ULSD Fuel additives - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: ULSD Fuel additives (/showthread.php?tid=6840) Pages: 1 2 |
ULSD Fuel additives - ronmarabito2002 - 06-10-2008 13:19 I use a product called "Clean Fire" and it is sold direct from the source. It is expensive, but is concentrate. One ounce treats 12 gallons of diesel, so it will last a long time. http://www.cleanfire.net/product/ It was recommended to me by Gulf States Filter company that I used to represent. Since we do not use our coaches all the time, and do quite a bit of stop and go, consider the oil change intervals for Severe use. On a Detroit 6V or 8V92, that is 6000 miles. You can adjust that upwards if the pattern in oil analysis indicates no damage would occur. If you added a by-pass filter, you could increase your oil change intervals significantly. R.E. (Ron) Marabito, Dallas, TX 92WB40 --- In WanderlodgeForum@yahoogroups.com, "Stephen Hare" <share74@...> wrote: > > What additive is used to replace the "old" Diesel Fuel? Something at a > truckstop? > > I have used Marvel Mystery Oil in Fuel and Crankcase for years, is this > something to use? > I just happen to have a gallon out in the shed, would be nice to use it!!! > In the automotive business, we would use Lucas Oil Stabilizer.. Good for > Diesel engines too!! > > > Stephen > > On Tue, Jun 10, 2008 at 6:45 PM, ronmarabito2002 > > > Suggest you use a good additive. I wasn't using and had high numbers > > in oil analysis, showing wear. Started additive and all is back to > > normal. > > > > R.E. (Ron) Marabito, Dallas, tX 92WB40 > > > > --- In WanderlodgeForum@yahoogroups.com > > "Stephen H" <share74@> wrote: > > > > > > Awhile back there was a lot of talk about the new ULSD fuel-- and our > > > Bird's. Some were in favor of using additives, and some said they would > > > just it plain and see what happens. Now time has passed. Has anyone > > > had any problems with the 'new' fuel? There were concerns about fuel > > > lines, seals, leaks, ect..Are we ok? When I do get a 'Bird, do I need > > > to just go fill up, or put something in prior? > > > Stephen H > > > Plant City, FL > > > > > > > > > > ULSD Fuel additives - Cris Wiedaman - 06-11-2008 00:42 I have 3 different types of fuel lines. one of them, an old ruber one simply swelled up and started spraying fuel after about 2 months the signs were obviouse, A cloth covered line seams to get harder over time faster then normal, the last line has 3 diferent plastics it is composed of and it is doing well. Chris Wiedamann, Wonderlodge want to be, My car runs on diesel, and other fuel though Cincinnati, OH The Shadow --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > I have been running it for at least 15,000 miles without additives and no problems.. knock on wood. I have changed the filters once in that time. > Leroy Eckert > 1990 WB-40 Royale > Dahlonega, GA > Smoke N Mirrors > > Stephen H <share74@...> wrote: Awhile back there was a lot of talk about the new ULSD fuel-- and our > Bird's. Some were in favor of using additives, and some said they would > just it plain and see what happens. Now time has passed. Has anyone > had any problems with the 'new' fuel? There were concerns about fuel > lines, seals, leaks, ect..Are we ok? When I do get a 'Bird, do I need > to just go fill up, or put something in prior? > Stephen H > Plant City, FL > ULSD Fuel additives - Gregory OConnor - 06-11-2008 01:21 I think the additives were a big sales gimick. Every fuelline or Ipump issue is now going to be blamed on new fuels. what was the reason prior to ulsd? I have always added ATF fluid to my diesel fuel when I think of it. I have driven over 20k with no issues in a 92 cummins N14 W/350,000 miles on the clock. I know of dirt haulers (old rigs) who have driven many more miles with no additives and no issues. I guess it cant hurt to buy and drop additives. if they burn like fuel you get back $5.00 per the gallon. I drop the used crankcase oil in the fuel tank (1g,oil/100g,fuel to 2/100) for a $50.00 refund. Dirty Filters were a warning sign I looked for with the ulsd additive promo campaigns. , I have only replaced three fuel filters in 200,000 miles they were replaced in a one week period. it seems as dirty filter issues happen in a series untill the tank contaminants are loaded in the filter. I dont treat fuel filters as a maintenance item and only replace at issue. 20 filters not bought at 36.15 per =$723.00 in my pocket. GregoryO'Connor --- In WanderlodgeForum@yahoogroups.com, "Cris Wiedaman" > > I have 3 different types of fuel lines. one of them, an old ruber > one simply swelled up and started spraying fuel after about 2 months > the signs were obviouse, A cloth covered line seams to get harder > over time faster then normal, the last line has 3 diferent plastics > it is composed of and it is doing well. > Chris Wiedamann, > Wonderlodge want to be, My car runs on diesel, and other fuel though > Cincinnati, OH > The Shadow > --- In WanderlodgeForum@yahoogroups.com, Leroy Eckert > > > > > I have been running it for at least 15,000 miles without additives > and no problems.. knock on wood. I have changed the filters once in > that time. > > Leroy Eckert > > 1990 WB-40 Royale > > Dahlonega, GA > > Smoke N Mirrors > > > > Stephen H <share74@> wrote: Awhile > back there was a lot of talk about the new ULSD fuel-- and our > > Bird's. Some were in favor of using additives, and some said they > would > > just it plain and see what happens. Now time has passed. Has > anyone > > had any problems with the 'new' fuel? There were concerns about > fuel > > lines, seals, leaks, ect..Are we ok? When I do get a 'Bird, do I > need > > to just go fill up, or put something in prior? > > Stephen H > > Plant City, FL > > > |
