Suspension dump light won't go out - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Suspension dump light won't go out (/showthread.php?tid=7344) Pages: 1 2 |
Suspension dump light won't go out - Curt Sprenger - 11-08-2008 15:43 Mike, Jim is absolutely correct. I had this problem for almost 4 year. I changed out the 3 pressure switches, all 3 at the same time. The dash light is treating me with respect...so far...it's on when it should be on and COMPLETELY OUT when the system is aried up. Cheap fix. On Sat, Nov 8, 2008 at 5:27 PM, jim riordan <"jqrjr@yahoo.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA Suspension dump light won't go out - Gregory OConnor - 11-09-2008 04:56 Curt, across the tracks here we only fix the part that broke. then ebay that removed. MikeB, I have pdf's of 43 prints RobR and I gathered up last year when immigration granted him access to the States (Rob bring a bus pin'ata to Q this year). Cant seem to change the file names to that more descriptive??? I wanted to send them to you with a easy lookup format. it would be cool to post one of my pdf's and weed thru the interpertation for forum members not familiar with how to read the prints. I wanted to send it out like KurtH did with the s60 files but fear that half the folks could not read them. Even Tom2Shoes who can read them, would only use the 'review of prints' to further convince himself to take it to a shop. How do I send the 92 DDacII master chassis file? this shows the dumplight relay circuitry on my 94pt wich seems to differ from that of the 86-88pt. Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > Mike, > > Jim is absolutely correct. I had this problem for almost 4 year. I changed > out the 3 pressure switches, all 3 at the same time. The dash light is > treating me with respect...so far...it's on when it should be on and > COMPLETELY OUT when the system is aried up. Cheap fix. > > On Sat, Nov 8, 2008 at 5:27 PM, jim riordan > > > Mike, > > > > Just had a simmilar problem. There are three pressure switches on my coach, > > that activate that light. I found after trouble shhoting that the tag axle > > pressure switch was bad. We did the trouble shooting by disconnecting the > > leads to the switch. high up middle of coach near tag. it was a pain but we > > got it figured out. BB had the parts > > > > jim riordan > > 88WBWL XXV > > stuart, fl. > > > > *mbulriss <mbulriss@...>* wrote: > > > > OK, the title sums it up: the suspension dump light on the dash does > > not go out. Always seemed a little slow going off after the tag axle > > aired up, but now it just stays on. > > > > All suspension air bags *are* fully aired up. Checked the Clippard > > valves in the front load center on advice from Ralph - no leaks found. > > Crawled around under the rear listening for air leaks and checking > > the air bags. No leaks heard, but of course that for sure doesn't > > mean there aren't any, based on older ears! > > > > Any ideas on what to check next? > > > > Thanks, > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
