Newbie Issues...Engine Bay Cool Down Methods - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Newbie Issues...Engine Bay Cool Down Methods (/showthread.php?tid=5644) |
Newbie Issues...Engine Bay Cool Down Methods - Leroy Eckert - 09-11-2007 12:11 Ron: Question please on the fans. Did you use two relays, a single relay or run the power through the switch. I presume the fans are 16" Hayden or equivalent which draw about 15 amps each. Thanks Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: ronmarabito2002 To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, September 11, 2007 6:30 PM Subject: [WanderlodgeForum] Re: Newbie Issues...Engine Bay Cool Down Methods A few of us here in Texas have installed 12V electric radiator fans on the passenger side of the engine compartment, blowing back over the engine and through the radiator to aid in the cooldown of that area. It really helps a lot. I installed a switch next to the fan that I turn on when I shut the engine off. I let it run for 15 to 30 minutes after shutdown. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > We just took our 43' LXi out for our first shake down cruise to Ft. > Desoto Park in St. Pete, Florida. Aside from the Ranger sending to a > spot we had no prayer of getting into, we had an issue of cooling down > the bedroom of the coach. Granted, it was 94 degrees with 100% > humidity, but the bedroom seemed to take hours and hours to cool down > with all the heat of the engine bay trapped directly below the bed. > > What is the best way to vent the engine bay of all that heat? What > did the dealer not tell me? Any help would be greatly appreciated! > > Thanks! > > -Allen and Conny > '00 43' LXi > "Lone Wolf" > [Non-text portions of this message have been removed] Newbie Issues...Engine Bay Cool Down Methods - Fred Hulse - 09-11-2007 12:26 Allen You should have a 5 inch X about 18 inch flex coupling that goes between your turbo and the muffler and is directly under the floor rear of the bedroom or closet. Be certain that is not leaking exhaust,it is an ideal place for rust to start and of course leak exhaust. Hot and dangerous. Fred & Jeanne Hulse Morristown Arizona 1997 Wanderlodge WLWB41 [Non-text portions of this message have been removed] Newbie Issues...Engine Bay Cool Down Methods - Allen & Conny - 09-11-2007 13:43 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > Allen > You should have a 5 inch X about 18 inch flex coupling that goes between your turbo and the muffler and is directly under the floor rear of the bedroom or closet. > Be certain that is not leaking exhaust,it is an ideal place for rust to start and of course leak exhaust. Hot and dangerous. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > Thanks Fred and Jeanne! Everything in the engine bay seems fine...just hot. I'm going to try opening the main hatch as well as running the roof vent. Part of my problem was also that there was a short in the DeSoto 30A line. It kept tripping the breaker even with just the 'fridge and one A/C going. We woke up at 2AM with the interior warmer than then outside. I fired up the genset and all was well again. Thanks for your help! I'll keep an eye on that flexline.. -Allen and Conny '00 43'LXi "Lone Wolf" New Port Richey, FL Newbie Issues...Engine Bay Cool Down Methods - Allen & Conny - 09-11-2007 13:43 --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote: > > Allen > You should have a 5 inch X about 18 inch flex coupling that goes between your turbo and the muffler and is directly under the floor rear of the bedroom or closet. > Be certain that is not leaking exhaust,it is an ideal place for rust to start and of course leak exhaust. Hot and dangerous. > Fred & Jeanne Hulse > Morristown Arizona > 1997 Wanderlodge WLWB41 > > [Non-text portions of this message have been removed] > Thanks Fred and Jeanne! Everything in the engine bay seems fine...just hot. I'm going to try opening the main hatch as well as running the roof vent. Part of my problem was also that there was a short in the DeSoto 30A line. It kept tripping the breaker even with just the 'fridge and one A/C going. We woke up at 2AM with the interior warmer than then outside. I fired up the genset and all was well again. Thanks for your help! I'll keep an eye on that flexline.. -Allen and Conny '00 43'LXi "Lone Wolf" New Port Richey, FL Newbie Issues...Engine Bay Cool Down Methods - Bob Lawrence - 09-11-2007 15:22 Out here in the Seattle area, after a run, I turn on the fan override and leave it on till shutdown. Also open the engine hatch for a couple of hours. Since we have a Select Comfort air bed, it really blows up with the hot air coming up. I try to remember to let air out before we start for the day. Bob Lawrence 84 PT36 Tacoma, Wa. > > What is the best way to vent the engine bay of all that heat? What > did the dealer not tell me? Any help would be greatly appreciated! > > Thanks! > > -Allen and Conny > '00 43' LXi > "Lone Wolf" > Newbie Issues...Engine Bay Cool Down Methods - Gregory OConnor - 09-11-2007 17:10 Run the fan on switch from the cockpit to over cool the engine prior to shut down. The engine will rise in temp after shut down befor it starts to cool at rest. I fear any attempt to reinsulate to correct the problem, may prove a fire danger. Being the shake down cruise, The heat may be more alarming then actualy uncomfortable. I was concerned at first, now I defrost in the bedroom closet. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Allen & Conny" > > We just took our 43' LXi out for our first shake down cruise to Ft. > Desoto Park in St. Pete, Florida. Aside from the Ranger sending to a > spot we had no prayer of getting into, we had an issue of cooling down > the bedroom of the coach. Granted, it was 94 degrees with 100% > humidity, but the bedroom seemed to take hours and hours to cool down > with all the heat of the engine bay trapped directly below the bed. > > What is the best way to vent the engine bay of all that heat? What > did the dealer not tell me? Any help would be greatly appreciated! > > Thanks! > > -Allen and Conny > '00 43' LXi > "Lone Wolf" > Newbie Issues...Engine Bay Cool Down Methods - Allen & Conny - 09-12-2007 02:53 --- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > > Out here in the Seattle area, after a run, I turn on the fan override > and leave it on till shutdown. > Bob, Thanks for the advice. I noticed that the fan override switch on my coach only works when the engine is running. It would be nice if those fans worked after engine shut down. That would vent the heat quickly... Thanks again! -Allen and Conny '00 43' LXi "Lone Wolf" New Port Richey, FL Newbie Issues...Engine Bay Cool Down Methods - Don Bradner - 09-12-2007 02:59 I don't know about the '00 coach, but for most (all?) of us, that fan is hydraulic, so it can't run with the engine off. Don Bradner 90 PT40 "Blue Thunder" Posting by satellite from Boise, Idaho, headed towards Salt Lake City today. On 9/12/2007 at 2:53 PM Allen & Conny wrote: >--- In WanderlodgeForum@yahoogroups.com, "Bob Lawrence" > >> >> Out here in the Seattle area, after a run, I turn on the fan >override >> and leave it on till shutdown. >> > >Bob, >Thanks for the advice. I noticed that the fan override switch on my >coach only works when the engine is running. It would be nice if >those fans worked after engine shut down. That would vent the heat >quickly... > >Thanks again! > >-Allen and Conny >'00 43' LXi "Lone Wolf" >New Port Richey, FL Newbie Issues...Engine Bay Cool Down Methods - Allen & Conny - 09-12-2007 03:28 --- In WanderlodgeForum@yahoogroups.com, "Don Bradner" > > I don't know about the '00 coach, but for most (all?) of us, that fan is hydraulic, so it can't run with the engine off. > > Don Bradner > 90 PT40 "Blue Thunder" > Posting by satellite from Boise, Idaho, headed towards Salt Lake City today. > > Hey Don, That explains it. I'll have to remember to switch it on for a while prior shut down. I can't tell you how much we appreciate everyone's knowledge and patience. We are very new to this.. On another subject, I noticed your response came via satellite. We bought the coach specifically to explore the West next summer for three months. I would like to stay in contact with my office during the trip and I need to explore ways of doing so, either satellite or broadband cell. When you get a moment, can you let me know how your satellite connection works? I know the dish on my coach is in- motion and the receiver is DirectTV but I haven't tried either one yet. Thank you! > > >-Allen and Conny > >'00 LXi "Lone Wolf" > >New Port Richey, FL > Newbie Issues...Engine Bay Cool Down Methods - Larry Watson - 09-12-2007 10:12 > > You should have a 5 inch X about 18 inch flex coupling that goes > between your turbo and the muffler and is directly under the floor > rear of the bedroom or closet. > > Be certain that is not leaking exhaust,it is an ideal place for > rust to start and of course leak exhaust. Hot and dangerous. Allen, I once had a problem with that piece of pipe with the flex coupling. It was cracked right at the flange where the pipe clamped to the output of the turbo. You couldn't see the crack and there was no noticeable exhaust escape at idle speed, but at highway RPM the pressure would separate the pipe at the crack! The first symptom I noticed was a noticeable drop in turbo boost pressure. The engine compartment got so hot that the plastic placard on the Front/Rear ignition switchover panel started turning up at the corners! Larry Watson '87 PT40 Greensboro, GA |
