Sound deadening - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Sound deadening (/showthread.php?tid=6722) Pages: 1 2 |
Sound deadening - bubblerboy64 - 08-31-2008 18:04 Chuck, The two best things I did for myself and my bus were the air pedestal seats and the insulation of the engine, dog house and the generator compartment. I might suggest too that a lot of the engine noise comes up thru the floor and even from under the dash. I used a double layer of carpet matt and carpet plus the Dupree product where a glue down would be best. I highly recommend the stuff. I also made a carpet cover for over the out side of the dog house. It has the disadvantage of taking up space making it even more challenging to get into the drivers seat but my bus is "quiet". There is a little bit of a learning curve working with the stuff. The glue is somethin else. You better mean it when you strip the protective plastic off and touch it to the place you want it. If you think you can move or slide it once it is in contact even a fraction of an inch you will quickly finding that you can not. So when you go to apply it get it perfectly cut and positioned, go for a trial run with the protective plastic still on and when you peal the plastic off and place it, you better "mean it". John Heckman central Pa 1973 FC > > we suppplied the sound deader for the project \ > look at dupreeproducts.com pick out insulation from the tabs allthe > specs. are there > > stephen 77fc35 > dupreeproducts.com > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, cfsomers@ wrote: > > > > John > > > > I see that you used a specific material to insulate. I was not able to > > locate this. Would happen to have a website for this? > > > > Chuck Somers > > 81fcsb35 > > > > > > > Scott, What material did you use under the carpet? John > > >> > > >> I pulled up my carpet and put a layer of insulation under it. Not > > >> very scientific, but effective at deadening sound through the floor. > > >> > > >> Scott Forman > > >> 86 PT38 > > >> Memphis > > >> > > >> --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > >> wrote: > > >> > > > >> > My project this weekend was the installation of the insulation > > >> (Stephen > > >> > Bartles product). Any of you FC owners if you have not you > > >> should. I > > >> > believe that there is practically no sound out of the dog house > > >> area. > > >> > (In addition to the foam I have a heavy cover over the outside of > > >> the > > >> > dog house). The only area that seems to be transmitting sound is > > >> now > > >> > the floor area drivers side. Anyone have a way to handle that? I > > >> > certainly can live with what I have now but if there is more that > > >> can > > >> > be done why not. Not looking to make a Lexus out this thing but I > > >> > wouldn't mind getting just a bit closer. > > >> > > > >> > John Heckman > > >> > central Pa > > >> > 1973 FC > > >> > > > >> > > > > > > > > > > > > |
