Satellite Receiver Hookup - Printable Version
+--- Thread: Satellite Receiver Hookup (/showthread.php?tid=4257)
Pages: 1 2
Satellite Receiver Hookup - Curt Sprenger - 02-07-2007 05:41
I wired from the satellite to the Direct TV receiver..from the DTV
receiver to a new splitter with gain control...from the splitter to the
3 TVs (rear, forward, bay). Works great. The old BB stuff gave a fuzzy
picture.
Curt Sprenger
Anaheim Hills, Calif.
Richard Hayden wrote:
> That wouldn't be the first time Jim. Although, as I just replied to
> Tom, I did try going through the existing setup and had trouble. It's
> been awhile but I seem to recall a problem with the splitters behind
> the switch/amp box. Maybe I have a problem there and it just isn't
> showing up the way I using it now with only 1 tv.
> Dick Hayden - '87 PT 38 - Lake Stevens, WA
> From: jqrjr>
com
> Sent: Wednesday, February 07, 2007 8:42 AM
> Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup
> BY the way, I also think that Dick is wrong.
> Jim Riordan
> --- In WanderlodgeForum@yahoogroups.com
com
> >, "Leroy Eckert"
> > Well, I cannot tell you exactly how my coach is wired unless I go
> out and track down the wires. It took me and a video guy a while to
> get it right. Here is how mine works.
> > I have 3 TV's.
> > I have:
> > In motion Satellite Receiver box(technical name escapes me at the
> moment) L-3 TracVision
> > A-B switch in the coach.
> > Land line cable port (factory)
> > Space Ship Air Antenna installed at factory.
> > When my satellite receiver is on I receive satellite TV.
> > When I plug into cable TV, park supplied, and turn off the
> satellite receiver I receive cable TV.
> > If I want to use the Air antenna, seldom, I switch from A to B and
> I receive nearby stations over the air. Satellite TV receiver off.
> > In the satellite and cable configuration the switch is always in
> position A.
> > Reception is very clear in all cases.
> > I hope this helps you.
> > Leroy Eckert
> > 1990 WB-40 "Smoke N Mirrors"
> > Niceville, FL
> > From: what1not
s.com>
> > Sent: Tuesday, February 06, 2007 7:52 PM
> > Subject: [WanderlodgeForum] Satellite Receiver Hookup
> > Hi Everyone,
> > I have a '87 PT40 and I am looking at adding a portable satellite
> > dish to my setup.
> > A couple of questions:
> > 1. Can you bring the satellite signal through the cable input
> switch
> > to the satellite receiver?
> > 2. I understand that there is power going to the dish from the
> > satellite receiver and that there is an issue with the amplifier
> for
> > the regular antenna which somehow do not allow the satellite and
> > reciever to properly communicate. If I can't go through the A C
> > switch in the coach can I split the cable input to the switch and
> > then go directly to the satellite receiver when not using a cable
> > setup?
> > Any other info is greatly appreciated!
> > Jo and Bill Neil
> > '87 PT40
Satellite Receiver Hookup - birdboat45 - 02-07-2007 10:32
Tom a simple diagram would be great. I have had trouble with the BB
switch to work with my sat. Set up.
Thanks
Jack Jones
East Tn 87
PT 40
WanderlodgeForum@yahoogroups.com, Tom
Warner wrote:
> In my 1985 PT 40 setup (was the same for my 1982 FC35) there is a
> switch with two positions in the small upper bin that houses the
> switch and amplifiers and two AC receptacles. One input to the
switch
> is from the outside cable TV input that is in the drivers side
rear
> compartment where the AC inputs are. The other input is from the
> overhead TV antenna. I installed a new satellite antenna and ran
> two output cables and control cable from it thru a new cable
entrance
> I installed near the goat rail into the inside overhead bin. From
> there the control cable goes directly to control switch for the
> direct satellite control box, and one of the satellite antenna
> outputs goes to the receiver, the other is left coiled up since I
> dont use it. I ran a new coax from the output of the satellite
> receiver to the 2 position switch provided by BB, disconnected the
> input from the rear cable TV line and connected the output from
> satellite receiver in its place. Now I can chose either the
overhead
> TV antenna or the satellite receiver output. I also added a
modulator
> and DVD player and routed its output to the satellite receiver
> external antenna input. Now with the satellite receiver on I can
use
> it, or when I switch it off can chose the DVD player. The
satellite
> receiver has an internal switch that switches the output from the
> satellite receiver to the DVD player when it is switched off.
> Tom Warner
> vernon center,ny
> 1985 PT 40
to
> >trouble. It's been awhile but I seem to recall a problem with
> >splitters behind the switch/amp box. Maybe I have a problem
there
> >and it just isn't showing up the way I using it now with only 1
tv.
> > From: jqrjr
> > To:
WanderlodgeForum@yahoogroups.com com>
> > Jim Riordan
> > --- In
WanderlodgeForum@yahoogroups.com com>,
> > "Leroy Eckert"
I go
while to
> > > I have 3 TV's.
> > > I have:
at the
B and
off.
always in
> > position A.
> > > Leroy Eckert
> > > Niceville, FL
> > > From: what1not
> > > To:
> > WanderlodgeForum@yahoogroups.com 40yahoogroups.com>
> > > Hi Everyone,
satellite
> > > dish to my setup.
> > switch
amplifier
> > for
A C
switch and
cable
> > > setup?
> > > Jo and Bill Neil
> > > '87 PT40
> >Yahoo! Groups Links
Satellite Receiver Hookup - Tom Warner - 02-07-2007 10:48
Jack the switch itself is very simple with two inputs , one from the
rear cable tv line coming from the same small compartment that the
shore line power receptacles are housed, the other from your rooftop
TV antenna. The output of the switch goes to the amplifiers etc and
then to each wall outlet for your tv, one near the passenger side
wall in front, one to the front backup/tv monitor and the other to
the rear bedroom.
I dont use the one from the rear cable tv input so removed the
connector from the switch and connected the new cable running from
the satellite receiver to it.
tom
>Thanks
>Jack Jones
>East Tn 87
>PT 40
>switch
>rear
>the
>entrance
>the
>overhead
>modulator
>use
>satellite
> > Tom Warner
> > vernon center,ny
> > 1985 PT 40
>to
>the
>there
>tv.
> > > From: jqrjr
> > > To:
>WanderlodgeForum@yahoogroups.com<mailto:W\
>com>
> > > Jim Riordan
> > > --- In
>com>,
> > > "Leroy Eckert"
>I go
>while to
> > > > I have 3 TV's.
> > > > I have:
>at the
>B and
>off.
>always in
> > > position A.
> > > > Leroy Eckert
> > > > Niceville, FL
> > > > From: what1not
> > > > To:
> > > WanderlodgeForum@yahoogroups.com >40yahoogroups.com>
> > > > Hi Everyone,
>satellite
> > > > dish to my setup.
> > > switch
>the
>amplifier
> > > for
>and
>A C
>switch and
>cable
> > > > setup?
> > > > Jo and Bill Neil
> > > > '87 PT40
> > >Yahoo! Groups Links
>Yahoo! Groups Links
Satellite Receiver Hookup - jqrjr - 02-08-2007 05:10
Tom,
Go to Radio shack get a switch box that can handle multiple
inputs/outputs.
Inputs to switch box from each source (Satellite,Cable,over air dish)
would be as if they were going to tv. Instead they will go out by
coax to switch box. Outputs will go to each set or vcr from the box,
you can use (in most cases) the old coax wiring. The switch box
allows you to switch on each set between feeds. Mine has several
buttons for each appliance (tv or vcr) to choose between the sources
(satellite, cable, over the air dish). This is very useful if
signifigant other want to watch Wheel of Fortune and you want to
watch the Playboy channel.
rooftop
> the rear bedroom.
> tom
> >Thanks
> >Jack Jones
> >East Tn 87
> >PT 40
a
> >switch
> >rear
ran
> >the
> >entrance
From
I
> >the
> >overhead
> >modulator
> >use
> >satellite
> > > Tom Warner
> > > vernon center,ny
> > > 1985 PT 40
replied
> >to
> >the
> >there
> >tv.
> > > > From: jqrjr
> > > > To:
>WanderlodgeForum@yahoogroups.com< .>mailto:WanderlodgeForum@yahoogroups.
> >com>
> > > > Jim Riordan
> > > > --- In
> >com>,
> > > > "Leroy Eckert"
unless
> >I go
> >while to
> > > > > I have 3 TV's.
> > > > > I have:
> >at the
to
> >B and
receiver
> >off.
> >always in
> > > > position A.
> > > > > Leroy Eckert
> > > > > Niceville, FL
> > > > > From: what1not
> > > > > To:
> > > > WanderlodgeForum@yahoogroups.com > >40yahoogroups.com>
> > > > > Hi Everyone,
> >satellite
> > > > > dish to my setup.
input
> > > > switch
> >the
> >amplifier
> > > > for
satellite
> >and
> >A C
> >switch and
a
> >cable
> > > > > setup?
> > > > > Jo and Bill Neil
> > > > > '87 PT40
> > > >Yahoo! Groups Links
> >Yahoo! Groups Links
Satellite Receiver Hookup - Gregory OConnor - 02-08-2007 05:32
I removed the switch box and treat the sat as if it is the prime
input. The one TV is treated asif it is the only TV and the other
sets are hard wired monitors (every set is tuned to the same
broadcast). Direct TV now has a air anteni input on their box. The
box has input for other source of input. And you can chose for the
source via the remote clicker. They also have a new box that does not
require line of site and the box can be hidden. I tried to setup
my 'table-top Campword Porta dish'in a RV site that had a tree
blocking my automatic sat dome but the experience was not a happy
one. I now use a chainsaw for those situations
GregoryO'Connor
94ptRomolandCa
" move it or lose it"
MayorRisso'75, Greg'07
"Dont touch that Dial"
NBC'85, TimV'07
--- In WanderlodgeForum@yahoogroups.com, "jqrjr" wrote:
> Tom,
> inputs/outputs.
dish)
box,
sources
> the
> rooftop
to
> > the rear bedroom.
from
> > tom
BB
> > >Thanks
> > >Jack Jones
> > >East Tn 87
> > >PT 40
is
> a
> > >switch
> > >rear
> ran
> > >the
> > >entrance
> From
since
> I
satellite
disconnected
> the
from
> > >the
> > >overhead
> > >modulator
can
> > >use
> > >satellite
> the
> > > > Tom Warner
> > > > vernon center,ny
> > > > 1985 PT 40
> replied
> > >to
with
> > >the
> > >there
only 1
> > >tv.
> > > > > From: jqrjr
> > > > > To:
>WanderlodgeForum@yahoogroups.com< > .>mailto:WanderlodgeForum@yahoogroups.
> > >com>
> > > > > Jim Riordan
> > > > > --- In
> > >com>,
> > > > > "Leroy Eckert"
> unless
> > >I go
> > >while to
> > > > > > I have 3 TV's.
> > > > > > I have:
me
> > >at the
A
> to
> > >B and
> receiver
> > >off.
> > >always in
> > > > > position A.
> > > > > > Leroy Eckert
> > > > > > Niceville, FL
> > > > > > From: what1not
> > > > > > To:
> > > > > WanderlodgeForum@yahoogroups.com > > >40yahoogroups.com>
> > > > > > Hi Everyone,
> > >satellite
> > > > > > dish to my setup.
> input
> > > > > switch
from
> > >the
> > >amplifier
> > > > > for
> satellite
> > >and
> the
> > >A C
> > >switch and
using
> a
> > >cable
> > > > > > setup?
> > > > > > Jo and Bill Neil
> > > > > > '87 PT40
> > > > >Yahoo! Groups Links
> > >Yahoo! Groups Links
