A new problem for this group to ponder - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: A new problem for this group to ponder (/showthread.php?tid=6544) Pages: 1 2 |
A new problem for this group to ponder - robert nloomas - 04-03-2008 02:46 --- In WanderlodgeForum@yahoogroups.com, Drew May wrote: Drew I had the same thing happen.what I took the inversion valve a part and clean it and lube it also the exh.port was plug I clean that out and every thing return normal. Bob Loomas 1985 PT 36 > > Thanks Ralph! > > "Ralph L. Fullenwider" wrote: Hi Drew: > > The exhaust port on the inversion valve is sticking or the double check > valve is sticking, either one will give you much the same symptoms. Both of > those valve are located on the curb side rear under the grill hatch. Need a > can of 3 in 1 oil or fish oil, remove the input air line and put a few > drops of air in the line, re connect, build the air and cycle the system. > Do this to both valves. > > It should take care of the problem. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > At 07:49 PM 4/2/2008 -0700, you wrote: > > >Hello everyone, > > > >I experienced a new "issue" on our way home from Alabama after taking 20 > >laps behind the wheel of a Nascar race car at Talladega. What a blast! > > > >Here's the new problem. I had used the cruise control all day and also had > >the retarder switch on (but not using). I came to a stop at an > >intersection and when I applied the brakes my engine revved to 1000 RPM's > >(above the typical 550 RPM's when stopping & off the accelerator). I took > >my foot off the brake, engine kicks down back to 550 rpm's (normal). I > >applied the brake again, engine kicked back up to 1000 rpm's. Very very > >strange. I had this happen a few times, one time getting up to 1500 RPM's > >when trying to stop the coach which was a chore and very scary to think > >the coach wouldn't stop. I put the coach in neutral when applying the > >brake, didn't stop the high RPM's while having the coach brake applied. > >After being back underway, before the next stop, I switched the cruise to > >off and the retarder to off. Coming to my next stop the coach braked > >normally until I got home. Yesterday, I went to move the coach, and it did > >the exact same thing with cruise and retarder off. Apply the brakes, > >engine revs to 1000 rpm's whether the coach is in reverse, drive or > >neutral. This is probably not an easy fix, but would appreciate any > >collective direction or thoughts on the matter. > > > >Thank you in advance!! > > > >Drew May > >Conway, AR > >'88 WB40 > > > > > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 "Ruff Diamond" > Duncan, Oklahoma > > > > > > > --------------------------------- > You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. > A new problem for this group to ponder - Gregory OConnor - 04-03-2008 04:17 I realy didnt have a thought about the M&G other then the first things I look to when a problem arises is ;self inflicted changes ;recent repairs, and ;operator confusion. M&G uses air and the toad is a big electiral system modification to the bus. Drew's post was full of good details, I wanted him to reveal more to the readers who may have the solution. It sounds like RalphF has the solution, and Drew will followup with a result. I just wish the subject line was more descriptive as to help with a future archive search. Looking at the prompt to the problem (pushing the brake pedal) Leroy was able to surmise the TwoPedal/BigToe theory. Since pushing the pedal moves air and turns on electric brake lights, it may be air or electric. I have no idea how the cruise or high idle works knowlede of those systems would help solve his issue. I am not confident enough to use CruiseControl to drive or use an air operated high idle system to warm my bus. The service brakes(prompted by driver brake pedal) in an air brake system are pressure applied, without pressure the brakes are off. The park brake spring is the one that needs constant pressure to remain off. If the M&G brake away brake option fails, it may lock the toad brakes up GregoryO'Connoir 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jim Riordan" wrote: > > Greg, > > I just installed an M&G brake system on my 88 WBWL XXV did not think > that it would affect anything but possibly if air leak that the > brakes would not come off! what were you thinking that the M&G might > do? > > Jim Riordan > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > If I asked "how big are your feet?" Ernie and Mike would put me on > > restrictive post. just aint fair. > > > > Do you have an M&G toad suplemental braking system? Or any mods of > > the sort? > > I wonder what signals the cruise to kick off when the brakes are > > applied? > > I wonder if it has somthing to do with 'fast idle' and brake light > > signal kicking in a false fast idle? > > > > If you apply the brakes while in Allison "N" can you get the 1000R > > responce? > > > > GregoryO'Connor > > 94ptRomolandCa > > > > > > --- In WanderlodgeForum@yahoogroups.com, Drew May > > wrote: > > > > > > > > > > > > Hello everyone, > > > > > > I experienced a new "issue" on our way home from Alabama after > > taking 20 laps behind the wheel of a Nascar race car at Talladega. > > What a blast! > > > > > > Here's the new problem. I had used the cruise control all day and > > also had the retarder switch on (but not using). I came to a stop > at > > an intersection and when I applied the brakes my engine revved to > > 1000 RPM's (above the typical 550 RPM's when stopping & off the > > accelerator). I took my foot off the brake, engine kicks down back > > to 550 rpm's (normal). I applied the brake again, engine kicked > back > > up to 1000 rpm's. Very very strange. I had this happen a few times, > > one time getting up to 1500 RPM's when trying to stop the coach > > which was a chore and very scary to think the coach wouldn't stop. > I > > put the coach in neutral when applying the brake, didn't stop the > > high RPM's while having the coach brake applied. After being back > > underway, before the next stop, I switched the cruise to off and > the > > retarder to off. Coming to my next stop the coach braked normally > > until I got home. Yesterday, I went to move the coach, and it did > > the exact same thing with cruise and retarder off. > > > Apply the brakes, engine revs to 1000 rpm's whether the coach is > > in reverse, drive or neutral. This is probably not an easy fix, but > > would appreciate any collective direction or thoughts on the > matter. > > > > > > Thank you in advance!! > > > > > > Drew May > > > Conway, AR > > > '88 WB40 > > > > > > > > > --------------------------------- > > > You rock. That's why Blockbuster's offering you one month of > > Blockbuster Total Access, No Cost. > > > > > > |
