New battery time - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: New battery time (/showthread.php?tid=8367) Pages: 1 2 |
New battery time - GARY MINKER - 08-19-2009 10:29
New battery time - Joyce and Richard Hayden - 08-20-2009 07:03 Gary,
The problem with 13.7 volt chargers is that your batteries will not ever get a full charge. That will cause them to fail prematurely. Shane is correct.
New battery time - Wilhelmus Schreurs - 08-20-2009 16:50 Hi there Richard.
About the batteries. this is not so. each type of battery has it's own charge rate. The lead acid ones are in the 14.4 volt range, but he AGM's I believe are in 13.7 range. Not quite sure, but I know they are not the same Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada All new Yahoo! Mail - Get a sneak peak at messages with a handy reading pane. New battery time - sfedeli3 - 08-21-2009 01:10 Good point Bill. I forgot to make that distinction. The better choice would be to get a charger that can be programmed for various types, rather than a static voltage power supply. Especially with AGM's, the unit will need to shut down automatically when the batteries are full, or he'll ruin them. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > Hi there Richard. > > About the batteries. this is not so. each type of battery has it's own charge rate. > The lead acid ones are in the 14.4 volt range, but he AGM's I believe are in 13.7 range. > Not quite sure, but I know they are not the same > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > __________________________________________________________________ > Looking for the perfect gift? Give the gift of Flickr! > > http://www.flickr.com/gift/ > New battery time - rjmackillop - 08-21-2009 01:48 Hi, AGM and wet have the same charge characteristics. Only Gel is different. Obviously you can't mix any - really should have same brand and age in battery banks. See:http://www.windsun.com/Batteries/Battery_FAQ.htm#AGM, or Absorbed Glass Mat Batteries > > Good point Bill. I forgot to make that distinction. The better choice would be to get a charger that can be programmed for various types, rather than a static voltage power supply. Especially with AGM's, the unit will need to shut down automatically when the batteries are full, or he'll ruin them. > > Shane Fedeli > 85PT40 > Hershey, PA > > --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs wrote: > > > > Hi there Richard. > > > > About the batteries. this is not so. each type of battery has it's own charge rate. > > The lead acid ones are in the 14.4 volt range, but he AGM's I believe are in 13.7 range. > > Not quite sure, but I know they are not the same > > > > Bill 84 FC 35 SB "$quanderlodge" > > Terrace, B.C. Canada > > > > > > __________________________________________________________________ > > Looking for the perfect gift? Give the gift of Flickr! > > > > http://www.flickr.com/gift/ > > > New battery time - GARY MINKER - 08-27-2009 01:05
New battery time - rjmackillop - 08-27-2009 02:07 Great battery site: http://www.eastpenn-deka.com/assets/base/0139.pdf Flooded/gel/AGM --- In WanderlodgeForum@yahoogroups.com, GARY MINKER > > Driving is the equalizing charge. If you drive once a month, you equalize the batteries. Every battery is slightly different by a few tenths of a volt. If you call 5 years short life, then you would be right but I am ballanced out and get 5 or more years out of the batteries with this trick. And actually at the battery terminals it is 13.9 volts. > > --- On Thu, 8/20/09, Joyce and Richard Hayden > > From: Joyce and Richard Hayden > Subject: Re: [WanderlodgeForum] Re: New battery time > To: WanderlodgeForum@yahoogroups.com > Date: Thursday, August 20, 2009, 3:03 PM > > > > > > > > > > > > > > > > > Gary, > The problem with 13.7 volt chargers is that your batteries will not ever > get a full charge. That will cause them to fail prematurely. Shane > is correct. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > ----- Original Message ----- > From: GARY > MINKER > To: WanderlodgeForum@ yahoogroups. com > > Sent: Wednesday, August 19, 2009 3:09 > PM > Subject: Re: [WanderlodgeForum] Re: New > battery time > > > > > > > > After years of debate, I got rid of all chargers and went > to fixed highly regulated switching converters at 13.7 VDC. I let > the engine float/equalize the batteries. The Sonnenschein AGM's > love it and I have no problems. I have 120 amps of converters that > never boil a battery and at 13.7 the charge is good. > > --- On > Thu, 8/13/09, sfedeli3 <sfedeli3@comcast. net> > wrote: > > > From: > sfedeli3 <sfedeli3@comcast. net> > Subject: > [WanderlodgeForum] Re: New battery time > To: > WanderlodgeForum@ yahoogroups. com > Date: Thursday, August > 13, 2009, 9:40 AM > > > > > Hi Jerry, > > Don't waste your $$ on the IOTA's. They are not > capable of a full bulk charge or equalization (despite what the > literature says). You need a charger that is temperature- compensating > and capable of at least 15.5 volts when equalizing. I'd spend the > extra $$ and get a Truecharge2 or even a remanned ProSine 2.0. > Wherever you mount it, make sure that it's dry and cool. Mine's been > working great for 4 years. Check out this link- [http://www.xantrex. com/web/id/ 256/p/1/pt/ > 7/product. asp]. > > Shane Fedeli > 85PT40 > Hershey, > PA > > --- In WanderlodgeForum@ > yahoogroups. com, "jburgessx2" > wrote: > > > > We full time but rarely dry camp. So, I'm > thinking 12v deep cycle should be okay. Also, I'm replacing the > boilers with Iota DLS-45 chargers. Thoughts? Jerry 85 PT40 > > > > > > > should be fine. Also, I'm replacing my boilers with > Iota DLS-45 chargers. > > > > > A > > > |
