Dash Air - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Dash Air (/showthread.php?tid=688) Pages: 1 2 |
Dash Air - Ralph - 06-27-2011 07:50 For the cooling you get out of a dash air, (front of body cool, but back sweats) it is generally not worth the monies to repair. Actually cheaper and a lot more comfy to run gen set and roof airs. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: "WILLIAM" Sender: WanderlodgeForum@yahoogroups.com Date: Mon, 27 Jun 2011 19:37:38 To: Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Dash air Anybody ever have any luck repairing (or activating a long unused) dash air conditioner on an SP36. The compressor belt was removed when I bought the coach. Chuck Harrison Akron, Ohio 90 SP36 ------------------------------------ Yahoo! Groups Links Dash Air - crissrace - 06-27-2011 23:36 --- In WanderlodgeForum@yahoogroups.com, "WILLIAM" > > Anybody ever have any luck repairing (or activating a long unused) dash air conditioner on an SP36. The compressor belt was removed when I > bought the coach. > > Chuck Harrison > Akron, Ohio > 90 SP36 I repaired my SP36 dash air and am glad I did. The key was the fact that a friend had some old R12 and gave it to me. The most expensive aspect of the repair will be the replacement R12. Call me if you want to talk about this repair. It wasn't that difficult. 412-303-3177 Bob Criss Pittsburgh, PA 90 SP36 > Dash Air - Dorn Hetzel - 06-27-2011 23:53 I was able to have my dash air rebuilt to run on 134. Â The expansion valve and dryer had to be replaced and some old hoses were replaced as well. Â The original compressor, evaporator and condensor work fine.
On Tue, Jun 28, 2011 at 7:36 AM, crissrace <"crissrace@yahoo.com"> wrote:
Dash Air - Dorn Hetzel - 06-27-2011 23:53 Whoops, Dorn Hetzel 77FC35 Hogansville, GA
On Tue, Jun 28, 2011 at 7:53 AM, Dorn Hetzel <"dorn@hetzel.org"> wrote:
I was able to have my dash air rebuilt to run on 134. Â The expansion valve and dryer had to be replaced and some old hoses were replaced as well. Â Dash Air - Ron Thompson - 06-28-2011 04:54
Dash Air - xz3kg7 - 06-29-2011 14:44 Chuck, I have an 87 FC35 and I fixed my chassis air a few years ago. I know I don't have the long hose runs like you, but I still had advice not to get mine going... However I have been very pleased, and have had virtually no issues since doing so. I put a new condensor (Red dot) on mine and converted to R134a. I think the condensor was around $600, and that was the most expensive single piece. It cost maybe $1200 total (did the work myself). That included a new compressor. I live in Texas, and it was not comfortable driving into the sun on a hot day running roof airs only. Not to mention the front unit puts out around 20-25,000 btu. On cooler days, or when the sun goes down the chassis air is easily enough to keep things cool without running the genset. Good luck, email me if you have questions about how I did mine. Alan Johnson 87FC35 --- In WanderlodgeForum@yahoogroups.com, "WILLIAM" > > Anybody ever have any luck repairing (or activating a long unused) dash air conditioner on an SP36. The compressor belt was removed when I > bought the coach. > > Chuck Harrison > Akron, Ohio > 90 SP36 > Dash Air - wl89spman - 07-11-2011 14:11 Chuck...my 89SP dash air has always worked(6yrs) for me, however on real hot days it doesnt cool very well. I probably should have it looked at too. BY the way could you tell me how your retarder lever works? With your sw. on can you push lever down and get braking with out using brake? good luck Ed Gardels 89SP Arlington Tx --- In WanderlodgeForum@yahoogroups.com, "Ralph" > > For the cooling you get out of a dash air, (front of body cool, but back sweats) it is generally not worth the monies to repair. Actually cheaper and a lot more comfy to run gen set and roof airs. > Safe travels, Ralph & Charolette Fullenwider > '84 FC35 "Ruff Diamond" > Duncan, Oklahoma > Sent via BlackBerry by AT&T > > -----Original Message----- > From: "WILLIAM" > Sender: WanderlodgeForum@yahoogroups.com > Date: Mon, 27 Jun 2011 19:37:38 > To: > Reply-To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Dash air > > Anybody ever have any luck repairing (or activating a long unused) dash air conditioner on an SP36. The compressor belt was removed when I > bought the coach. > > Chuck Harrison > Akron, Ohio > 90 SP36 > > > > ------------------------------------ > > Yahoo! Groups Links > |
