Air Height valves - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Height valves (/showthread.php?tid=6354) Pages: 1 2 |
Air Height valves - pattypape - 02-16-2008 04:04 Hi Bruce, I posted yesterday ,but it disappeared, so this may be a double post. The Swivel that John McGinnis is referring to is a NAPA 732-1400, 1/4 28 thread. It screws onto the top of the adjusting rod. At the bottom of the rod is the adjustment , a fixed swivel attached to a bracket on the main axle, this I believe is the harder to locate item. Sorry I am late, & Hope this helps, Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "John McGinnis" > > Bruce, I don't know what the specific problem might be with the leak in > leveling system but FWIW I'd like to suggest while your in that area > working you might want to take the time to replace the swivel ball > joint on the end of the connecting rod on the air leveler. It's a > $3.00 part and after 20 years of road grime it will seaze up and break > off. That happen to me on the first day of ownership of my bird. I > thought I had an air leak or ruptured air bag until we crawled around > underneath and found the rod hanging loose. Driving in some road > conditions it would wiggle around and catch and the bag would inflat > then others it would deflat. Somewhere I have the NAPA & Carquest part > numbers for the ball joint. Maybe Bill Pape will come on, I sent him a > NAPA ball joint awhile back he lives on his bird & mine is in storage > so he can get to the parts number quicker. Good luck. > John 88FC35 > Air Height valves - birdshill123 - 02-17-2008 08:14 Thanks Bill Bruce 1988 FC35 |
