Leveling system solenoid - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Leveling system solenoid (/showthread.php?tid=5289) Pages: 1 2 |
Leveling system solenoid - Curt Sprenger - 07-04-2007 19:05 Contact Stephen Birtles for the solenoid. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. truitt44@... wrote: > Scott, > Cole Hersee is the brand of solenoid on my coach. I would think it > would be the same on yours. Google on Cole Hersee call home office and > see if they have a distributor in Memphis. They will send you a > catalog if you ask. > Howard T., Sowega, 86 PT40 > > > > From: "Scott Forman" <sforman@... > > > Date: 2007/07/04 Wed PM 05:16:50 EDT > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] Re: Leveling system solenoid > > > > Thanks for the response, but this is not what I need. I need a > > solenoid, not a relay. The large metal cylindrical things often used > > on older ignition circuits. > > > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com > > > wrote: > > > > > > They're by Bosch and don't get cheap, Chinese-made replacements as > > > they'll fail quickly. Better auto parts stores should carry them, > > but > > > you may need to ask. Often the cheap ones are in blister packs on > > > racks in the automotive electrical department. > > > > > > I bought a bunch of Bosch relays to have on hand from an eBay > > vendor > > > -- about $1 each or so. Genuine Bosch in a 20/30 amp-rating. This > > URL > > > is similar to what I purchased: > > > > <http://cgi.ebay.com/ebaymotors/GENUINE-BOSCH-12V-DC-20-30-Amp-SPDT- > <http://cgi.ebay.com/ebaymotors/GENUINE-BOSCH-12V-DC-20-30-Amp-SPDT-> > > > > > Auto-Relay-10- > > > > > PACK_W0QQcmdZViewItemQQcategoryZ33721QQihZ002QQitemZ120136828374QQrdZ1 > > > > > > (You may need to piece this back together) > > > > > > Or just search eBay for "Bosch relay". You can get them with and > > > without sockets. > > > > > > This URL is for a PDF with a bunch of wiring diagrams showing > > > operation of a Bosch relay. > > > <http://www.dlcparts.com/images/BoschGuide.pdf> > > > > > > And this web site has a great description of how a relay works: > > > <http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/ > <http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/> > > > relay.htm> > > > > > > Pete Masterson > > > '95 Blue Bird Wanderlodge WBDA 42 > > > El Sobrante CA > > > aeonix1@... > > > > > > > > > > > > On Jul 4, 2007, at 12:46 PM, Scott Forman wrote: > > > > > > > I am troubleshooting my inoperative levelers, and I think I have > > > > identified the culprit in one of the three-pin solenoids mounted > > under > > > > the step well. When I jump the current cross the solenoid, the > > motor > > > > runs, so I am pretty sure this is the problem. It is the one > > where > > > > the > > > > third pin must be grounded to deliver the current. Where can I > > find > > > > one of these? > > > > > > > > I bought a generic solenoid that looks similar, but it isn't > > getting > > > > the job done. > > > > > > > > Thanks > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > Leveling system solenoid - truitt44@...> - 07-05-2007 00:20 Scott, The one I used was for the battery charging system. It was a Cole Hersee Intermitant, 3 pole, 12 volt, steel case, model # V30 7400 Howard Truitt Camilla, Ga. 86 PT40 > > From: "Scott Forman" <sforman@...> > Date: 2007/07/04 Wed PM 08:26:27 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Leveling system solenoid > > Which model did you use? > > Scott > > > > --- In WanderlodgeForum@yahoogroups.com, > > > > Scott, > > I ordered my Cole Hersee solenoid from Ryder Fleet Services. If this > leveling unit came with the solenoids from HWH they may have used a > different brand. > > Howard, Sowega, 86 PT40 > > > > > > Leveling system solenoid - Larry - 07-05-2007 01:44 Scott, Go to napa with the solenoid and they can match one up... I took mine there and they came out with an exact match, it is one with the curved base, they counter uy said it was one for a tailgate lift... HTH Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: Scott Forman <sforman@...> To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, July 4, 2007 5:16:50 PM Subject: [WanderlodgeForum] Re: Leveling system solenoid Thanks for the response, but this is not what I need. I need a solenoid, not a relay. The large metal cylindrical things often used on older ignition circuits. Scott --- In WanderlodgeForum@ yahoogroups. com, Pete Masterson wrote: > > They're by Bosch and don't get cheap, Chinese-made replacements as > they'll fail quickly. Better auto parts stores should carry them, but > you may need to ask. Often the cheap ones are in blister packs on > racks in the automotive electrical department. > > I bought a bunch of Bosch relays to have on hand from an eBay vendor > -- about $1 each or so. Genuine Bosch in a 20/30 amp-rating. This URL > is similar to what I purchased: > <http://cgi.ebay. com/ebaymotors/ GENUINE-BOSCH- 12V-DC-20- 30-Amp-SPDT- > Auto-Relay-10- > PACK_W0QQcmdZViewIt emQQcategoryZ337 21QQihZ002QQitem Z120136828374QQr dZ1 > > (You may need to piece this back together) > > Or just search eBay for "Bosch relay". You can get them with and > without sockets. > > This URL is for a PDF with a bunch of wiring diagrams showing > operation of a Bosch relay. > <http://www.dlcparts. com/images/ BoschGuide. pdf> > > And this web site has a great description of how a relay works: > <http://www.classict ruckshop. com/clubs/ earlyburbs/ projects/ bosch/ > relay.htm> > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 > El Sobrante CA > aeonix1@... > > > > On Jul 4, 2007, at 12:46 PM, Scott Forman wrote: > > > I am troubleshooting my inoperative levelers, and I think I have > > identified the culprit in one of the three-pin solenoids mounted under > > the step well. When I jump the current cross the solenoid, the motor > > runs, so I am pretty sure this is the problem. It is the one where > > the > > third pin must be grounded to deliver the current. Where can I find > > one of these? > > > > I bought a generic solenoid that looks similar, but it isn't getting > > the job done. > > > > Thanks > > Scott Forman > > 86 PT38 > > Memphis > > > > [Non-text portions of this message have been removed] > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____ Don't pick lemons. See all the new 2007 cars at Yahoo! Autos. http://autos.yahoo.com/new_cars.html [Non-text portions of this message have been removed] |
