How is generator battery charged on an 82 FC? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: How is generator battery charged on an 82 FC? (/showthread.php?tid=5245) Pages: 1 2 |
How is generator battery charged on an 82 FC? - truitt44@...> - 06-29-2007 06:47 Kerry, I had the same problem you described. I found a thirty amp. circuit breaker had burnt out replaced it and now charges and cranks fine. Howard Truitt Camilla, Ga. 86 PT40 > > From: "davidkerryedwards" > Date: 2007/06/28 Thu PM 02:10:29 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] How is generator battery charged on an 82 FC? > > My one year old battery on the generator was discharged enough to not turn over the motor > this spring. I could start the generator by pushing the button that connects house and > generator batteries. I assumed it was low from sitting all winter but after driving about 75 > miles, battery is still weak. I assumed the main engine alternator would charge the generator > battery. Is this assumption mistaken? Is the generator battery only charged from 110 volts? > It doesn't seem likely that a battery would fail in just one year (although not altogether out of > the question). > > Kerry > 82 Fc 35 > Denver > > > How is generator battery charged on an 82 FC? - freewill2008 - 06-29-2007 08:25 Pretty sure there is no CB in the early 80s FC charging circuit. BB used #1 cable for the circuit, while a 30A CB would usually be found protecting much smaller cable. For example, if BB had designed for a 3% voltage drop over 40 feet and the current was limited to 30A by the breaker, then the wire size would be #6. Anyone know what size the genset charge cable is on a PT? BB did not seem to use any fuse or CB protection for the big DC cables on the old FCs. I find this kinda freaky, so I keep an eye on the cable runs looking for places where the inslulation might be getting abraded. Anyone remember someone posting about a fire breaking out in the battery compartment of their FC while going down the road about 4 years ago? 3-400 amps of battery + worn insulation + no fuse or breaker = a whole lotta heat! Bob Griesel '84 FC31 WLII WA > > Kerry, > I had the same problem you described. I found a thirty amp. circuit breaker had burnt out replaced it and now charges and cranks fine. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > From: "davidkerryedwards" > > Date: 2007/06/28 Thu PM 02:10:29 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] How is generator battery charged on an 82 FC? > > > > My one year old battery on the generator was discharged enough to not turn over the motor > > this spring. I could start the generator by pushing the button that connects house and > > generator batteries. I assumed it was low from sitting all winter but after driving about 75 > > miles, battery is still weak. I assumed the main engine alternator would charge the generator > > battery. Is this assumption mistaken? Is the generator battery only charged from 110 volts? > > It doesn't seem likely that a battery would fail in just one year (although not altogether out of > > the question). > > > > Kerry > > 82 Fc 35 > > Denver > > > > > > > How is generator battery charged on an 82 FC? - freewill2008 - 06-29-2007 08:50 I mistated this just a little yesterday. The genset should start from the coach batteries as long either cable is connected. If the cable from the isolator to the combiner relay and genset battery is connected, then the genset should crank OK from the coach batteries because current would pass through the isolator in the direction of the genset. Current would not pass the other way from the genset battery through the isolator to the coach batteries however. That is the purpose of the combiner and the cable from the combiner to the 3208 cranking motor. (The 3208 would never crank with that combiner and cable alone of course, but it would help if the coach batteries were marginal.) To start the genset with the coach batteries it would still be better to use the dashboard combiner switch though, because the combiner would keep the genset starting load off the solid state isolator. Bob Griesel --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > It depends on which cable is been disconnected. > > If only the cable from the isolator to the combiner > relay is disconnected, then the genset will start > with the dash combiner, but > there will be no charging > current going to the genset battery from the converter > and/or the 3208 alternator. > > If only the cable from the 3208 starter to the other > side of the combiner relay is disconnected, there will > be charging current going to the genset battery but the > dash combiner switch will not work. > > If both cables going from the front of the coach to > the combiner are disconnected, or the cable from the > combiner to the genset battery is disconnected, then > the dash combiner won't work *and* the genset battery > won't get any charge from the converter and/or 3208 > alternator. > > BobG > > > > > If I understand Bob's post correctly, that > > cable being disconnected would also mean you > > would not have been able to start the generator > > by using the dash combiner switch, yet you were, > > so?? > > > > Don Bradner > > 90 PT40 "Blue Thunder" > > Eureka, CA > > > > On 6/28/2007 at 8:35 PM davidkerryedwards wrote: > > > > >Ah ha. I've seen what I think is that isolate in the house battery > > >compartment mounted on > > >the back wall. There is a heavy cable that is pretty obviously > > >disconnected from that > > >isolator. I have no idea why, but this could easily be the cable > of which > > >you speak and > > >would account for the dead battery. Any idea why someone might > disconnect > > >that cable? > > >It does seem as though the voltage meter on the generator reads > higher > > >when the main > > >engine is running. > > > > > >Kerry > > >82 Fc 35 > > >Denver > > > How is generator battery charged on an 82 FC? - Richard Hayden - 06-30-2007 07:04 That bothered me as well so I installed a 250amp fuse as close to the batteries as I could. The only circuit that is not protected is the starter cable. 250 amps is probably a little small but it has not blown in a year. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: freewill2008 To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 29, 2007 1:25 PM Subject: [WanderlodgeForum] Re: How is generator battery charged on an 82 FC? Pretty sure there is no CB in the early 80s FC charging circuit. BB used #1 cable for the circuit, while a 30A CB would usually be found protecting much smaller cable. For example, if BB had designed for a 3% voltage drop over 40 feet and the current was limited to 30A by the breaker, then the wire size would be #6. Anyone know what size the genset charge cable is on a PT? BB did not seem to use any fuse or CB protection for the big DC cables on the old FCs. I find this kinda freaky, so I keep an eye on the cable runs looking for places where the inslulation might be getting abraded. Anyone remember someone posting about a fire breaking out in the battery compartment of their FC while going down the road about 4 years ago? 3-400 amps of battery + worn insulation + no fuse or breaker = a whole lotta heat! Bob Griesel '84 FC31 WLII WA > > Kerry, > I had the same problem you described. I found a thirty amp. circuit breaker had burnt out replaced it and now charges and cranks fine. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > From: "davidkerryedwards" > > Date: 2007/06/28 Thu PM 02:10:29 EDT > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] How is generator battery charged on an 82 FC? > > > > My one year old battery on the generator was discharged enough to not turn over the motor > > this spring. I could start the generator by pushing the button that connects house and > > generator batteries. I assumed it was low from sitting all winter but after driving about 75 > > miles, battery is still weak. I assumed the main engine alternator would charge the generator > > battery. Is this assumption mistaken? Is the generator battery only charged from 110 volts? > > It doesn't seem likely that a battery would fail in just one year (although not altogether out of > > the question). > > > > Kerry > > 82 Fc 35 > > Denver > > > > > > > [Non-text portions of this message have been removed] |
