diesel/gasser differences - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: diesel/gasser differences (/showthread.php?tid=8477) Pages: 1 2 |
diesel/gasser differences - jackcj7 - 10-02-2009 15:19 I have the Burgendy & Silver 1973FC31 that is in Vintage Birds. It has a 391A Ford with a MT40 Allison, that has a retarder. It has juce brakes, and is overall a very simple Bird, compared to the newer ones. No air system, and that troublesom Air Step. I have seen Sporlian valves mentioned, but my coach has none. To fill the Water tank, I simply connect the hose to a fitting that goes right into the tank.. It originally had 30 amp shore power, but I upgraded to 50 amp. It also came with steel split rims, and 9.00X19" tires. Now it rides on 11X22.5 Toyos and some very pretty Accuride wheels. One thing to watch for on an older vehicle is the rotted rubber water hoses, including that feed to the chassis heaters, and Hot Water Heater. (I bypassed these...Here in Arnold-Land, the last thing I need is more heat)!! The little hoses around the engine water pump should be replaced also, as they rot after time.. In a gas rig, you dont have to worry about Diesel Fuel "Going Bad", no Racor Filters, just a simple gas filter like I have in my Jeep.. No worry about what Anti-Freez to use or not to mix. I buy whatever is on sale at WallyWorld.....If I should replace the Shock Absorbers, I understand a set can be bought at Pep Boys. I get 5.0 to 6.0 mpg on the road, and I always tow my Jeep. An oil change is some 9 quarts, much less that the 3208, and the oil also is from WallyWorld.. We like our Coach, but are just interested in persuing other things. Jack Smith 1973FC31 SoCal --- In WanderlodgeForum@yahoogroups.com, "ludlowthudpucker" > > I am trying to understand the full difference between a diesel or gasser wanderlodge of any given year. > > It seems hard to find much info on the powertrain difference, could any gasser peeps, give any insight to thier experience with a gasser unit. > > The area that I can't seem to find any info on at all is the chassis. Other than the gasser (usually a Ford industrial 391 (I think))Is there any difference in an FC gasser unit as compared to the diesel. Do they both have the air ride suspension? Do they both have airbrakes? Are the chassis identical? Do they both have 22 inch tires? Do both have brake assist system (Maybe not a jake for the gasser,but a retarder of some sort)? Are there any other difference other than just the engine? > > Any info would be great. > diesel/gasser differences - ludlowthudpucker - 10-02-2009 22:35 Jack, Thank you for the info. It sounds like you haven't had any bad experiences with your gasser rig. What kind of mileage have you put on it since you have owned it? Steve Hutter. --- In WanderlodgeForum@yahoogroups.com, "jackcj7" > > > I have the Burgendy & Silver 1973FC31 that is in Vintage Birds. It has a 391A Ford with a MT40 Allison, that has a retarder. It has juce brakes, and is overall a very simple Bird, compared to the newer ones. No air system, and that troublesom Air Step. I have seen Sporlian valves mentioned, but my coach has none. To fill the Water tank, I simply connect the hose to a fitting that goes right into the tank.. It originally had 30 amp shore power, but I upgraded to 50 amp. It also came with steel split rims, and 9.00X19" tires. Now it rides on 11X22.5 Toyos and some very pretty Accuride wheels. One thing to watch for on an older vehicle is the rotted rubber water hoses, including that feed to the chassis heaters, and Hot Water Heater. (I bypassed these...Here in Arnold-Land, the last thing I need is more heat)!! The little hoses around the engine water pump should be replaced also, as they rot after time.. > In a gas rig, you dont have to worry about Diesel Fuel "Going Bad", no Racor Filters, just a simple gas filter like I have in my Jeep.. No worry about what Anti-Freez to use or not to mix. I buy whatever is on sale at WallyWorld.....If I should replace the Shock Absorbers, I understand a set can be bought at Pep Boys. > I get 5.0 to 6.0 mpg on the road, and I always tow my Jeep. > An oil change is some 9 quarts, much less that the 3208, and the oil also is from WallyWorld.. > We like our Coach, but are just interested in persuing other things. > Jack Smith > 1973FC31 > SoCal > > > --- In WanderlodgeForum@yahoogroups.com, "ludlowthudpucker" > > > > I am trying to understand the full difference between a diesel or gasser wanderlodge of any given year. > > > > It seems hard to find much info on the powertrain difference, could any gasser peeps, give any insight to thier experience with a gasser unit. > > > > The area that I can't seem to find any info on at all is the chassis. Other than the gasser (usually a Ford industrial 391 (I think))Is there any difference in an FC gasser unit as compared to the diesel. Do they both have the air ride suspension? Do they both have airbrakes? Are the chassis identical? Do they both have 22 inch tires? Do both have brake assist system (Maybe not a jake for the gasser,but a retarder of some sort)? Are there any other difference other than just the engine? > > > > Any info would be great. > > > diesel/gasser differences - Michael - 10-03-2009 02:12 Just an FYI... My 1963 Bluebird with a GMC 401 Gasser came with air brakes. Michael & Tami Putz Mesa, Az 1978 FC35SB Wanderlodge - "Putz'n Around" 1963 FC35SB Conversion - "The Freedom Bus" FMCA #236459 --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > Steve - Air suspension started around 1980 and gassers ended around 1978, so no standard Wanderlodges had both air suspension and a gas engine. Air was *maybe* an available option earlier. > > The chassis is pretty much the same for all FCs. 34,000 GVW with body-on-frame construction. > > By the time diesel and air suspension became standard, brakes were air. Not sure when hydraulic brakes were used, but it goes back to early 70s. > > 80s FC all had 22.5" wheels AFAIK. I think some early 70's had 20". > > Many FCs have a Telma (also marketed by Jacobs) electric driveline retarder. Not sure when they started but would guess the 80s. > > I've heard of both 391 and 534 Ford gassers. There are several gasser owners on this forum. Maybe someone will chime in. > > Bob Griesel '84 FC31 WLII WA > > --- In WanderlodgeForum@yahoogroups.com, "ludlowthudpucker" > > > > Thanks Bob, > > I'll check it out and see if it helps. These Yahoo forums are a bit strange, it doesn't seem to have a place for a signature (or at least I haven't found it yet) so I'll just put it at the end of this post. > > > > What I'm looking for is more than just lists of which years had diesel/gas available, but specific specs for diesel vs gasser and real experience from gasser owners. > > > > Steve Hutter > > Florida > > > > > > --- In WanderlodgeForum@yahoogroups.com, "freewill2008" wrote: > > > > > > Start here: http://vintagebirds.com/ Go to "History" when you get there. > > > > > > Please tell us your name. > > > > > > Bob Griesel '84 FC31 WLII WA > > > > > > --- In WanderlodgeForum@yahoogroups.com, "ludlowthudpucker" > > > > > > > > I am trying to understand the full difference between a diesel or gasser wanderlodge of any given year. > > > > > > > > It seems hard to find much info on the powertrain difference, could any gasser peeps, give any insight to thier experience with a gasser unit. > > > > > > > > The area that I can't seem to find any info on at all is the chassis. Other than the gasser (usually a Ford industrial 391 (I think))Is there any difference in an FC gasser unit as compared to the diesel. Do they both have the air ride suspension? Do they both have airbrakes? Are the chassis identical? Do they both have 22 inch tires? Do both have brake assist system (Maybe not a jake for the gasser,but a retarder of some sort)? Are there any other difference other than just the engine? > > > > > > > > Any info would be great. > > > > > > > > > > |
