headlamp assemblies - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: headlamp assemblies (/showthread.php?tid=4574) Pages: 1 2 |
headlamp assemblies - Stephen Birtles - 03-28-2007 11:58 I usually use a very special compund to polish lens Crest toothpaste the old green stuff and a buffer works great Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > I failed to mention that I used the headlight refinishing product and they were definately better and was pleased completely but after a summer in the desert the last finishing chemical that was applied turned into little flakes and made the lamps have a crackle finish. I tried sanding and polishing them again with a little success,but the pits from the sand and rock chips made it impossible to refinish to satisfaction.That is the reason for replacement.Desert living does that to these front ends.When I get them changed, I will use the 3M film to protect them,maybe. > The lamps are 88-91 F150 and Bronco. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > headlamp assemblies - Stephen Birtles - 03-28-2007 11:58 I usually use a very special compund to polish lens Crest toothpaste the old green stuff and a buffer works great Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > I failed to mention that I used the headlight refinishing product and they were definately better and was pleased completely but after a summer in the desert the last finishing chemical that was applied turned into little flakes and made the lamps have a crackle finish. I tried sanding and polishing them again with a little success,but the pits from the sand and rock chips made it impossible to refinish to satisfaction.That is the reason for replacement.Desert living does that to these front ends.When I get them changed, I will use the 3M film to protect them,maybe. > The lamps are 88-91 F150 and Bronco. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > |
