87 FC 35 Generator?????? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: 87 FC 35 Generator?????? (/showthread.php?tid=8429) |
87 FC 35 Generator?????? - gregory O - 09-26-2009 03:14 maybe the linkage on the fuel solenoid is not letting the electromagnetic stroke of the solenoid go to full open????? there is more force, thus more amp draw required to open the selonoid then hold it open. Recently some rich friends had an overheating selonoid problem on their new 97EcknfloorPT. Lucas, The SouthWest guru of Gensets diagnosed the issue and it made perfect sence. Greg of Tim&Greg 94ptca --- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@...> wrote: > > STILL WORKING ON GEN GOT SERVICE MANUAL CAN MANUALLY WORK FUEL SOLENOD WHEN UNHOOKED AND ENGINE RUNS DOES ANYONE KNOW HOW MANY AMPS IT PULLS > TKS BOB IN KY STILL HUNTING > 87 FC 35 Generator?????? - richardgideon - 09-27-2009 04:08 I recently replaced the fuel shutoff solenoid on my Onan DKD. The instruction sheet with the new solenoid assembly indicated that when the governor linkage on the Onan (Kubota Diesel) is wide open against the stop, the electric solenoid linkage should be adjusted so that the solenoid is "pulled in" all the way. Linkage adjustment appears to be critical and could result in chattering or maybe over heating the solenoid. Dick Gideon 1989 FC35 8.0 DKD Onan Rolla, MO --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > maybe the linkage on the fuel solenoid is not letting the electromagnetic stroke of the solenoid go to full open????? there is more force, thus more amp draw required to open the selonoid then hold it open. Recently some rich friends had an overheating selonoid problem on their new 97EcknfloorPT. Lucas, The SouthWest guru of Gensets diagnosed the issue and it made perfect sence. > Greg of Tim&Greg > 94ptca > > > --- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@> wrote: > > > > STILL WORKING ON GEN GOT SERVICE MANUAL CAN MANUALLY WORK FUEL SOLENOD WHEN UNHOOKED AND ENGINE RUNS DOES ANYONE KNOW HOW MANY AMPS IT PULLS > > TKS BOB IN KY STILL HUNTING > > > 87 FC 35 Generator?????? - TimV - 09-27-2009 07:36 Then maybe a test of the linkage causing the amp draw would be to disconnect the linkage then check to see if operating the solenoid will draw the 40 amps it does now. then, operate the genset with the shut of linkage opened manualy, ;selonoid removed from setting but connected to + and- ;; wait to see if the solenoid will lose its signal disconnected running then repeat manualy open the shutoff linkage , remove the solenoid completly, put a test light on the input to the solenoid, run the gen set and wait for the signal to disapear. these test should prove issue. Novice mechanics replace clutches that were only out of adjustment and assumed that the replacement of the clutch was the fix. 40 amp might be the result of a bad solenoid , a hard chore, weak connection etc Greg --- In WanderlodgeForum@yahoogroups.com, "richardgideon" > > I recently replaced the fuel shutoff solenoid on my Onan DKD. The instruction sheet with the new solenoid assembly indicated that when the governor linkage on the Onan (Kubota Diesel) is wide open against the stop, the electric solenoid linkage should be adjusted so that the solenoid is "pulled in" all the way. Linkage adjustment appears to be critical and could result in chattering or maybe over heating the solenoid. > > Dick Gideon > 1989 FC35 > 8.0 DKD Onan > Rolla, MO > > --- In WanderlodgeForum@yahoogroups.com, "gregory O" > > > > maybe the linkage on the fuel solenoid is not letting the electromagnetic stroke of the solenoid go to full open????? there is more force, thus more amp draw required to open the selonoid then hold it open. Recently some rich friends had an overheating selonoid problem on their new 97EcknfloorPT. Lucas, The SouthWest guru of Gensets diagnosed the issue and it made perfect sence. > > Greg of Tim&Greg > > 94ptca > > > > > > --- In WanderlodgeForum@yahoogroups.com, "sc310c" <sc310c@> wrote: > > > > > > STILL WORKING ON GEN GOT SERVICE MANUAL CAN MANUALLY WORK FUEL SOLENOD WHEN UNHOOKED AND ENGINE RUNS DOES ANYONE KNOW HOW MANY AMPS IT PULLS > > > TKS BOB IN KY STILL HUNTING > > > > > > 87 FC 35 Generator?????? - sc310c - 06-23-2010 06:55 does anyone know a parts source for the injector pump parts tks bob maloney 87 fc 35 in ky 87 FC 35 Generator?????? - Ken Doyle - 06-23-2010 07:42 Try a Massy Ferguson tractor dealer. MF uses the Perkins engine Project Ken Doyle ConServe PO Box 35245 Richmond, VA 23235 direct: 301-908-5735 fax: 804-725-2982 From: does anyone know a parts source for the injector pump parts tks bob maloney 87 fc 35 in ky 87 FC 35 Generator?????? - mbulriss - 06-23-2010 10:27 In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Ken Doyle" wrote: > > Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their > tractors. You will need the Perkins numbers (lots of numbers) to locate the > proper parts. > > > > > > Project success is in the details > > > > Ken Doyle > > ConServe > > PO Box 35245 > > Richmond, VA 23235 > > direct: 301-908-5735 > > fax: 804-725-2982 > > ken.hvac-conserve@... > > > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c > Sent: Wednesday, June 23, 2010 2:56 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] 87 FC 35 Generator?????? > > > > > > does anyone know a parts source for the injector pump parts > tks bob maloney 87 fc 35 in ky > 87 FC 35 Generator?????? - cape0001 - 06-23-2010 11:21 why not try perkins Stephen 97bmc 37 --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...> wrote: > > In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also. > > Mike Bulriss > 1991 WB40 "Texas Minivan" > San Antonio, TX > > > --- In WanderlodgeForum@yahoogroups.com, "Ken Doyle" wrote: > > > > Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their > > tractors. You will need the Perkins numbers (lots of numbers) to locate the > > proper parts. > > > > > > > > > > > > Project success is in the details > > > > > > > > Ken Doyle > > > > ConServe > > > > PO Box 35245 > > > > Richmond, VA 23235 > > > > direct: 301-908-5735 > > > > fax: 804-725-2982 > > > > ken.hvac-conserve@ > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c > > Sent: Wednesday, June 23, 2010 2:56 PM > > To: WanderlodgeForum@yahoogroups.com > > Subject: [WanderlodgeForum] 87 FC 35 Generator?????? > > > > > > > > > > > > does anyone know a parts source for the injector pump parts > > tks bob maloney 87 fc 35 in ky > > > 87 FC 35 Generator?????? - Glenn Stoner - 06-23-2010 11:36 Whenever i need parts i call up these folks- they usually hook me up. It's been a while though... Industrial Diesel http://www.IndustrialDiesel.net (800) 323-3659 8705 Harmon Fort Worth, Texas 76117 --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > why not try perkins > Stephen 97bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ken Doyle" wrote: > > > > > > Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their > > > tractors. You will need the Perkins numbers (lots of numbers) to locate the > > > proper parts. > > > > > > > > > > > > > > > > > > Project success is in the details > > > > > > > > > > > > Ken Doyle > > > > > > ConServe > > > > > > PO Box 35245 > > > > > > Richmond, VA 23235 > > > > > > direct: 301-908-5735 > > > > > > fax: 804-725-2982 > > > > > > ken.hvac-conserve@ > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c > > > Sent: Wednesday, June 23, 2010 2:56 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] 87 FC 35 Generator?????? > > > > > > > > > > > > > > > > > > does anyone know a parts source for the injector pump parts > > > tks bob maloney 87 fc 35 in ky > > > > > > 87 FC 35 Generator?????? - pattypape - 06-24-2010 02:23 It is an Onan/ Kubota Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > why not try perkins > Stephen 97bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ken Doyle" wrote: > > > > > > Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their > > > tractors. You will need the Perkins numbers (lots of numbers) to locate the > > > proper parts. > > > > > > > > > > > > > > > > > > Project success is in the details > > > > > > > > > > > > Ken Doyle > > > > > > ConServe > > > > > > PO Box 35245 > > > > > > Richmond, VA 23235 > > > > > > direct: 301-908-5735 > > > > > > fax: 804-725-2982 > > > > > > ken.hvac-conserve@ > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c > > > Sent: Wednesday, June 23, 2010 2:56 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] 87 FC 35 Generator?????? > > > > > > > > > > > > > > > > > > does anyone know a parts source for the injector pump parts > > > tks bob maloney 87 fc 35 in ky > > > > > > 87 FC 35 Generator?????? - pattypape - 06-24-2010 02:25 It is an Onan/ Kubota Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "cape0001" <sbirtles@...> wrote: > > why not try perkins > Stephen 97bmc 37 > > --- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@> wrote: > > > > In addition to Massey Ferguson, try a Bobcat dealer as they used Perkins also. > > > > Mike Bulriss > > 1991 WB40 "Texas Minivan" > > San Antonio, TX > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Ken Doyle" wrote: > > > > > > Try a Massy Ferguson tractor dealer. MF uses the Perkins engine in their > > > tractors. You will need the Perkins numbers (lots of numbers) to locate the > > > proper parts. > > > > > > > > > > > > > > > > > > Project success is in the details > > > > > > > > > > > > Ken Doyle > > > > > > ConServe > > > > > > PO Box 35245 > > > > > > Richmond, VA 23235 > > > > > > direct: 301-908-5735 > > > > > > fax: 804-725-2982 > > > > > > ken.hvac-conserve@ > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of sc310c > > > Sent: Wednesday, June 23, 2010 2:56 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: [WanderlodgeForum] 87 FC 35 Generator?????? > > > > > > > > > > > > > > > > > > does anyone know a parts source for the injector pump parts > > > tks bob maloney 87 fc 35 in ky > > > > > > |
