Brighter tail lights - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Brighter tail lights (/showthread.php?tid=803) Pages: 1 2 |
Brighter tail lights - Scott - 06-09-2005 02:37 George, watch those pot pies (loaded with sodium..LOL listen to me) I recently finished the insulation of my genny compartment (thanks to Stephen Birtles) and I had lots of foil tape left over works wonderful cut it to fit..then take the back off...EZ Scott 86FC35 "RUBY" Murrells Inlet SC (still next to heaven) --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > My old 81 FC didn't have very bright tail/brake lights and > I'd read here about using aluminum foil (chicken pot pie) > dishes put behind the bulbs to make a reflector to brighten > them up. > Do you have any idea how hard it is to find aluminum > plates in a microwave world? I ate a bunch of pot pies > in search of the elusive metal plates. ;o) I finally > learned how to peek into the packaging to see if the plate > was the right one or not before I bought them (and had to eat it). > Armed with 4 new clean plates, I cleaned up the tail > light lenses, trimmed the pie plates and installed them. > Yes, it did brighten them up, but it greatly reduced the > lit surface area. Only part of the red lens lit up. It looked funny. > So, I made a visit to my local glitzy auto parts store > (the one with the yard signs in front advertising a deal > on cashews). Cashews in a parts store? > I found a roll of chrome tape. Wooohooo. I took the lenses > off, cleaned everything again and installed the "custom, cut-to-fit > chrome tape" and it worked great. > The entire red lens now lights up brightly. It worked so good > I did the front turn signal lenses as well. > Brighten up your life for only a few bucks. ;o) > > George Witt > 81 FC 35 > Lincoln, Nebraska Brighter tail lights - Chet Geist - 06-09-2005 02:43 Another solution might be to put on new LED tail lights. I put two on the rear of mine and what a difference. They seem to love the low voltage. Got them from Blue Bird school bus dealer at $47.00 each. Not a perfect fit, but within 1/4" of old holes. Also neat to see the LED's light up before the old filament type bulbs on the lights above them. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of Tom Warner Sent: Thursday, June 09, 2005 8:57 AM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Brighter tail lights Guys those taillights on the FC models at least are the very same ones that are used in school buses . If they are dim its because of low voltage. They passed Federal standards when they were new. I ran new larger gauge wires to mine and that corrected the problem. Same with the headlights. Tom 1982 FC35 Vernon Center,NY At 06:15 AM 6/9/2005 -0700, you wrote: >George >You shoulda put 6 volt bulbs in, >That's what the parts man at the cashew selling parts house would tell you! >Fred & Jeanne Hulse >Morristown Arizona >1997 Wanderlodge PT41 > > > > > > >Yahoo! Groups Links > > > > ---------------------------------------------------------------------------- -- Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] Brighter tail lights - Jeff Miller - 06-09-2005 02:56 My thoughts on the <'86 taillights. They were made to pass the standards, based on proper voltage, and new lenses. The base was originally black, BlueBird painted (primed) the bus with the metal base on the bus because there was no reflector so painting it made masking easier. Adding a reflector does improve the light output, in essence a candle has one candlepower, a candle in front of a flat mirror has two candlepower. You are increasing the light output with a reflector. However, there was no reflector because the optics of the lense collect enough light from the bulb, ... when new and properly powered. The optics (pillow and Freznel for those interested) degrade over time, the plastic degrades and loses some of its qualities over time and exposure to the elements. The voltage is also not what is probably should be, the lights passed DOT standards on a bench-test in a lab, not on a Wanderlodge. Buy new lights. The lenses are pretty cheap and readily available (Red, Amber, and Clear) from Truck-Lite and others. If the socket isn't reliable anymore you can buy the entire fixture. New lenses work much better and even look better, even cleaning the dust out of the light helps. Improving the voltage to the light is a little complicated, long wiring runs with many old connections caused this. A new headlamp switch will benefit many old coaches, readily available at NAPA (sorry, I don't have the number at-hand). Be ready to replace any of the connectors to the switch that don't look good or have good retention force, you will likely find at least one heat-damaged wire. A good solution is to add a relay in the Left Rear overhead to power the taillamps from a local power source there, pretty simple conversion if you can do some minor wiring. It has to be simple, Gary has done it ;~) This gives better voltage and current available so that a towed vehicle will actually be visible at night, ... kind of helpful. I've also had good results from replacing the light assemblies with new LED lights, from my local BB dealer for around $35/ea. The lower current requirement of the LED light greatly reduces the voltage drop across the wiring and connections (and switch), and even leaves more for the towed-vehicle wiring. - Jeff Miller Brighter tail lights - Jeff Miller - 06-09-2005 03:05 On mine I've replaced all four with LED. When wiring them, since the original setup only used the lower two for tail, I ran this wire up to the upper lights so that I have four running lights in the rear instead of two. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Chet Geist" wrote: > Another solution might be to put on new LED tail lights. I put two on the > rear of mine and what a difference. They seem to love the low voltage. Got > them from Blue Bird school bus dealer at $47.00 each. Not a perfect fit, > but within 1/4" of old holes. Also neat to see the LED's light up before > the old filament type bulbs on the lights above them. > > Chet Geist > 1981 FC33, Austin, Texas] Brighter tail lights - John - 06-09-2005 09:01 Shame on you George, you didn't look at my web site, that is exactly what I used, but i found the tape at Lowes, all the same though, see; http://www.pbase.com/image/25297168 "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" SEE THE OLD COACH AT: http://www.pbase.com/image/26052733 HOPKINS, SOUTH CAROLINA /////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> wrote: > My old 81 FC didn't have very bright tail/brake lights and > I'd read here about using aluminum foil (chicken pot pie) > dishes put behind the bulbs to make a reflector to brighten > them up. > Do you have any idea how hard it is to find aluminum > plates in a microwave world? I ate a bunch of pot pies > in search of the elusive metal plates. ;o) I finally > learned how to peek into the packaging to see if the plate > was the right one or not before I bought them (and had to eat it). > Armed with 4 new clean plates, I cleaned up the tail > light lenses, trimmed the pie plates and installed them. > Yes, it did brighten them up, but it greatly reduced the > lit surface area. Only part of the red lens lit up. It looked funny. > So, I made a visit to my local glitzy auto parts store > (the one with the yard signs in front advertising a deal > on cashews). Cashews in a parts store? > I found a roll of chrome tape. Wooohooo. I took the lenses > off, cleaned everything again and installed the "custom, cut-to-fit > chrome tape" and it worked great. > The entire red lens now lights up brightly. It worked so good > I did the front turn signal lenses as well. > Brighten up your life for only a few bucks. ;o) > > George Witt > 81 FC 35 > Lincoln, Nebraska Brighter tail lights - Jack & Donna Smith - 06-09-2005 09:49 George:... What I did was to visit the local 99¢ store and buy a number of ladies make up compacte.. I removed the mirrors and DoubleStickyTape/Silaconed them behind the Tail/Turn/stop light bulbs.. worked great!!! FOR THE TOAD: In addition to the Towed lights, I bought a reciver light from H.Freight, $4 or so, cut the connector off and soldered both filiments togather, and wired it into the Toad light scheme.. This ome is vrey bright and different so it gets attention!! Jack Smith 1973FC31 Near "Shakey Acres" in SoCal. ============================================================= --- In WanderlodgeForum@yahoogroups.com, "John" > Shame on you George, you didn't look at my web site, that is exactly > what I used, but i found the tape at Lowes, all the same though, see; > > http://www.pbase.com/image/25297168 > > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" > SEE THE OLD COACH AT: > http://www.pbase.com/image/26052733 > HOPKINS, SOUTH CAROLINA > > /////////////////////////////////////////////////////// > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > wrote: > > My old 81 FC didn't have very bright tail/brake lights and > > I'd read here about using aluminum foil (chicken pot pie) > > dishes put behind the bulbs to make a reflector to brighten > > them up. > > Do you have any idea how hard it is to find aluminum > > plates in a microwave world? I ate a bunch of pot pies > > in search of the elusive metal plates. ;o) I finally > > learned how to peek into the packaging to see if the plate > > was the right one or not before I bought them (and had to eat it). > > Armed with 4 new clean plates, I cleaned up the tail > > light lenses, trimmed the pie plates and installed them. > > Yes, it did brighten them up, but it greatly reduced the > > lit surface area. Only part of the red lens lit up. It looked > funny. > > So, I made a visit to my local glitzy auto parts store > > (the one with the yard signs in front advertising a deal > > on cashews). Cashews in a parts store? > > I found a roll of chrome tape. Wooohooo. I took the lenses > > off, cleaned everything again and installed the "custom, cut-to-fit > > chrome tape" and it worked great. > > The entire red lens now lights up brightly. It worked so good > > I did the front turn signal lenses as well. > > Brighten up your life for only a few bucks. ;o) > > > > George Witt > > 81 FC 35 > > Lincoln, Nebraska Brighter tail lights - Blair - 06-09-2005 12:26 Hi Jack, Re: tail lights....forget all that tape and shinny AL surfaces...When at Randy's this last winter, I had the same problem with the dim rear lights. A couple of the housings where either cracked or broken and we did surgery with some glass and resin.......The "reflective" area of the housing was thoughly cleaned and prepped and painted with this ultra shinny CR paint that dried to a mirror finish. Looks like a factory mirror on these new molded headlight assemblies....and the lights are bright!!!! Blair At 02:49 PM 6/9/2005, you wrote: >George:... What I did was to visit the local 99¢ store and buy a >number of ladies make up compacte.. I removed the mirrors and >DoubleStickyTape/Silaconed them behind the Tail/Turn/stop light >bulbs.. worked great!!! >FOR THE TOAD: In addition to the Towed lights, I bought a reciver >light from H.Freight, $4 or so, cut the connector off and soldered >both filiments togather, and wired it into the Toad light scheme.. >This ome is vrey bright and different so it gets attention!! >Jack Smith >1973FC31 >Near "Shakey Acres" in SoCal. > >============================================================= > >--- In WanderlodgeForum@yahoogroups.com, "John" > > Shame on you George, you didn't look at my web site, that is exactly > > what I used, but i found the tape at Lowes, all the same though, see; > > > > <http://www.pbase.com/image/25297168>http://www.pbase.com/image/25297168 > > > > > > "REMEMBER SEPTEMBER 11, 2001" > > John Finn > > '82 35FCRB > > BLUEBIRD WANDERLODGE > > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > > GO TO; > > <http://www.pbase.com/image/24977457>http://www.pbase.com/image/24977457 > > '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" > > SEE THE OLD COACH AT: > > <http://www.pbase.com/image/26052733>http://www.pbase.com/image/26052733 > > HOPKINS, SOUTH CAROLINA > > > > /////////////////////////////////////////////////////// > > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > > wrote: > > > My old 81 FC didn't have very bright tail/brake lights and > > > I'd read here about using aluminum foil (chicken pot pie) > > > dishes put behind the bulbs to make a reflector to brighten > > > them up. > > > Do you have any idea how hard it is to find aluminum > > > plates in a microwave world? I ate a bunch of pot pies > > > in search of the elusive metal plates. ;o) I finally > > > learned how to peek into the packaging to see if the plate > > > was the right one or not before I bought them (and had to eat it). > > > Armed with 4 new clean plates, I cleaned up the tail > > > light lenses, trimmed the pie plates and installed them. > > > Yes, it did brighten them up, but it greatly reduced the > > > lit surface area. Only part of the red lens lit up. It looked > > funny. > > > So, I made a visit to my local glitzy auto parts store > > > (the one with the yard signs in front advertising a deal > > > on cashews). Cashews in a parts store? > > > I found a roll of chrome tape. Wooohooo. I took the lenses > > > off, cleaned everything again and installed the "custom, cut-to-fit > > > chrome tape" and it worked great. > > > The entire red lens now lights up brightly. It worked so good > > > I did the front turn signal lenses as well. > > > Brighten up your life for only a few bucks. ;o) > > > > > > George Witt > > > 81 FC 35 > > > Lincoln, Nebraska > > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] Brighter tail lights - randydupree - 06-09-2005 13:05 they did come out good,painting them with oklahoma chrome paint! randydupree93wb ----- Original Message ----- From: Blair To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 09, 2005 8:26 PM Subject: Re: [WanderlodgeForum] Re: Brighter tail lights Hi Jack, Re: tail lights....forget all that tape and shinny AL surfaces...When at Randy's this last winter, I had the same problem with the dim rear lights. A couple of the housings where either cracked or broken and we did surgery with some glass and resin.......The "reflective" area of the housing was thoughly cleaned and prepped and painted with this ultra shinny CR paint that dried to a mirror finish. Looks like a factory mirror on these new molded headlight assemblies....and the lights are bright!!!! Blair At 02:49 PM 6/9/2005, you wrote: >George:... What I did was to visit the local 99¢ store and buy a >number of ladies make up compacte.. I removed the mirrors and >DoubleStickyTape/Silaconed them behind the Tail/Turn/stop light >bulbs.. worked great!!! >FOR THE TOAD: In addition to the Towed lights, I bought a reciver >light from H.Freight, $4 or so, cut the connector off and soldered >both filiments togather, and wired it into the Toad light scheme.. >This ome is vrey bright and different so it gets attention!! >Jack Smith >1973FC31 >Near "Shakey Acres" in SoCal. > >============================================================= > >--- In WanderlodgeForum@yahoogroups.com, "John" > > Shame on you George, you didn't look at my web site, that is exactly > > what I used, but i found the tape at Lowes, all the same though, see; > > > > <http://www.pbase.com/image/25297168>http://www.pbase.com/image/25297168 > > > > > > "REMEMBER SEPTEMBER 11, 2001" > > John Finn > > '82 35FCRB > > BLUEBIRD WANDERLODGE > > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > > GO TO; > > <http://www.pbase.com/image/24977457>http://www.pbase.com/image/24977457 > > '66 SUPERIOR / IH 392 GAS V8 32' PUSHER "FOR SALE" > > SEE THE OLD COACH AT: > > <http://www.pbase.com/image/26052733>http://www.pbase.com/image/26052733 > > HOPKINS, SOUTH CAROLINA > > > > /////////////////////////////////////////////////////// > > > > --- In WanderlodgeForum@yahoogroups.com, "mrdonut12" <mrdonut12@y...> > > wrote: > > > My old 81 FC didn't have very bright tail/brake lights and > > > I'd read here about using aluminum foil (chicken pot pie) > > > dishes put behind the bulbs to make a reflector to brighten > > > them up. > > > Do you have any idea how hard it is to find aluminum > > > plates in a microwave world? I ate a bunch of pot pies > > > in search of the elusive metal plates. ;o) I finally > > > learned how to peek into the packaging to see if the plate > > > was the right one or not before I bought them (and had to eat it). > > > Armed with 4 new clean plates, I cleaned up the tail > > > light lenses, trimmed the pie plates and installed them. > > > Yes, it did brighten them up, but it greatly reduced the > > > lit surface area. Only part of the red lens lit up. It looked > > funny. > > > So, I made a visit to my local glitzy auto parts store > > > (the one with the yard signs in front advertising a deal > > > on cashews). Cashews in a parts store? > > > I found a roll of chrome tape. Wooohooo. I took the lenses > > > off, cleaned everything again and installed the "custom, cut-to-fit > > > chrome tape" and it worked great. > > > The entire red lens now lights up brightly. It worked so good > > > I did the front turn signal lenses as well. > > > Brighten up your life for only a few bucks. ;o) > > > > > > George Witt > > > 81 FC 35 > > > Lincoln, Nebraska > > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
