It's official, 1984 FC35SB, now what? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: It's official, 1984 FC35SB, now what? (/showthread.php?tid=4371) Pages: 1 2 |
It's official, 1984 FC35SB, now what? - mbulriss - 02-20-2007 09:45 --- In WanderlodgeForum@yahoogroups.com, "strehlekeith" > Any advice on ensuring I have power to the whole coach? There is no > power to the microwave for instance.... Assuming you are plugged in to good shore power or have the genset on, if you have no power to electrical items like the microwave, I would check the easy place first - the breaker box - to make sure all the breakers are on.... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "strehlekeith" > > Thanks Mike, there is a detector under the fridge but doesn't seem to > have power? The book mentioned something about a detedtor in the > dinette are but I have not looked yet. However, there is a green > light on the control panel for the fridge. I'll look later... > > Any advice on ensuring I have power to the whole coach? There is no > power to the microwave for instance.... > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> > wrote: > > > > Yes Keith - in addition to all the shut off valves, there is a gas > > detector that has to be turned on and have a green light, or gas > does > > not flow. On a PT the gas detector panel is under the dinette > usually. > > Not sure where it is on an FC. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "strehlekeith" > > > > > > > > Thanks Harold, I live in the North County area of San Diego. I > saw > > > all the shut off valves for the different items in the fridge > > > compartment but was not aware of the one for the stove. I'll > check > > > it out but I think the propane is shut down due to a solenoid or > lack > > > of power to the gas detector? I was planning ontaking it to an > rv > > > place here but don't want to spend a fortune paying them to chase > > > down the problem. I'm open to all suggestions.... > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Harold Prescott" > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "strehlekeith" > > > > > > > > > > > > > > Well I went and did it. I went to San Jose on Sunday and > bought > > > an 84 > > > > > FC35. The drive line is good and the generator runs great. > > > Beyond > > > > > that everything is there, in very good shape, but some things > > > don't > > > > > work. My first order of business is to get the propane > flowing. > > > The > > > > > tank is full but doesn't flow to the stove, fridge etc. > Where do > > > I > > > > > start? Also, is the water heater gas or electric? I can't > find > > > a > > > > > place to light it so I'm assuming it's electric? > > > > > > > > > > Okay, that's the first of a million questions... > > > > > > > > > > Besides this one... Are there any Bird owners in the San > Diego > > > area > > > > > willing to go through some of this stuff with me? > > > > > > > > > > I am very grateful for any help I can get, thanks, > > > > > > > > > > Keith > > > > > 1984 FC35SB > > > > > San Diego > > > > > > > > > Keith, > > > > About the propane, > > > > There is a shut off for each furnace, the refer, and the range. > > > > The shut off for the range is under the burners. The furnace > and > > > > refer valves are located behind - under the refer, it is > accesed > > > from > > > > the outside via the little door above the left drive tire. > > > > Of course there is the main shut off at the propane tank. > > > > Also if the DC is off, nothing will work. > > > > > > > > The water heater should be AC. > > > > Inside the left rear closet is the main AC circuit breaker > pannel. > > > > A "red" light switch should low be on the left side bed. > > > > This swithch is for the water heater on twin bed models. > > > > > > > > What area of San Diego? > > > > > > > > > > > > good luck, > > > > Harold > > > > '85 FC35 > > > > Northern California > > > > > > > > > > It's official, 1984 FC35SB, now what? - Keith Strehle - 02-20-2007 11:34 Thanks, I think the first thing is to get some clear weather, then get it plugged into shore power. I did rotate the switch but I think I still only had power to leg one. I'll check again. Are there any of the old household type screw in fuses on these buses? I know I'll get this all sorted out sooner or later... --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Make sure your large shore power/generator rotary switch is switched to the > correct position (Off, 30a, 50a, Gen). My switch is accessible via a lift-up > door (about 4"x6") on the floor, just to the right (if sitting in the seat) > of the front passenger seat. Not sure of the location on a FC. Check your > overhead AC meters which will indicate AC voltage...make sure all of your 110v > circuit breakers are on...one of them is for the AC meters, so make sure, in > particular, that it isn't tripped. > > It will get better once you learn all the little tricks...believe me...we > were all there once, too. > > Kevin McKeown > Yorba Linda, CA > 1986 38' PT > ************************************** Check out free AOL at > http://free.aol.com/thenewaol/index.adp. Most comprehensive set of free > safety and security tools, millions of free high-quality videos from across the > web, free AOL Mail and much more. > > > [Non-text portions of this message have been removed] > It's official, 1984 FC35SB, now what? - Curt Sprenger - 02-20-2007 11:45 Are there any of the old household type screw in fuses on these buses? Keith, None in your 'Bird. You may have a supply of them in a box for future use. Both of our 'Birds came with a few as spares, for the older campgrounds is my guess. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. It's official, 1984 FC35SB, now what? - Keith Strehle - 02-20-2007 11:50 So that explains why they were in the drawer! And I'm getting lot's of good feedback on the fridge deal. Thanks --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Are there any of the old household type screw in fuses on these buses? > > Keith, > None in your 'Bird. You may have a supply of them in a box for future > use. Both of our 'Birds came with a few as spares, for the older > campgrounds is my guess. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > It's official, 1984 FC35SB, now what? - Howard O. Truitt - 02-21-2007 04:40 Keith, Congratulations on you recent purchase. I remember trying to get my frig. and stove to light the first time. Check to be sure the main valve on the tank is open all the way. I turned the stove on and could hear the pilot popping. It took what seemed like a long time for the gas to reach the stove the same was true with the frig. Works perfect now. Good luck. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: "strehlekeith" To: Sent: Tuesday, February 20, 2007 11:50 AM Subject: [WanderlodgeForum] It's official, 1984 FC35SB, now what? > --rtfY8qZgt2yX5-NE6hTkZ4I278b62dgj1Z9eWfX > Mime-Version: 1.0 > Content-Transfer-Encoding: quoted-printable > Content-Type: text/plain; charset=ISO-8859-1 > > Well I went and did it. I went to San Jose on Sunday and bought an 84=20 > FC35. The drive line is good and the generator runs great. Beyond=20 > that everything is there, in very good shape, but some things don't=20 > work. My first order of business is to get the propane flowing. The=20 > tank is full but doesn't flow to the stove, fridge etc. Where do I=20 > start? Also, is the water heater gas or electric? I can't find a=20 > place to light it so I'm assuming it's electric?=20=20 > > Okay, that's the first of a million questions... > > Besides this one... Are there any Bird owners in the San Diego area=20 > willing to go through some of this stuff with me?=20=20 > > I am very grateful for any help I can get, thanks,=20=20 > > Keith > 1984 FC35SB > San Diego > > > --rtfY8qZgt2yX5-NE6hTkZ4I278b62dgj1Z9eWfX > Content-Type: text/html; charset=ISO-8859-1 > Content-Transfer-Encoding: 7bit > > > > "http://www.w3.org/TR/html4/strict.dtd"> > > > > > <!-- Network content --> > > > > > <!--~-|**|PrettyHtmlStartT|**|-~--> >
> > <!--~-|**|PrettyHtmlEndT|**|-~--> > >
>Well I went and did it. I went to San Jose on Sunday and > <!--~-|**|PrettyHtmlStart|**|-~--> > > <!--~-|**|PrettyHtmlEnd|**|-~--> > > <!--~-|**|PrettyHtmlStart|**|-~--> > > <style type="text/css"> > <!-- > #ygrp-mlmsg {font-size:13px; font-family: > arial,helvetica,clean,sans-serif;*font-size:small;*font:x-small;} > #ygrp-mlmsg table {font-size:inherit;font:100%;} > #ygrp-mlmsg select, input, textarea {font:99% > arial,helvetica,clean,sans-serif;} > #ygrp-mlmsg pre, code {font:115% monospace;*font-size:100%;} > #ygrp-mlmsg * {line-height:1.22em;} > #ygrp-text{ > font-family: Georgia; > } > #ygrp-text p{ > margin: 0 0 1em 0; > } > #ygrp-tpmsgs{ > font-family: Arial; > clear: both; > } > #ygrp-vitnav{ > padding-top: 10px; > font-family: Verdana; > font-size: 77%; > margin: 0; > } > #ygrp-vitnav a{ > padding: 0 1px; > } > #ygrp-actbar{ > clear: both; > margin: 25px 0; > white-space:nowrap; > color: #666; > text-align: right; > } > #ygrp-actbar .left{ > float: left; > white-space:nowrap; > } > .bld{font-weight:bold;} > #ygrp-grft{ > font-family: Verdana; > font-size: 77%; > padding: 15px 0; > } > #ygrp-ft{ > font-family: verdana; > font-size: 77%; > border-top: 1px solid #666; > padding: 5px 0; > } > #ygrp-mlmsg #logo{ > padding-bottom: 10px; > } > > #ygrp-vital{ > background-color: #e0ecee; > margin-bottom: 20px; > padding: 2px 0 8px 8px; > } > #ygrp-vital #vithd{ > font-size: 77%; > font-family: Verdana; > font-weight: bold; > color: #333; > text-transform: uppercase; > } > #ygrp-vital ul{ > padding: 0; > margin: 2px 0; > } > #ygrp-vital ul li{ > list-style-type: none; > clear: both; > border: 1px solid #e0ecee; > } > #ygrp-vital ul li .ct{ > font-weight: bold; > color: #ff7900; > float: right; > width: 2em; > text-align:right; > padding-right: .5em; > } > #ygrp-vital ul li .cat{ > font-weight: bold; > } > #ygrp-vital a { > text-decoration: none; > } > > #ygrp-vital a:hover{ > text-decoration: underline; > } > > #ygrp-sponsor #hd{ > color: #999; > font-size: 77%; > } > #ygrp-sponsor #ov{ > padding: 6px 13px; > background-color: #e0ecee; > margin-bottom: 20px; > } > #ygrp-sponsor #ov ul{ > padding: 0 0 0 8px; > margin: 0; > } > #ygrp-sponsor #ov li{ > list-style-type: square; > padding: 6px 0; > font-size: 77%; > } > #ygrp-sponsor #ov li a{ > text-decoration: none; > font-size: 130%; > } > #ygrp-sponsor #nc { > background-color: #eee; > margin-bottom: 20px; > padding: 0 8px; > } > #ygrp-sponsor .ad{ > padding: 8px 0; > } > #ygrp-sponsor .ad #hd1{ > font-family: Arial; > font-weight: bold; > color: #628c2a; > font-size: 100%; > line-height: 122%; > } > #ygrp-sponsor .ad a{ > text-decoration: none; > } > #ygrp-sponsor .ad a:hover{ > text-decoration: underline; > } > #ygrp-sponsor .ad p{ > margin: 0; > } > o {font-size: 0; } > .MsoNormal { > margin: 0 0 0 0; > } > #ygrp-text tt{ > font-size: 120%; > } > blockquote{margin: 0 0 0 4px;} > .replbq {margin:4} > --> > </style> > > <!--~-|**|PrettyHtmlEnd|**|-~--> > <!--End group email --> > > > --rtfY8qZgt2yX5-NE6hTkZ4I278b62dgj1Z9eWfX-- > > > -- > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.1.412 / Virus Database: 268.18.1/690 - Release Date: 2/16/2007 > > |
