Gen batt charging circuit diode - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Gen batt charging circuit diode (/showthread.php?tid=6829) Pages: 1 2 |
Gen batt charging circuit diode - Wilhelmus Schreurs - 06-09-2008 03:50 Hi Guys:
This ACRis it an electronic device, or is itmechanical? Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada ----- Original Message ---- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Sunday, June 8, 2008 5:56:39 PM Subject: [WanderlodgeForum] Re: Gen batt charging circuit diode Scott, Yes, I did install one on my '78. It is nice to have a visual indication that things are working, and the genie does seem to crank faster. I destroyed my original generator battery when I forgot to open the disconnect switch. The old diode or whatever let it drain to zero. The new ACR should prevent such mishaps as well. Gardner 78GC33 --- In "WanderlodgeForum%40yahoogroups.com", "thomas_sorrentino" > > Scott, > > I got mine at westmarine. Their part number 6917124 $77.99. One of > the better upgrades I've done. I think Gardner Yeaw did one also. > > Tom Sorrentino > 1987 PT38 > Bedford Hills, NY > > --- In "WanderlodgeForum%40yahoogroups.com", "Scott Forman" <sforman@> > wrote: > > > > What does this cost and where do I get it? > > > > Scott > > > > --- In "WanderlodgeForum%40yahoogroups.com", "thomas_sorrentino" > > > > > > > > Scott, > > > > > > I have to agree with what Shane said. I would just upgrade to the > > > Battery Link ACR. My generator has never cranked as fast as it > does > > > now either! I could probably find the old diode I took out, if > you > > > want it. > > > > > > Tom Sorrentino > > > 1987 PT38 > > > Bedford Hills, NY > > > > > > > > > --- In "WanderlodgeForum%40yahoogroups.com", "sfedeli3" <sfedeli3@> > > > wrote: > > > > > > > > Scott, > > > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea > Systems > > > > "Battery Link ACR". It works flawlessly- linking the two banks > > only > > > > when voltage is over 13.4 and separating them at levels below > > that. > > > It > > > > was literally a "drop-in" replacement- although I used a little > > > > heavier wire for those "just in case" moments. There is zero > > voltage > > > > drop- my generator has never cranked as fast as it does now! > > > > > > > > Shane Fedeli > > > > 85PT40 > > > > Hershey, PA > > > > > > > > --- In "WanderlodgeForum%40yahoogroups.com", "Scott Forman" > <sforman@> > > > > wrote: > > > > > > > > > > I need to replace the doide in the generator battery charging > > > circuit, > > > > > does anyone know the specifications for that item? > > > > > > > > > > Scott Forman > > > > > 86 PT38 > > > > > Memphis > > > > > > > > > > > > > > > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers. Gen batt charging circuit diode - sfedeli3 - 06-09-2008 04:00 It is a mechanical relay that is energized by an electronic circuit that senses voltage over 13.2. The relay is rated for 80 amps, but will shut off if a high-amp (OVER 150A) discharge happens. If one of your banks is low, you should bypass the unit with your "aux battery" switch on the dash. It should not be mounted in the battery compartment because of the hydrogen gas (BOOM). I placed mine in the old redi-line compartment of my PT, next to the Xantrex inverter/charger. --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Hi Guys: > This ACR is it an electronic device, or is it mechanical? > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Gardner Yeaw > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, June 8, 2008 5:56:39 PM > Subject: [WanderlodgeForum] Re: Gen batt charging circuit diode > > > Scott, > Yes, I did install one on my '78. It is nice to have a visual > indication that things are working, and the genie does seem to crank > faster. I destroyed my original generator battery when I forgot to > open the disconnect switch. The old diode or whatever let it drain > to zero. The new ACR should prevent such mishaps as well. > > Gardner > 78GC33 > > --- In WanderlodgeForum@ yahoogroups. com, "thomas_sorrentino" > > > > > Scott, > > > > I got mine at westmarine. Their part number 6917124 $77.99. One of > > the better upgrades I've done. I think Gardner Yeaw did one also. > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@> > > wrote: > > > > > > What does this cost and where do I get it? > > > > > > Scott > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "thomas_sorrentino" > > > > > > > > > > > Scott, > > > > > > > > I have to agree with what Shane said. I would just upgrade to > the > > > > Battery Link ACR. My generator has never cranked as fast as it > > does > > > > now either! I could probably find the old diode I took out, if > > you > > > > want it. > > > > > > > > Tom Sorrentino > > > > 1987 PT38 > > > > Bedford Hills, NY > > > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "sfedeli3" > <sfedeli3@> > > > > wrote: > > > > > > > > > > Scott, > > > > > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea > > Systems > > > > > "Battery Link ACR". It works flawlessly- linking the two > banks > > > only > > > > > when voltage is over 13.4 and separating them at levels > below > > > that. > > > > It > > > > > was literally a "drop-in" replacement- although I used a > little > > > > > heavier wire for those "just in case" moments. There is zero > > > voltage > > > > > drop- my generator has never cranked as fast as it does now! > > > > > > > > > > Shane Fedeli > > > > > 85PT40 > > > > > Hershey, PA > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" > > <sforman@> > > > > > wrote: > > > > > > > > > > > > I need to replace the doide in the generator battery > charging > > > > circuit, > > > > > > does anyone know the specifications for that item? > > > > > > > > > > > > Scott Forman > > > > > > 86 PT38 > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________________ > Looking for the perfect gift? Give the gift of Flickr! > > http://www.flickr.com/gift/ > Gen batt charging circuit diode - Wilhelmus Schreurs - 06-09-2008 09:04 Thanks Shane. Bill 84 FC 35 SB "$quanderlodge"Terrace, B.C. Canada ----- Original Message ---- From: sfedeli3 <sfedeli3@...> To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 9, 2008 9:00:26 AM Subject: [WanderlodgeForum] Re: Gen batt charging circuit diode It is a mechanical relay that is energized by an electronic circuit that senses voltage over 13.2. The relay is rated for 80 amps, but will shut off if a high-amp (OVER 150A) discharge happens. If one of your banks is low, you should bypass the unit with your "aux battery" switch on the dash. It should not be mounted in the battery compartment because of the hydrogen gas (BOOM). I placed mine in the old redi-line compartment of my PT, next to the Xantrex inverter/charger. --- In "WanderlodgeForum%40yahoogroups.com", Wilhelmus Schreurs > > Hi Guys: > This ACR is it an electronic device, or is it mechanical? > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: Gardner Yeaw > To: "WanderlodgeForum%40yahoogroups.com" > Sent: Sunday, June 8, 2008 5:56:39 PM > Subject: [WanderlodgeForum] Re: Gen batt charging circuit diode > > > Scott, > Yes, I did install one on my '78. It is nice to have a visual > indication that things are working, and the genie does seem to crank > faster. I destroyed my original generator battery when I forgot to > open the disconnect switch. The old diode or whatever let it drain > to zero. The new ACR should prevent such mishaps as well. > > Gardner > 78GC33 > > --- In WanderlodgeForum@ yahoogroups. com, "thomas_sorrentino" > > > > > Scott, > > > > I got mine at westmarine. Their part number 6917124 $77.99. One of > > the better upgrades I've done. I think Gardner Yeaw did one also. > > > > Tom Sorrentino > > 1987 PT38 > > Bedford Hills, NY > > > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@> > > wrote: > > > > > > What does this cost and where do I get it? > > > > > > Scott > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "thomas_sorrentino" > > > > > > > > > > > Scott, > > > > > > > > I have to agree with what Shane said. I would just upgrade to > the > > > > Battery Link ACR. My generator has never cranked as fast as it > > does > > > > now either! I could probably find the old diode I took out, if > > you > > > > want it. > > > > > > > > Tom Sorrentino > > > > 1987 PT38 > > > > Bedford Hills, NY > > > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "sfedeli3" > <sfedeli3@> > > > > wrote: > > > > > > > > > > Scott, > > > > > > > > > > Tom Sorrentino and I just replaced ours with a Blue Sea > > Systems > > > > > "Battery Link ACR". It works flawlessly- linking the two > banks > > > only > > > > > when voltage is over 13.4 and separating them at levels > below > > > that. > > > > It > > > > > was literally a "drop-in" replacement- although I used a > little > > > > > heavier wire for those "just in case" moments. There is zero > > > voltage > > > > > drop- my generator has never cranked as fast as it does now! > > > > > > > > > > Shane Fedeli > > > > > 85PT40 > > > > > Hershey, PA > > > > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" > > <sforman@> > > > > > wrote: > > > > > > > > > > > > I need to replace the doide in the generator battery > charging > > > > circuit, > > > > > > does anyone know the specifications for that item? > > > > > > > > > > > > Scott Forman > > > > > > 86 PT38 > > > > > > Memphis > > > > > > > > > > > > > > > > > > > > > > > > > ____________ _________ _________ _________ _________ _________ _ > Looking for the perfect gift? Give the gift of Flickr! > > http://www.flickr. com/gift/ > Ask a question on any topic and get answers from real people. Go to Yahoo! Answers. |
