 Frozen pipes - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Frozen pipes (/showthread.php?tid=4356) Pages:  1 2   |
Frozen pipes - David Heibult - 02-19-2007 03:29 Ernest; to repair the pipes how much work is it to remove the nite stand and get to the pipes,I belive mine are frozen this year, Dave 91 WLWB 40 >From: Terry Neal >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Frozen pipes >Date: Sun, 18 Feb 2007 10:53:33 -0700 > >Same place mine froze too Ernie. Heat tape & PEX should fix it. I'm >going to add the circulating pump to my system too. If it's moving, it >won't freeze. > >Terry Neal >Bozeman, MT >82PT40 >74FC34 > > > >Ernest Ekberg wrote: > > > I have found the weakest link to the frozen pipes saga. The water pipe > > run through the nightstand on the street side have been repaired many > > times due to the fact that there is no warm air circulating there. > > So, this is the area that needs most of the attention. I will repair > > all these runs with pex and add some heat tape. > > Ernie-83PT40 > > Livingston, Mt > > > > > Frozen pipes - ernieekberg@...> - 02-19-2007 08:32 Dave, remove your drawer and look inside. Mine has 2 screws that hold it down and a backer board on the rear to keep it in place. Easy R/R Ernie Ekberg 83PT40 Livingston,Montana ----- Original Message ----- From: David Heibult To: WanderlodgeForum@yahoogroups.com Sent: Monday, February 19, 2007 8:29 AM Subject: Re: [WanderlodgeForum] Frozen pipes Ernest; to repair the pipes how much work is it to remove the nite stand and get to the pipes,I belive mine are frozen this year, Dave 91 WLWB 40 >From: Terry Neal >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: Re: [WanderlodgeForum] Frozen pipes >Date: Sun, 18 Feb 2007 10:53:33 -0700 > >Same place mine froze too Ernie. Heat tape & PEX should fix it. I'm >going to add the circulating pump to my system too. If it's moving, it >won't freeze. > >Terry Neal >Bozeman, MT >82PT40 >74FC34 > > > >Ernest Ekberg wrote: > > > I have found the weakest link to the frozen pipes saga. The water pipe > > run through the nightstand on the street side have been repaired many > > times due to the fact that there is no warm air circulating there. > > So, this is the area that needs most of the attention. I will repair > > all these runs with pex and add some heat tape. > > Ernie-83PT40 > > Livingston, Mt > > > > > [Non-text portions of this message have been removed]  |
