RCA back-up camera - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: RCA back-up camera (/showthread.php?tid=4548) Pages: 1 2 |
RCA back-up camera - one_dusty_hoot - 03-23-2007 10:44 ED, Were the controls in the side overhead used? Was this an LCD or tube monitor? Was it installed in the overhead front as the original. Was the size about the same? Was the old cable used to pull new cable? So many questions I know, I am looking at doing something with mine, naot a clear picture, blooming, pix tube is on the way out. TIA bob janes, 87fc35, greenivlle, sc --- In WanderlodgeForum@yahoogroups.com, "ed_mcdowell31005" > > Keith, > > Had my backup camera and monitor replaced by Bleakley in Unadilla, Ga > with a color Sony with sound. I am very pleased. New cabling must > be fished to the back so the labor is the big item. > > Ed McDowell > 89FC35 > Bonaire, Ga > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Thanks for the sound advice. I'm always trying to save a buck ya > > know... Guess I'll be using the old one as a paperweight. The > > monitor works. Do you think I can get just the camera??? > > > > Keith > > 84FC35 > > San Diego > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > I am in the process of retrofitting my camera. I removed a Sanyo > > camera and Taiwan Corp tube. I will remove the old power wires > > tomorrow. I am replacing the old camera and tube with an Owls eye > > light sensitive camera and LCD screen. The Owls eye camera is > about > > as big as your thumb. I have had it working on the bench with > > excellent results. I also plan to use another Owls eye camera to > > provide a picture of the R/H side of the bus on a second LCD > screen. > > That should eliminate a dead spot. > > > I'll dig up a couple of web sites to browse for cameras. I'll > also > > advise if I have any luck with my retrofit. Hopefully, the results > > will be good. > > > > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > > > > > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, March 22, 2007 2:08 PM > > > Subject: [WanderlodgeForum] RCA back-up camera > > > > > > > > > I know there is power to the terminals but it does not work. So > I > > want > > > to take my (original equipment?)RCA back-up camera out to have > it > > > tested or to determine if it's worth fixing. Any suggestions? > > > > > > Keith > > > 84FC35 > > > San Diego > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > RCA back-up camera - dspithaler@... - 03-23-2007 15:46 Guys I was wandering where most people mounted the new camera. Do you mount them inside or on the out side. I'm going to put a new one in this spring when I get back home. I put a new glass in my camera housing two years ago from BlueBird & it is starting to go bad already. I guess if the camera has sound it has to be mounted outside. Don 89 SP 36' Butler, PA Going to Orange Lake North of Ocala, FL Saturday from Zephyrhills FL. -----Original Message----- From: maczero1@... To: WanderlodgeForum@yahoogroups.com Sent: Fri, 23 Mar 2007 10:29 AM Subject: [WanderlodgeForum] Re: RCA back-up camera Keith, Had my backup camera and monitor replaced by Bleakley in Unadilla, Ga with a color Sony with sound. I am very pleased. New cabling must be fished to the back so the labor is the big item. Ed McDowell 89FC35 Bonaire, Ga --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Thanks for the sound advice. I'm always trying to save a buck ya > know... Guess I'll be using the old one as a paperweight. The > monitor works. Do you think I can get just the camera??? > > Keith > 84FC35 > San Diego > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > I am in the process of retrofitting my camera. I removed a Sanyo > camera and Taiwan Corp tube. I will remove the old power wires > tomorrow. I am replacing the old camera and tube with an Owls eye > light sensitive camera and LCD screen. The Owls eye camera is about > as big as your thumb. I have had it working on the bench with > excellent results. I also plan to use another Owls eye camera to > provide a picture of the R/H side of the bus on a second LCD screen. > That should eliminate a dead spot. > > I'll dig up a couple of web sites to browse for cameras. I'll also > advise if I have any luck with my retrofit. Hopefully, the results > will be good. > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, March 22, 2007 2:08 PM > > Subject: [WanderlodgeForum] RCA back-up camera > > > > > > I know there is power to the terminals but it does not work. So I > want > > to take my (original equipment?)RCA back-up camera out to have it > > tested or to determine if it's worth fixing. Any suggestions? > > > > Keith > > 84FC35 > > San Diego > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > ________________________________________________________________________ AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com. [Non-text portions of this message have been removed] RCA back-up camera - Richard Hayden - 03-23-2007 16:18 Bob, When I replaced mine I ran the new cable but really didn't need to. The only thing that bought me was the ability to "listen". With the camera inside not much to listen to. I now understand that an adapter is available to use the old coax if in good condition. I went with Sony from rvcams.com. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: one_dusty_hoot To: WanderlodgeForum@yahoogroups.com Sent: Friday, March 23, 2007 2:44 PM Subject: [WanderlodgeForum] Re: RCA back-up camera ED, Were the controls in the side overhead used? Was this an LCD or tube monitor? Was it installed in the overhead front as the original. Was the size about the same? Was the old cable used to pull new cable? So many questions I know, I am looking at doing something with mine, naot a clear picture, blooming, pix tube is on the way out. TIA bob janes, 87fc35, greenivlle, sc --- In WanderlodgeForum@yahoogroups.com "ed_mcdowell31005" > > Keith, > > Had my backup camera and monitor replaced by Bleakley in Unadilla, Ga > with a color Sony with sound. I am very pleased. New cabling must > be fished to the back so the labor is the big item. > > Ed McDowell > 89FC35 > Bonaire, Ga > > --- In WanderlodgeForum@yahoogroups.com "Keith Strehle" > > > > > Thanks for the sound advice. I'm always trying to save a buck ya > > know... Guess I'll be using the old one as a paperweight. The > > monitor works. Do you think I can get just the camera??? > > > > Keith > > 84FC35 > > San Diego > > > > > > > > --- In WanderlodgeForum@yahoogroups.com "Leroy Eckert" > > > > > > > > I am in the process of retrofitting my camera. I removed a Sanyo > > camera and Taiwan Corp tube. I will remove the old power wires > > tomorrow. I am replacing the old camera and tube with an Owls eye > > light sensitive camera and LCD screen. The Owls eye camera is > about > > as big as your thumb. I have had it working on the bench with > > excellent results. I also plan to use another Owls eye camera to > > provide a picture of the R/H side of the bus on a second LCD > screen. > > That should eliminate a dead spot. > > > I'll dig up a couple of web sites to browse for cameras. I'll > also > > advise if I have any luck with my retrofit. Hopefully, the results > > will be good. > > > > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > > > > > > > ----- Original Message ----- > > > From: Keith Strehle > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Thursday, March 22, 2007 2:08 PM > > > Subject: [WanderlodgeForum] RCA back-up camera > > > > > > > > > I know there is power to the terminals but it does not work. So > I > > want > > > to take my (original equipment?)RCA back-up camera out to have > it > > > tested or to determine if it's worth fixing. Any suggestions? > > > > > > Keith > > > 84FC35 > > > San Diego > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] RCA back-up camera - jqrjr - 03-24-2007 03:13 Bob, See previous days post. I di it myself I don't have a FC so I am sure big fifferences but the pull is shorter. I mounted the camera in the old location inside, this has a negitive as in the down position I can only see four feet from the back of the coach bumper. so when the wall is at the edge of the picture I have gotten close enough. WBWL had the carmera in the dash so that is where I mounted it. eaiser on the eyes to see. LCD monitor Jim Riordan 88 WBWL XXV Stuart, Fl. --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > ED, > Were the controls in the side overhead used? Was this an > LCD or tube monitor? Was it installed in the overhead > front as the original. Was the size about the same? > Was the old cable used to pull new cable? So many > questions I know, I am looking at doing something with > mine, naot a clear picture, blooming, pix tube is on > the way out. > TIA > bob janes, 87fc35, greenivlle, sc > > > > > --- In WanderlodgeForum@yahoogroups.com, "ed_mcdowell31005" > > > > > Keith, > > > > Had my backup camera and monitor replaced by Bleakley in Unadilla, > Ga > > with a color Sony with sound. I am very pleased. New cabling must > > be fished to the back so the labor is the big item. > > > > Ed McDowell > > 89FC35 > > Bonaire, Ga > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > Thanks for the sound advice. I'm always trying to save a buck ya > > > know... Guess I'll be using the old one as a paperweight. The > > > monitor works. Do you think I can get just the camera??? > > > > > > Keith > > > 84FC35 > > > San Diego > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > > > > > > > I am in the process of retrofitting my camera. I removed a > Sanyo > > > camera and Taiwan Corp tube. I will remove the old power wires > > > tomorrow. I am replacing the old camera and tube with an Owls > eye > > > light sensitive camera and LCD screen. The Owls eye camera is > > about > > > as big as your thumb. I have had it working on the bench with > > > excellent results. I also plan to use another Owls eye camera to > > > provide a picture of the R/H side of the bus on a second LCD > > screen. > > > That should eliminate a dead spot. > > > > I'll dig up a couple of web sites to browse for cameras. I'll > > also > > > advise if I have any luck with my retrofit. Hopefully, the > results > > > will be good. > > > > > > > > Leroy Eckert > > > > 1990 WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > > > > > > > > > ----- Original Message ----- > > > > From: Keith Strehle > > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Thursday, March 22, 2007 2:08 PM > > > > Subject: [WanderlodgeForum] RCA back-up camera > > > > > > > > > > > > I know there is power to the terminals but it does not work. > So > > I > > > want > > > > to take my (original equipment?)RCA back-up camera out to > have > > it > > > > tested or to determine if it's worth fixing. Any suggestions? > > > > > > > > Keith > > > > 84FC35 > > > > San Diego > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > RCA back-up camera - Keith Strehle - 09-10-2007 05:19 Hey everyone, I have an RCA back up camera in my 84FC35. (original equip?) I removed it yesterday and hope to test it somehow. Any suggestions? I know there is power to the camera and the monitor works. Also, there are three connections on the back of the camera. One for the 12V, one is a single pin cam lock type and the third is a round multi pin connection. There is not a cable for the multi pin connector. Should there be a cable for the multi pin connector or is it not required? Thanks, Keith 84FC35 RCA back-up camera - amweath - 09-10-2007 05:48 Keith, I'm also trying to get mine working. I took the camera to an electronics store that dealt in security systems. They were able to test my camera - it works fine. I've traced my trouble to a broken lead going from the camera trigger relay to the TV on/off panel above the drivers head. The problem is that it isn't obvious where the lead broke off. This after two days off tracing leads. Good luck Art Weatherly Riverside Ca '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Hey everyone, I have an RCA back up camera in my 84FC35. (original > equip?) I removed it yesterday and hope to test it somehow. Any > suggestions? I know there is power to the camera and the monitor > works. > > Also, there are three connections on the back of the camera. One for > the 12V, one is a single pin cam lock type and the third is a round > multi pin connection. There is not a cable for the multi pin > connector. Should there be a cable for the multi pin connector or is > it not required? > > Thanks, Keith > 84FC35 > RCA back-up camera - Keith Strehle - 09-10-2007 06:50 Thanks for the info Art. Can you tell me if the multi-pin connector on yours was being used? Or were there only the 12V leads and the small cam-lock cable? Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > Keith, > > I'm also trying to get mine working. I took the camera to an > electronics store that dealt in security systems. They were able to > test > my camera - it works fine. I've traced my trouble to a broken lead > going from the camera trigger relay to the TV on/off panel above > the drivers head. The problem is that it isn't obvious where the > lead broke off. This after two days off tracing leads. > > Good luck > > Art Weatherly > Riverside Ca > '85 PT36 > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Hey everyone, I have an RCA back up camera in my 84FC35. (original > > equip?) I removed it yesterday and hope to test it somehow. Any > > suggestions? I know there is power to the camera and the monitor > > works. > > > > Also, there are three connections on the back of the camera. One > for > > the 12V, one is a single pin cam lock type and the third is a > round > > multi pin connection. There is not a cable for the multi pin > > connector. Should there be a cable for the multi pin connector or > is > > it not required? > > > > Thanks, Keith > > 84FC35 > > > RCA back-up camera - amweath - 09-10-2007 07:19 I have a very small aftermarket camera. There is no connecter . Four leads come out of the camera. Power (12V.), ground, audio, and video. The 12V. lead goes to green #28 lead that gets power when TV is turned on. The gnd goes to a coach chassis ground. The video goes to a coax which goes the the TV chassis.The audio is unused. Art Weatherly Riverside Ca. '85 PT36 --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Thanks for the info Art. Can you tell me if the multi-pin connector > on yours was being used? Or were there only the 12V leads and the > small cam-lock cable? > > Keith > 84FC35 > > --- In WanderlodgeForum@yahoogroups.com, "amweath" > wrote: > > > > Keith, > > > > I'm also trying to get mine working. I took the camera to an > > electronics store that dealt in security systems. They were able to > > test > > my camera - it works fine. I've traced my trouble to a broken lead > > going from the camera trigger relay to the TV on/off panel above > > the drivers head. The problem is that it isn't obvious where the > > lead broke off. This after two days off tracing leads. > > > > Good luck > > > > Art Weatherly > > Riverside Ca > > '85 PT36 > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > Hey everyone, I have an RCA back up camera in my 84FC35. > (original > > > equip?) I removed it yesterday and hope to test it somehow. Any > > > suggestions? I know there is power to the camera and the monitor > > > works. > > > > > > Also, there are three connections on the back of the camera. One > > for > > > the 12V, one is a single pin cam lock type and the third is a > > round > > > multi pin connection. There is not a cable for the multi pin > > > connector. Should there be a cable for the multi pin connector > or > > is > > > it not required? > > > > > > Thanks, Keith > > > 84FC35 > > > > > > RCA back-up camera - Keith Strehle - 09-10-2007 07:24 Thanks, I thought we were talking about the same camera? Perhaps someone who still has the old RCA camera will chime in. I'll post the model number later... Keith 84FC35 --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > I have a very small aftermarket camera. There is no connecter . > Four leads come out of the camera. Power (12V.), ground, audio, and > video. The 12V. lead goes to green #28 lead that gets power when TV > is turned on. The gnd goes to a coach chassis ground. The video goes > to a coax which goes the the TV chassis.The audio is unused. > > > Art Weatherly > Riverside Ca. > '85 PT36 > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > Thanks for the info Art. Can you tell me if the multi-pin > connector > > on yours was being used? Or were there only the 12V leads and the > > small cam-lock cable? > > > > Keith > > 84FC35 > > > > --- In WanderlodgeForum@yahoogroups.com, "amweath" > > wrote: > > > > > > Keith, > > > > > > I'm also trying to get mine working. I took the camera to an > > > electronics store that dealt in security systems. They were able > to > > > test > > > my camera - it works fine. I've traced my trouble to a broken > lead > > > going from the camera trigger relay to the TV on/off panel above > > > the drivers head. The problem is that it isn't obvious where the > > > lead broke off. This after two days off tracing leads. > > > > > > Good luck > > > > > > Art Weatherly > > > Riverside Ca > > > '85 PT36 > > > > > > > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > > > > > > > > > > Hey everyone, I have an RCA back up camera in my 84FC35. > > (original > > > > equip?) I removed it yesterday and hope to test it somehow. > Any > > > > suggestions? I know there is power to the camera and the > monitor > > > > works. > > > > > > > > Also, there are three connections on the back of the camera. > One > > > for > > > > the 12V, one is a single pin cam lock type and the third is a > > > round > > > > multi pin connection. There is not a cable for the multi pin > > > > connector. Should there be a cable for the multi pin > connector > > or > > > is > > > > it not required? > > > > > > > > Thanks, Keith > > > > 84FC35 > > > > > > > > > > RCA back-up camera - Scott Forman - 09-10-2007 10:46 I replaced the camera on my old FC with a modern color IR unit. I got an adapter at Radio Shack that allowed my to plug it right into the original cable heading to the original monitor. Worked fine. One catch, though...if you get an IR camera, the little IR "lights" will reflect off the small window the camera looks out through and block out the picture at night. You could mount the camera outside to solve the problem, I chose to simply block out the IR with electrical tape. Worked fine. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle" > > Thanks for the sound advice. I'm always trying to save a buck ya > know... Guess I'll be using the old one as a paperweight. The > monitor works. Do you think I can get just the camera??? > > Keith > 84FC35 > San Diego > > > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > I am in the process of retrofitting my camera. I removed a Sanyo > camera and Taiwan Corp tube. I will remove the old power wires > tomorrow. I am replacing the old camera and tube with an Owls eye > light sensitive camera and LCD screen. The Owls eye camera is about > as big as your thumb. I have had it working on the bench with > excellent results. I also plan to use another Owls eye camera to > provide a picture of the R/H side of the bus on a second LCD screen. > That should eliminate a dead spot. > > I'll dig up a couple of web sites to browse for cameras. I'll also > advise if I have any luck with my retrofit. Hopefully, the results > will be good. > > > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > > > > > ----- Original Message ----- > > From: Keith Strehle > > To: WanderlodgeForum@yahoogroups.com > > Sent: Thursday, March 22, 2007 2:08 PM > > Subject: [WanderlodgeForum] RCA back-up camera > > > > > > I know there is power to the terminals but it does not work. So I > want > > to take my (original equipment?)RCA back-up camera out to have it > > tested or to determine if it's worth fixing. Any suggestions? > > > > Keith > > 84FC35 > > San Diego > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > |
