coolant sensor - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: coolant sensor (/showthread.php?tid=455) Pages: 1 2 |
coolant sensor - vmarshall@... - 05-02-2005 19:02 Andy, thanks for the reply. I forgot to mention in my post that my engine light also comes on more often when I am climbing a long hill. Must be something that is common with the 88 PT 40's. Hopefully between the two of us we can find a solution to this problem and will not have to keep over filling the coolant reservoir. Gene Marshall, Dickinson, Texas 1988 PT40 WB coolant sensor - gewans2 - 05-03-2005 04:03 I also have a 88 PT40 WB with the exact symtoms, must be a manufactured problem. Gene Shutt 88 PT40 WB --- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote: > Andy, thanks for the reply. I forgot to mention in my post that my engine light > also comes on more often when I am climbing a long hill. Must be something > that is common with the 88 PT 40's. Hopefully between the two of us we can find > a solution to this problem and will not have to keep over filling the coolant reservoir. > > Gene Marshall, Dickinson, Texas 1988 PT40 WB coolant sensor - Bob & Carol Howald` - 05-03-2005 07:11 --- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote: > Bob, thanks for the input. I will try the same procedure. However, I would like more information > as I have no experience with cannon plugs. Where are they located?? I have heard that > you must have special pliers to remove some types of cannon plugs. How did you remove yours? Also, > where did you purchase the tuner cleaner? Give me as much information > as you can as I have no idea where to begin. The ground straps are not a problem as I previously installed > additional ones. Thanks for your help. > > Gene Marshall, Dickinson, Texas 1988 PT40 WB Gene: The front of my 93 has a panel that come's off. under this panel is the front electrical load center with all the cannon plugs visable. Easy to get to and they just twist to seperate. I buy the tuner spray cleaner at any radio shack store. Hope this help's..Bob 93pt illinois coolant sensor - vmarshall@... - 05-03-2005 08:48 Thanks, I know the plugs you are talking about now. I did not realize that they call them cannon plugs. Thanks again. Gene Marshall, Dickinson, Texas 1988 PT40 WB coolant sensor - johnorud - 05-03-2005 09:54 I also have a 1988 pt40 with the check engine light that comes on when I pull a long hill,this has been constant for four years, The code say low coolant when the tank is full. I have been into William Detroit in Georgia and Phoenix, Detroit diesel shops in North Dakota, Kansas, Missouri, Michigan, and more. The suggestions and cures have ranged from poor ground, bad injectors, bad sender, to duck tape over the lite. I now believe it must be a fault in the computer or wiring or other magical places. But, if other 88 pt40 owners have the same problem it probably is a manufacuring flaw. If anyone finds a cure please post it. --- In WanderlodgeForum@yahoogroups.com, "gewans2" wrote: > I also have a 88 PT40 WB with the exact symtoms, must be a > manufactured problem. > > Gene Shutt 88 PT40 WB > > > > --- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote: > > Andy, thanks for the reply. I forgot to mention in my post that my > engine light > > also comes on more often when I am climbing a long hill. Must be > something > > that is common with the 88 PT 40's. Hopefully between the two of us > we can find > > a solution to this problem and will not have to keep over filling > the coolant reservoir. > > > > Gene Marshall, Dickinson, Texas 1988 PT40 WB coolant sensor - Dennis Nichols - 05-03-2005 12:50 My 1988 PT40 does the same. At 5/3/2005 04:54 PM, johnorud wrote: >I also have a 1988 pt40 with the check engine light that comes on >when I pull a long hill,this has been constant for four years... > >--- In WanderlodgeForum@yahoogroups.com, "gewans2" >wrote: > > I also have a 88 PT40 WB with the exact symtoms, must be a > > manufactured problem. > > > > --- In WanderlodgeForum@yahoogroups.com, vmarshall@h... wrote: > > > Andy, thanks for the reply. I forgot to mention in my post that >my > > engine light > > > also comes on more often when I am climbing a long hill. Must be > > something > > > that is common with the 88 PT 40's. Hopefully between the two of >us > > > > > Gene Marshall, Dickinson, Texas 1988 PT40 WB -- Dennis Nichols '88 WB40 XXV "Priscilla" -- No virus found in this outgoing message. Checked by AVG Anti-Virus. Version: 7.0.308 / Virus Database: 266.11.2 - Release Date: 5/2/2005 coolant sensor - Patticake - 07-05-2011 08:45 Does anyone know where to find a coolant sensor for a DDEC II 8V. Mine has, I think, gone to it's great reward. You would think BB used better parts than to only last 21 years. Steve Gureasko 90WBWL401/2 Jus Chillin Ponchatoula, La. |
