The only problem with the "Fortress of Solitude" - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: The only problem with the "Fortress of Solitude" (/showthread.php?tid=581) Pages: 1 2 |
The only problem with the "Fortress of Solitude" - pattypape - 05-12-2005 01:05 Hi George, If my coach air is dumped, but not level, sometimes the dead bolts and door strickers did not lineup. I had to make some adjustments to allow the electrical security lock to function properly. Bill 88FC Michigan --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > I gotta tell ya, I love my bird. I've traveled all over and > always feel safe no matter where I park for the night. > This thing is literally the fortress of solitude. > I've only considered one problem and my extensive > "Blue Box" doesn't seem to address it and I've not seen > it come up in this forum. > I've got a remote lock for the entry door. I can > switch it from the driver's seat or the bedroom. It's > an electric solonoid operated lock cylinder. > So, where's the manual over-ride for this thing? What > happens when I can't get it to unlock? Sure, I can > get out, but how do I get back in? (grin) > I'll save my other security question (will a 9mm bullet > penetrate the skin) for another post. LOL > > George Witt > 81 FC 35 > Lincoln, Nebraska--Huskers The only problem with the "Fortress of Solitude" - Tim Hannink - 05-12-2005 01:30 On a related note, the door lock switch above the streetside bed in my coach has another switch that evidently turns on all the exterior lights for security purposes. Mine doesn't seem to be working. I found the wiring diagram for the circuit in my BlueBook, but they didn't give the location of the relay that controls this circuit. Any idea on where it is located? Thanks, Tim Hannink Winter Park, FL 1981 FC33SB --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > Mine doesn't work from either switch. does anyone know where the > relay is located? Is the solenoid hard to get to? I guess I should > check it there first to see if I'm getting battery. > The only problem with the "Fortress of Solitude" - fred89sp - 05-12-2005 01:40 I think it is a lever that goes on the deadbolt tang. BB parts should have it, I doubt there is another source. --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > In a message dated 5/11/2005 10:03:33 P.M. Eastern Daylight Time, > randy@r... writes: > > on the coachs i've had it worked the deadbolts.you just need to take the > door apart and hook up the solenoid to the deadbolt.it should be easy for you! > randydupree93wb > > > randy do you know where you can get parts for the electric dead bolt. I had > mine apart & lost the cam that went on the dead bolt where you installed the > wire from the solenoid. > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] The only problem with the "Fortress of Solitude" - pattypape - 05-12-2005 01:47 Tim, On our 88 FC, the relay was apparently removed by the previous owner, (probably ran the battery down) It turns on the four docking lights headlights and the rear parking lights. It was located in the read bedroom overhead storage, near the back up camera. Purchased a relay from BB. If you need this part number I will find it. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Tim Hannink" > On a related note, the door lock switch above the streetside bed in > my coach has another switch that evidently turns on all the exterior > lights for security purposes. Mine doesn't seem to be working. I > found the wiring diagram for the circuit in my BlueBook, but they > didn't give the location of the relay that controls this circuit. > Any idea on where it is located? > > Thanks, > > Tim Hannink > Winter Park, FL > 1981 FC33SB > > > > --- In WanderlodgeForum@yahoogroups.com, "fl_bluebird_1983" > > > Mine doesn't work from either switch. does anyone know where the > > relay is located? Is the solenoid hard to get to? I guess I should > > check it there first to see if I'm getting battery. > > The only problem with the "Fortress of Solitude" - Gary Miller - 05-12-2005 05:39 George, Mine is set up the same way. If memory serves, the lock bolt consists of an inner bolt and an outer sleeve. The electric portion is the inner bolt. Manually locking the deadbolt moves both parts at the same time. Since the extension limit of the inner bolt is the same as the outer sleeve, when you lock the bolt manually, the inner bolt should extend no further. Thus doing so will not afford you any additional security. I believe the switches are there in case you forgot to lock the door and are underway (dashboard), or in your bedroom for the night. What you may be running into is that by not moving the whole assembly all the way to the locked position, when you actuate the switch, the inner portion moves slightly further out. Now when you unlock the door manually, the inner portion is still protruding into the door jamb (just past the outer sleeve) preventing you from opening your door. Another thought is that the outer portion is binding and not going into the jamb all the way, or the inner portion is somehow able to move out further when the bolt is all the way into the jamb. If you have locked the door remotely and are standing at the door, I believe you can lock the bolt manually (causing the inner portion to push back into the outer) then unlock it and you will be free to open your door. You do have additional security by locking the latch and the bolt however. Regarding the 9mm. After penetrating the steel outer skin, the bullet will be greatly energy depleted and likely tumbling, especially if it is a hollow point. Keep in mind that the door is softer aluminum, but a heavier gauge. Windows are another option but they're laminated and won't burst like most safety glass and they're not produced in your shade anymore (I think). Consider ammo with a steel core. ![]() I also enjoy the fortress like nature of the Wanderlodge, especially with a family on board. My additional security consists of a well groomed and trained, 4 year old, 60 pound, female border collie. When the dinette becomes a bed, she moves to the stepwell platform for the night, which puts her nose at about most peoples' chin level if they were to open the door. Being young, her teeth are very white against her black face and 1000 yard border collie stare. Although she's received much training, she has never overcome her aversion to strange men (my wife says that's why border collies are considered smart), especially if they 1) wear a hat, 2)look at her, 3) smile at her (teeth), and/or 4)reach out to her. Put a frisbee in your hand, however, and she'll eventually like you. Where the kids go, she goes. Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > I gotta tell ya, I love my bird. I've traveled all over and > always feel safe no matter where I park for the night. > This thing is literally the fortress of solitude. > I've only considered one problem and my extensive > "Blue Box" doesn't seem to address it and I've not seen > it come up in this forum. > I've got a remote lock for the entry door. I can > switch it from the driver's seat or the bedroom. It's > an electric solonoid operated lock cylinder. > So, where's the manual over-ride for this thing? What > happens when I can't get it to unlock? Sure, I can > get out, but how do I get back in? (grin) > I'll save my other security question (will a 9mm bullet > penetrate the skin) for another post. LOL > > George Witt > 81 FC 35 > Lincoln, Nebraska--Huskers The only problem with the "Fortress of Solitude" - ttikalsky - 05-12-2005 05:57 Does the "inner" bolt reside in the door or the outer frame? --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > George, > > Mine is set up the same way. If memory serves, the lock bolt > consists of an inner bolt and an outer sleeve. The electric portion > is the inner bolt. > > Manually locking the deadbolt moves both parts at the same time. > > Since the extension limit of the inner bolt is the same as the outer > sleeve, when you lock the bolt manually, the inner bolt should extend > no further. Thus doing so will not afford you any additional > security. I believe the switches are there in case you forgot to > lock the door and are underway (dashboard), or in your bedroom for > the night. > > What you may be running into is that by not moving the whole assembly > all the way to the locked position, when you actuate the switch, the > inner portion moves slightly further out. Now when you unlock the > door manually, the inner portion is still protruding into the door > jamb (just past the outer sleeve) preventing you from opening your > door. Another thought is that the outer portion is binding and not > going into the jamb all the way, or the inner portion is somehow able > to move out further when the bolt is all the way into the jamb. > > If you have locked the door remotely and are standing at the door, I > believe you can lock the bolt manually (causing the inner portion to > push back into the outer) then unlock it and you will be free to open > your door. > > You do have additional security by locking the latch and the bolt > however. > > Regarding the 9mm. After penetrating the steel outer skin, the > bullet will be greatly energy depleted and likely tumbling, > especially if it is a hollow point. Keep in mind that the door is > softer aluminum, but a heavier gauge. Windows are another option but > they're laminated and won't burst like most safety glass and they're > not produced in your shade anymore (I think). Consider ammo with a > steel core. ![]() > > I also enjoy the fortress like nature of the Wanderlodge, especially > with a family on board. My additional security consists of a well > groomed and trained, 4 year old, 60 pound, female border collie. > When the dinette becomes a bed, she moves to the stepwell platform > for the night, which puts her nose at about most peoples' chin level > if they were to open the door. Being young, her teeth are very white > against her black face and 1000 yard border collie stare. > > Although she's received much training, she has never overcome her > aversion to strange men (my wife says that's why border collies are > considered smart), especially if they 1) wear a hat, 2)look at her, > 3) smile at her (teeth), and/or 4)reach out to her. Put a frisbee in > your hand, however, and she'll eventually like you. Where the kids > go, she goes. > > Gary Miller > 83 FC 33 > Wauwatosa, WI > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > wrote: > > I gotta tell ya, I love my bird. I've traveled all over and > > always feel safe no matter where I park for the night. > > This thing is literally the fortress of solitude. > > I've only considered one problem and my extensive > > "Blue Box" doesn't seem to address it and I've not seen > > it come up in this forum. > > I've got a remote lock for the entry door. I can > > switch it from the driver's seat or the bedroom. It's > > an electric solonoid operated lock cylinder. > > So, where's the manual over-ride for this thing? What > > happens when I can't get it to unlock? Sure, I can > > get out, but how do I get back in? (grin) > > I'll save my other security question (will a 9mm bullet > > penetrate the skin) for another post. LOL > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska--Huskers The only problem with the "Fortress of Solitude" - Gary Miller - 05-12-2005 06:02 It's a single deadbolt, two pieces. Moves as one single unit manually. Gary Miller --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" wrote: > Does the "inner" bolt reside in the door or the outer frame? > > --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > > > George, > > > > Mine is set up the same way. If memory serves, the lock bolt > > consists of an inner bolt and an outer sleeve. The electric portion > > is the inner bolt. > > > > Manually locking the deadbolt moves both parts at the same time. > > > > Since the extension limit of the inner bolt is the same as the outer > > sleeve, when you lock the bolt manually, the inner bolt should extend > > no further. Thus doing so will not afford you any additional > > security. I believe the switches are there in case you forgot to > > lock the door and are underway (dashboard), or in your bedroom for > > the night. > > > > What you may be running into is that by not moving the whole assembly > > all the way to the locked position, when you actuate the switch, the > > inner portion moves slightly further out. Now when you unlock the > > door manually, the inner portion is still protruding into the door > > jamb (just past the outer sleeve) preventing you from opening your > > door. Another thought is that the outer portion is binding and not > > going into the jamb all the way, or the inner portion is somehow able > > to move out further when the bolt is all the way into the jamb. > > > > If you have locked the door remotely and are standing at the door, I > > believe you can lock the bolt manually (causing the inner portion to > > push back into the outer) then unlock it and you will be free to open > > your door. > > > > You do have additional security by locking the latch and the bolt > > however. > > > > Regarding the 9mm. After penetrating the steel outer skin, the > > bullet will be greatly energy depleted and likely tumbling, > > especially if it is a hollow point. Keep in mind that the door is > > softer aluminum, but a heavier gauge. Windows are another option but > > they're laminated and won't burst like most safety glass and they're > > not produced in your shade anymore (I think). Consider ammo with a > > steel core. ![]() > > > > I also enjoy the fortress like nature of the Wanderlodge, especially > > with a family on board. My additional security consists of a well > > groomed and trained, 4 year old, 60 pound, female border collie. > > When the dinette becomes a bed, she moves to the stepwell platform > > for the night, which puts her nose at about most peoples' chin level > > if they were to open the door. Being young, her teeth are very white > > against her black face and 1000 yard border collie stare. > > > > Although she's received much training, she has never overcome her > > aversion to strange men (my wife says that's why border collies are > > considered smart), especially if they 1) wear a hat, 2)look at her, > > 3) smile at her (teeth), and/or 4)reach out to her. Put a frisbee in > > your hand, however, and she'll eventually like you. Where the kids > > go, she goes. > > > > Gary Miller > > 83 FC 33 > > Wauwatosa, WI > > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > > wrote: > > > I gotta tell ya, I love my bird. I've traveled all over and > > > always feel safe no matter where I park for the night. > > > This thing is literally the fortress of solitude. > > > I've only considered one problem and my extensive > > > "Blue Box" doesn't seem to address it and I've not seen > > > it come up in this forum. > > > I've got a remote lock for the entry door. I can > > > switch it from the driver's seat or the bedroom. It's > > > an electric solonoid operated lock cylinder. > > > So, where's the manual over-ride for this thing? What > > > happens when I can't get it to unlock? Sure, I can > > > get out, but how do I get back in? (grin) > > > I'll save my other security question (will a 9mm bullet > > > penetrate the skin) for another post. LOL > > > > > > George Witt > > > 81 FC 35 > > > Lincoln, Nebraska--Huskers The only problem with the "Fortress of Solitude" - Gary Miller - 05-12-2005 08:40 Actually, I don't think I answered the question... From my recollection, and I'll be at my bird later today, the inner portion resides in the door frame. If it's extended, manually turning the bolt will push it back in. If the manual portion is extended, the inner portion (electric) will not move when actuated. It may extend somewhat if the manual bolt is not locked all the way into the jamb, and could interfere with opening the door when the manual bolt is retracted from it's partial position. Basically, I believe they interfere with each other and cannot be used at the same time, but the manual mode should always be able to push the automatic mode clear of the door if you need to unlock the door. Just lock the door manually(all the way), and unlock it. -whew- Gary Miller 83 FC 33 Wauwatosa, WI --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > It's a single deadbolt, two pieces. Moves as one single unit > manually. > > Gary Miller > > --- In WanderlodgeForum@yahoogroups.com, "ttikalsky" > wrote: > > Does the "inner" bolt reside in the door or the outer frame? > > > > --- In WanderlodgeForum@yahoogroups.com, "Gary Miller" > > > > > George, > > > > > > Mine is set up the same way. If memory serves, the lock bolt > > > consists of an inner bolt and an outer sleeve. The electric > portion > > > is the inner bolt. > > > > > > Manually locking the deadbolt moves both parts at the same time. > > > > > > Since the extension limit of the inner bolt is the same as the > outer > > > sleeve, when you lock the bolt manually, the inner bolt should > extend > > > no further. Thus doing so will not afford you any additional > > > security. I believe the switches are there in case you forgot to > > > lock the door and are underway (dashboard), or in your bedroom > for > > > the night. > > > > > > What you may be running into is that by not moving the whole > assembly > > > all the way to the locked position, when you actuate the switch, > the > > > inner portion moves slightly further out. Now when you unlock > the > > > door manually, the inner portion is still protruding into the > door > > > jamb (just past the outer sleeve) preventing you from opening > your > > > door. Another thought is that the outer portion is binding and > not > > > going into the jamb all the way, or the inner portion is somehow > able > > > to move out further when the bolt is all the way into the jamb. > > > > > > If you have locked the door remotely and are standing at the > door, I > > > believe you can lock the bolt manually (causing the inner portion > to > > > push back into the outer) then unlock it and you will be free to > open > > > your door. > > > > > > You do have additional security by locking the latch and the bolt > > > however. > > > > > > Regarding the 9mm. After penetrating the steel outer skin, the > > > bullet will be greatly energy depleted and likely tumbling, > > > especially if it is a hollow point. Keep in mind that the door > is > > > softer aluminum, but a heavier gauge. Windows are another option > but > > > they're laminated and won't burst like most safety glass and > they're > > > not produced in your shade anymore (I think). Consider ammo with > a > > > steel core. ![]() > > > > > > I also enjoy the fortress like nature of the Wanderlodge, > especially > > > with a family on board. My additional security consists of a > well > > > groomed and trained, 4 year old, 60 pound, female border collie. > > > When the dinette becomes a bed, she moves to the stepwell > platform > > > for the night, which puts her nose at about most peoples' chin > level > > > if they were to open the door. Being young, her teeth are very > white > > > against her black face and 1000 yard border collie stare. > > > > > > Although she's received much training, she has never overcome her > > > aversion to strange men (my wife says that's why border collies > are > > > considered smart), especially if they 1) wear a hat, 2)look at > her, > > > 3) smile at her (teeth), and/or 4)reach out to her. Put a > frisbee in > > > your hand, however, and she'll eventually like you. Where the > kids > > > go, she goes. > > > > > > Gary Miller > > > 83 FC 33 > > > Wauwatosa, WI > > > > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" > <mrdonut12@y...> > > > wrote: > > > > I gotta tell ya, I love my bird. I've traveled all over and > > > > always feel safe no matter where I park for the night. > > > > This thing is literally the fortress of solitude. > > > > I've only considered one problem and my extensive > > > > "Blue Box" doesn't seem to address it and I've not seen > > > > it come up in this forum. > > > > I've got a remote lock for the entry door. I can > > > > switch it from the driver's seat or the bedroom. It's > > > > an electric solonoid operated lock cylinder. > > > > So, where's the manual over-ride for this thing? What > > > > happens when I can't get it to unlock? Sure, I can > > > > get out, but how do I get back in? (grin) > > > > I'll save my other security question (will a 9mm bullet > > > > penetrate the skin) for another post. LOL > > > > > > > > George Witt > > > > 81 FC 35 > > > > Lincoln, Nebraska--Huskers The only problem with the "Fortress of Solitude" - dspithaler@... - 05-12-2005 09:07 In a message dated 5/12/2005 9:42:45 A.M. Eastern Daylight Time, friester@... writes: I think it is a lever that goes on the deadbolt tang. BB parts should have it, I doubt there is another source. --- In WanderlodgeForum@yahoogroups.com, dspithaler@a... wrote: > > In a message dated 5/11/2005 10:03:33 P.M. Eastern Daylight Time, > randy@r... writes: > > on the coach's I've had it worked the deadbolts.you just need to take the > door apart and hook up the solenoid to the deadbolt.it should be easy for you! > randydupree93wb > > > randy do you know where you can get parts for the electric dead bolt. I had > mine apart & lost the cam that went on the dead bolt where you installed the > wire from the solenoid. > Don > 89 SP 36' > Butler, PA > > > [Non-text portions of this message have been removed] Fred I tried to get the complete lock when I was at the Birds Nest last month.My dead bolt lock is a Dexter. They said you could not get them Don 89 SP 36' Butler, PA [Non-text portions of this message have been removed] The only problem with the "Fortress of Solitude" - dspithaler@... - 05-13-2005 11:52 In a message dated 5/12/2005 9:42:45 A.M. Eastern Daylight Time, friester@... writes: I think it is a lever that goes on the deadbolt tang. BB parts should have it, I doubt there is another source. I got tired of looking for that lever that goes on the deadbolt. I lost mine when I had the lock off to cover the door panel with the same material that my dinette cushions were covered in. Today I decided to make one. About 4 hours later I had it working like a new one. I had tow make a few to get the right throw on it. What I don't like is when you know what you need but you can't buy the part. The guy in BlueBird Parts didn't have a clue as to what I was talking about in the lock. He brought out the other lock above the deadbolt. Earl was on vacation at the time when I was there last month. Don S 89 SP 36' Butler, PA [Non-text portions of this message have been removed] |
