Pressure Pro arrived and installed - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Pressure Pro arrived and installed (/showthread.php?tid=4980) Pages: 1 2 |
Pressure Pro arrived and installed - truitt44@...> - 05-26-2007 04:13 Don, I did not say I had extenders on my valve stems. My inside dual stems were too short and I had a choice to add extenders which could develop a leak that would be hard to detect or replace the stem with a longer one. I have put on new tires and new 10" stabilized inside dual stems. Over the life of the new Michelin tires and the Pressure Pro system the prorated cost of new stems will be of little consequence not counting the cost of the Wanderlodge attached to those tires. But to each his own. Howard Truitt Camilla, Ga. 86 PT40 > > From: dspithaler@... > Date: 2007/05/25 Fri PM 09:29:55 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: Re: [WanderlodgeForum] Re: Pressure Pro arrived and installed > > > Howard What is wrong with the extensions on you inside wheel. I run > the extensions with the rubber stabilizer on the outer wheel. It has been > working for me I then put the pressure pro on it. I got the stabilizers off my > tire guy. He is a Blue Bird owner too. > Don > 89 SP 36' > Butler, PA > > To all who purchased the Pressure Pro System. > Most folks have problems with the inside dual stems being too short. For > safety reasons you are advised not to use valve extenders. You may want to check > out the 10" stems for the inside dual and the short stems for the outside > dual offered by Borg Equipment & Supply. www dot borgtiresupply dot com. I > installed the stems on my coach yesterday and now await delivery of my Pressure > Pro System. I have no financial interest in Borg Supply. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > > > Pressure Pro arrived and installed - erniecarpet@... - 05-26-2007 05:57 yea, but it is a pain to check and add air with this configuration. guess I won't drive on gravel roads. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] Pressure Pro arrived and installed - Tom McCarthy - 05-26-2007 06:00 Ernie, I never knew why and it always bothere me since checking air pressure was a contorsion circus. Hwen I got my Pressure Pros last year, I just had to have them turned out so I could get the caps on and off to fill with air. Anybody know why they are always turned in? Fashion? Tommy 2 Shoes McCarthy Poway, CA 95 PT42 --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Tom, why do the valve stems point in? I have a heck of a time checking > pressure on my coach. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > Pressure Pro arrived and installed - Stephen Birtles - 05-26-2007 06:15 protection against rocks slipping in between the duals you can check the air pressure with a truck dual foot gauge push for the outside tire hookand pull for the inside of course the valve have to be lined up with the hand hole on the outside wheel Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Tom McCarthy" > > Ernie, I never knew why and it always bothere me since checking air > pressure was a contorsion circus. Hwen I got my Pressure Pros last > year, I just had to have them turned out so I could get the caps on > and off to fill with air. Anybody know why they are always turned > in? Fashion? > > Tommy 2 Shoes McCarthy > Poway, CA > 95 PT42 > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@ wrote: > > > > Tom, why do the valve stems point in? I have a heck of a time > checking > > pressure on my coach. > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > > > > > > > > > ************************************** See what's free at > http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > Pressure Pro arrived and installed - Bob Lawrence - 05-26-2007 08:24 Ernie, It's a DOT thing. DOT didn't want some road debris to knock the valve stem off and cause an instant flat and possibly turn a truck over. I have been just behind an 18 wheeler that blew a rear tire and the trailer started to sway...scary to watch. That said, I turned mine around to be able to put the Crossfires on. Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > Tom, why do the valve stems point in? I have a heck of a time checking > pressure on my coach. > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
