What is this thing? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: What is this thing? (/showthread.php?tid=3643) Pages: 1 2 |
What is this thing? - Ryan Wright - 03-05-2008 04:25 Huge thank you to everyone for your responses on this. I am going to tighten this down this weekend and see if that solves it; if not, at least now I know how to find a new one to replace it. Appreciate your help!! -Ryan '86 PT-40 8V92 On Mon, Mar 3, 2008 at 10:00 AM, msksann <msksan@...> wrote: > > Just to correct my previous post, I have found 2 Pressure Protection > Valves, (I do not have the bulk oil fill), and they are used in the > Ridewell air spring suspension system, not the air brake system. I am > unsure if they regulate the air pressure, or protect it from air loss, > or perhaps either or both, depending on how the ports are connected(?) > The specs say that the valve opens at 65psi, and closes at 45psi. > I started another thread under 'Pressure Protection Valves', to share > my expirence with the forum, and perhaps clear this up. > I do believe the diaphragm material is hardening and failing... What is this thing? - Ryan Wright - 03-13-2008 07:53 Update on this: Big thanks to Michael for the part number (Haldex KN31000). NAPA took one look at my existing valve and said they'd never seen such a thing and don't carry it. After giving them the Haldex part number they changed their minds and my new one will be here tomorrow morning. :-) -Ryan '86 PT-40 8V92 On Mon, Mar 3, 2008 at 7:26 AM, msksann <msksan@...> wrote: > > Ryan: > It is a Pressure Protection Valve. There should be some part numbers > located on the 'cap', which, in this picture, is located underneath. > It is probably the same ones used between the air tank and the spring > brakes. Those are Midland part #N15759C (N157590) BB part #0522508. > This has been replaced by the Haldex KN31000, available at napa for > aprox $38. Or online for less: > http://tinyurl.com/24ngm4 |
