'00 LXi Suspension Level Alarm - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: '00 LXi Suspension Level Alarm (/showthread.php?tid=5485) Pages: 1 2 |
'00 LXi Suspension Level Alarm - Donald Goodwin - 08-08-2007 12:43 I did not do a good job explaining, I just removed fuse where purple wire went to. I also Had bluebird redo sensors under warranty but it still come on occasionally. I Put The Fuse In When I Stop And Usually It Is Fixed. It Is Handy Not To Listen To the Buzzer Going Down the Road. I Travel With a Group of Bluebird's and they ocassio9nally experience the same Problem some LXI's And Some LX's. There alarm will not come back on when the fuse is put back on the Next stop. Donny Goodwin 2003 LXI Montgomery, AL _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of David Brady Sent: Wednesday, August 08, 2007 6:41 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: '00 LXI Suspension Level Alarm When I bought my coach that purple wire was snipped. I reconnected it and diagnosed my slide pin that wasn't engaging properly. I suppose there are cases where the buzzer buzzes spontaneously, but I'm not sure that snipping the wire is the best solution for all. I connected mine, fixed the root cause, and she's been fine ever since. David Brady '02 LXi, NC Donald Goodwin wrote: > > I Have a 2003 LXI AND HAD THIS PROBLEM PERIODCALLY, There Is A Purple Wire > in the Fused Panel On The > > Outside Panel below the Driver's Window. Blue Bird And John Bleakly Both > Showed Me This Trick. I Finally Put > > A Switch on the Dash to Turn It Off. You May Turn It Back Off In 5 Minutes > And The Sensors Will Be Happy. I Have Had > > It Come On After Parking For A Few Minutes And Cranking Back Up. > > Donny Goodwin 2003 LXI > > _____ > > From: WanderlodgeForum@ yahoogroups.com > > [mailto:WanderlodgeForum@ yahoogroups.com > > Sent: Wednesday, August 08, 2007 5:40 PM > To: WanderlodgeForum@ yahoogroups.com > > Subject: Re: [WanderlodgeForum] Re: '00 LXi Suspension Level Alarm > > Allen, > > I believe the "level warning" lamp and buzzer also > takes the HWH slide control as input. I'd first walk > around the coach to take a look at each of the HWH > jacks. Make sure that they are fully retracted; i.e., > no shiny cylinder visible. If you turn off the level control > to soon, a jack may stop before it's fully retracted. > I don't typically turn off the level control - I typically > wait till I put the bus in drive and then check to see that > the "travel" light is on. If so, then you can hit the off > button if you wish. > > If you have a slide, it could be that it's not retracted > fully. The directions say that you should hold the retract > button until pressure builds in the retraction cylinder, is > diverted to the locking pins forcing the pins to lock and > the pressure in the hydraulic system to build causing > the pump to stop. At this point the red light on the > slide control panel will extinguish. Make sure you hold > the retract button until the light extinguishes. If you release > to soon, the pins won't engage the body of the slide, and > the buzzer will buzz, and (I believe), the dash level light will > stay on. > > Note that I'm talking about 2 lights, the red light on the > HWH slide control panel and the "level" light on the dash. > > David Brady > '02 LXi, Smokey > NC > > Allen & Conny wrote: > > > > Thanks Don! I stand corrected it is actually the light > > marked "Level Warning." I assumed the jacks were fully retracted > > because the "Travel" Light shows green on the HWH panel. > > > > Is there a way to try to retract the jacks higher other than hitting > > the "Store" button on the HWH panel? > > > > Thanks! > > > > -Allen > > > > --- In WanderlodgeForum@ > yahoogroups.com > > > > > > > > > > "Suspension level"? > > > > > > On mine, Suspension and Level are two different things, with the > > latter meaning the jacks aren't fully retracted. > > > > > > Don Bradner > > > 90 PT40 "Blue Thunder" > > > Eureka, CA > > > > > > On 8/8/2007 at 8:06 PM Allen & Conny wrote: > > > > > > >Hello Everyone! Since everyone solved the starter battery issue > > so > > > >quickly, I thought I'd throw this one out to the the group... > > > > > > > >After running the coach last night I noticed the suspension level > > > >alarm and light would not turn off. The suspension appeared to > > come > > > >up to full height front and rear. I dumped the suspension and > > waited > > > >for it to come up again, which it did, but the alarm was still > > buzzing > > > >away. The tag axle pressure seemed normal at ~80lbs. > > > > > > > >Any suggestions as to starting the diagnosis process? > > > > > > > >Thank you! > > > > > > > >Allen & Conny > > > >'00 LXi, "Lone Wolf" > > > >Tampa Bay, FL > > > > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.476 / Virus Database: 269.11.8/941 - Release Date: 8/7/2007 > 4:06 PM > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] > > > ---------------------------------------------------------- > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.476 / Virus Database: 269.11.8/941 - Release Date: 8/7/2007 4:06 PM > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] '00 LXi Suspension Level Alarm - Fred Hulse - 08-08-2007 12:56 Sometimes the left front tire will rub against the foot of the jack when making an extremely sharp left turn primarily when backing up and the foot will be tilted enough to keep the jack from retracting fully. This is normally with the 315-80R tires. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] '00 LXi Suspension Level Alarm - Allen & Conny - 08-10-2007 00:59 I would like to thank everyone who responded to my issue. Everyone's suggestions were very helpful. I spent some time on the coach last night following your suggestions. The jacks were all the way up (but the front left pad is slightly bent - Thanks Fred!). I cycled the jacks and the slide making sure I could hear the slide pins fully engaging on its return trip (Is there a visual sign on the HWH control to know when the cycle is complete both out and in?) Viola! The alarm and light went out. I suspect I was in a hurry the last time out and did allow the slide pins to fully engage, thereby tripping the sensors. So the the bus is fine. The fault was due to the dreaded "User Error." Thank you all again! Allen & Conny '00LXi, "Lone Wolf" Tampa Bay, FL --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > Hello Everyone! Since everyone solved the starter battery issue so > quickly, I thought I'd throw this one out to the the group... > > After running the coach last night I noticed the suspension level > alarm and light would not turn off. The suspension appeared to come > up to full height front and rear. I dumped the suspension and waited > for it to come up again, which it did, but the alarm was still buzzing > away. The tag axle pressure seemed normal at ~80lbs. > > Any suggestions as to starting the diagnosis process? > > Thank you! > > Allen & Conny > '00 LXi, "Lone Wolf" > Tampa Bay, FL > |
