Wire Tracers - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Wire Tracers (/showthread.php?tid=3922) Pages: 1 2 |
Wire Tracers - David Brady - 12-03-2006 04:08 Tom, I see that the OTC 20 ton stands have a height range of from 15.25 to 24 inches. On the LXi, if I use the HWH jacks to pick the back of the bus off the ground, the bottom of the frame rails at the tag axle are approximately 28 inches from the ground. Have you seen any stands that support 20 ton but have a height range suitable for me. I don't feel comfortable putting blocking between the stand and my reinforced, level, concrete floor, unless there's a suitable blocking material that this list has experience with. Thanks, David Brady '02 LXi, Smokey Va, soon to be NC Tom Warner wrote: > GULP!!!!!!! What I meant to say is I have a 20 1/2 ton OTC axel > hydraulic/air jack. Easy to use and very handy. I also have four 20 > ton heavy duty OTC jack stands. I work on the coach every day and am > extremely safety conscious. One rule When I go under the bus I must > come out > > Tom warner > vernon center,ny > 1985 PT 40 > > > > > > > Wire Tracers - Mike Hohnstein - 12-03-2006 05:13 Hmm, I haven't been hit in the head using any imported hydraulic lifting devices. My 60 year old art deco styled floor jack still gets the bus in the air. (Shop air over oil powered) I don't get too close to it while it is doing it's job. I know a guy who is missing vision in an eye due to a hydraulic press accident. I don't do business with catalog sellers anymore. Too many disappointments. MH ----- Original Message ----- From: Gregory OConnor To: WanderlodgeForum@yahoogroups.com Sent: Sunday, December 03, 2006 9:48 AM Subject: [WanderlodgeForum] Re: Wire Tracers Silly, what part of your M Benz was American Made? You can call me Cheep but if $35.00 gets you 18% closer its worth it. I wonder if that tool truck sells any Dale Carnegie titles. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...> wrote: > > That is very interesting, I used to work at American Can in Milwaukee, the founder of Gardner Bender, Mr. Gardner worked there too, before he moved on to bigger things. > I'm not as wise as you POB, I buy my tools from the tool truck that supplies PROFESSIONAL MECHANICS, you know, Snapon, Mac or Matco. They laid me away a couple hundred dollars for such a device, and call me silly but I like to use product made in this COUNTRY. As bird owner I am used to tracing circuits, and if I get over my head I call Jeff Miller. Others stressing over the loss of "Benny" might check out Jeff at Dupree products. He knows. > MH > > ----- Original Message ----- > From: Tom Warner > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, December 02, 2006 12:21 PM > Subject: [WanderlodgeForum] Wire Tracers > > > One of the best wire tracers that I have used is the gardner bender > wire tracer that you can buy at both lowes, home depot and lots of > other places. They have two models a wire tracker and a LAN tracker. > I have the LAN tracker since I can troubleshoot computer and phone > lines with it also. Gardner Bender is one of the premier producers of > tools and test equipment for electricians, telephone repairmen and > communications personnel. Sure you can buy ones that cost hundreds of > dollars but for automotive, homes and telephone wire tracing this > tool works fine, is portable, is easy to use and is reasonably > priced. What kind of tool do you use Mike that costs hundreds of > dollars and is better to trace wires? > > http://www.gardnerbender.com/ > http://www.discount-home- improvement.com/Electrical/Gardner_Bender_LAN_Tracker.html > > Print out this sheet and you will find it for a little less at either > Lowes or Home depot > > tom warner > vernon center,ny > 1985 PT 40 > > At 09:18 AM 12/2/2006, you wrote: > >Only if you need one that works. > >MH > > ----- Original Message ----- > > From: erniecarpet@... > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, December 02, 2006 7:44 AM > > Subject: Re: [WanderlodgeForum] Re: Posing a question to gauge > > interest....lurkers hel... > > > > > > I thought those wire toners were in the couple hundred dollar range? > > > > Ernie Ekberg > > 83PT40 > > Livingston, Montana > > --ready to roll > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] Wire Tracers - erniecarpet@... - 12-03-2006 06:27 In a message dated 12/3/2006 8:45:43 A.M. Mountain Standard Time, warbucks@... writes: 20 1/2 ton OTC It's amazing how sometimes my fingers don't type what my brain is thinking. Ernie Ekberg 83PT40 Limon, Co [Non-text portions of this message have been removed] Wire Tracers - Tom Warner - 12-03-2006 08:03 For that matter what part of any electronics device is made in the USA, which hydraulic devices? As for tools some of the best are now made in Japan and Taiwan and some are as expensive as Snapon which in my opinion is way over priced for the occaional user. Some of the tools I have had for over 45 years and they are still in perfect shape and they are not snapon. I have two sets of 12X torque multipliers which are made in Taiwan and believe me they are not cheap and are very well made. The OTC heavy duty 22 1/2 ton air/hydraulic floor jack is made in Taiwan and it is of excellent quality. tom warner vernon center,ny 1985 PT 40 At 12:13 PM 12/3/2006, you wrote: >Hmm, I haven't been hit in the head using any imported hydraulic >lifting devices. My 60 year old art deco styled floor jack still >gets the bus in the air. (Shop air over oil powered) I don't get too >close to it while it is doing it's job. I know a guy who is missing >vision in an eye due to a hydraulic press accident. I don't do >business with catalog sellers anymore. Too many disappointments. >MH > ----- Original Message ----- > From: Gregory OConnor > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, December 03, 2006 9:48 AM > Subject: [WanderlodgeForum] Re: Wire Tracers > > > Silly, what part of your M Benz was American Made? You can call me > Cheep but if $35.00 gets you 18% closer its worth it. I wonder if > that tool truck sells any Dale Carnegie titles. > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" > <MHOHNSTEIN@...> wrote: > > > > That is very interesting, I used to work at American Can in > Milwaukee, the founder of Gardner Bender, Mr. Gardner worked there > too, before he moved on to bigger things. > > I'm not as wise as you POB, I buy my tools from the tool truck that > supplies PROFESSIONAL MECHANICS, you know, Snapon, Mac or Matco. > They laid me away a couple hundred dollars for such a device, and > call me silly but I like to use product made in this COUNTRY. As > bird owner I am used to tracing circuits, and if I get over my head I > call Jeff Miller. Others stressing over the loss of "Benny" might > check out Jeff at Dupree products. He knows. > > MH > > > > ----- Original Message ----- > > From: Tom Warner > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, December 02, 2006 12:21 PM > > Subject: [WanderlodgeForum] Wire Tracers > > > > > > One of the best wire tracers that I have used is the gardner > bender > > wire tracer that you can buy at both lowes, home depot and lots > of > > other places. They have two models a wire tracker and a LAN > tracker. > > I have the LAN tracker since I can troubleshoot computer and > phone > > lines with it also. Gardner Bender is one of the premier > producers of > > tools and test equipment for electricians, telephone repairmen > and > > communications personnel. Sure you can buy ones that cost > hundreds of > > dollars but for automotive, homes and telephone wire tracing this > > tool works fine, is portable, is easy to use and is reasonably > > priced. What kind of tool do you use Mike that costs hundreds of > > dollars and is better to trace wires? > > > > http://www.gardnerbender.com/ > > http://www.discount-home- > improvement.com/Electrical/Gardner_Bender_LAN_Tracker.html > > > > Print out this sheet and you will find it for a little less at > either > > Lowes or Home depot > > > > tom warner > > vernon center,ny > > 1985 PT 40 > > > > At 09:18 AM 12/2/2006, you wrote: > > >Only if you need one that works. > > >MH > > > ----- Original Message ----- > > > From: erniecarpet@... > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, December 02, 2006 7:44 AM > > > Subject: Re: [WanderlodgeForum] Re: Posing a question to gauge > > > interest....lurkers hel... > > > > > > > > > I thought those wire toners were in the couple hundred dollar > range? > > > > > > Ernie Ekberg > > > 83PT40 > > > Livingston, Montana > > > --ready to roll > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > >[Non-text portions of this message have been removed] > > > > >Yahoo! Groups Links > > > |
