack assembly and another for extending the shaft to raise the coach. Is this how it works? Gardner 78FC33 (emulating a flamingo at this moment) [Non-text portions of this message have been removed] HWH leveling jacks - Ralph L. Fullenwider - 12-13-2006 02:37 Gardner: Sounds like you need to lub the pivot points on the sides of the jack. The small cylinder on the front of the jack is the kick down cylinder. All the fluid passes through the kick down first then through the kick down to the main extension cylinder. If you lub the pivot points, the kick down cylinder will not have to try to over come the spring tension and dry pivot points as well. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma At 03:22 AM 12/13/2006 +0000, you wrote: > I plan to call HWH, but maybe I can get the answer here. >My jacks have worked perfectly and this weekend I used them twice. The >third time the right rear jack would not drop down. It would move a >little, but stop. I noticed that the jack was extended about 2 inches. >I tried several times but no good. When i packed up and retracted the >rest of the jacks I noticed the 'bad' jack was retracted. I suspect it >will work now, but don't want to take the chance that it would deploy >and not retract. > > How does the jack actually work. I understand that there is a >system for lowering the jack assembly and another for extending the >shaft to raise the coach. Is this how it works? > >Gardner >78FC33 (emulating a flamingo at this moment) > > HWH leveling jacks - Gardner Yeaw - 12-13-2006 12:40 Ralph, Thanks for the advise. As soon as it stops raining I will check it out. Once I put it up for the winter I need to send the valve assembly to HWH to be rebuilt. One of the jacks doesn't hold, no leak. At the rate I am replacing and fixing things up I should start to call it a 2006 with some 1978 parts! Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Gardner: > > Sounds like you need to lub the pivot points on the sides of the jack. The > small cylinder on the front of the jack is the kick down cylinder. All the > fluid passes through the kick down first then through the kick down to the > main extension cylinder. If you lub the pivot points, the kick down > cylinder will not have to try to over come the spring tension and dry pivot > points as well. > > Safe travels, > > Ralph and Charolette Fullenwider > Ralph's RV Solutions, Duncan, Oklahoma > > At 03:22 AM 12/13/2006 +0000, you wrote: > > I plan to call HWH, but maybe I can get the answer here. > >My jacks have worked perfectly and this weekend I used them twice. The > >third time the right rear jack would not drop down. It would move a > >little, but stop. I noticed that the jack was extended about 2 inches. > >I tried several times but no good. When i packed up and retracted the > >rest of the jacks I noticed the 'bad' jack was retracted. I suspect it > >will work now, but don't want to take the chance that it would deploy > >and not retract. > > > > How does the jack actually work. I understand that there is a > >system for lowering the jack assembly and another for extending the > >shaft to raise the coach. Is this how it works? > > > >Gardner > >78FC33 (emulating a flamingo at this moment) > > > > > HWH leveling jacks - Peggy & Ed McStay - 07-05-2007 01:54 I just removed the rear jacks because of a leak on the right rear. i removed both rear jacks because they both need to be rebuilt. got them on the work bench and into the cleaning tank and gave them a good cleaning.after removing and wiping them down i see no way to take them apart. what am i overlooking here. has anyone taken these jacks apart and rebuilt them. looks to me like the top end is welded and at the ram end all i can see is the wiper. looks like a sealed unit.when HWH has to rebuild them i guess they have to cut them open. any help and info on this topic? thanks ed and peggy mcstay 83FC RB 35FT ""lonesome dove"" lake charles, louisiana HWH leveling jacks - mbulriss - 07-05-2007 03:03 Ed, Seems like I remember a *long* ago post from Les Gray in west Texas that he had cut his open to repair them and then discovered that if he had cleaned out all the solid packed debris that had accumulated over the years in the foot of the jack pad that he had discovered a bolt head or nut on a threaded rod that allowed the whole thing to be unbolted and slid apart for rebuild. You might want to check the foot pad carefully. FWIW, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Peggy & Ed McStay" > > I just removed the rear jacks because of a leak on the right rear. i > removed both rear jacks because they both need to be rebuilt. got them > on the work bench and into the cleaning tank and gave them a good > cleaning.after removing and wiping them down i see no way to take them > apart. what am i overlooking here. has anyone taken these jacks apart > and rebuilt them. looks to me like the top end is welded and at the ram > end all i can see is the wiper. looks like a sealed unit.when HWH has > to rebuild them i guess they have to cut them open. any help and info > on this topic? thanks > > ed and peggy mcstay > 83FC RB 35FT > ""lonesome dove"" > lake charles, louisiana > HWH leveling jacks - Richard Hayden - 07-05-2007 03:33 Ed, If they are like what I have, they will have to be shipped to HWH in Moscow, Iowa for repair. That is actually a good thing as they will guarantee then as if they were new. Mine were straight down model but I think the construction is the same. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: mbulriss To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 05, 2007 8:03 AM Subject: [WanderlodgeForum] Re: HWH Leveling jacks Ed, Seems like I remember a *long* ago post from Les Gray in west Texas that he had cut his open to repair them and then discovered that if he had cleaned out all the solid packed debris that had accumulated over the years in the foot of the jack pad that he had discovered a bolt head or nut on a threaded rod that allowed the whole thing to be unbolted and slid apart for rebuild. You might want to check the foot pad carefully. FWIW, Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com "Peggy & Ed McStay" > > I just removed the rear jacks because of a leak on the right rear. i > removed both rear jacks because they both need to be rebuilt. got them > on the work bench and into the cleaning tank and gave them a good > cleaning.after removing and wiping them down i see no way to take them > apart. what am i overlooking here. has anyone taken these jacks apart > and rebuilt them. looks to me like the top end is welded and at the ram > end all i can see is the wiper. looks like a sealed unit.when HWH has > to rebuild them i guess they have to cut them open. any help and info > on this topic? thanks > > ed and peggy mcstay > 83FC RB 35FT > ""lonesome dove"" > lake charles, louisiana > [Non-text portions of this message have been removed] |
