Need to replace starting batteries. - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Need to replace starting batteries. (/showthread.php?tid=9360) Pages: 1 2 |
Need to replace starting batteries. - nelsons - 05-07-2011 07:31 Hello Ron, I just traced the "Orange Wire". It went back to the Electrical connection for the trailer Hitch. I was the second owner of the coach. The previous owner must have used this to charge his car battery or maybe a trailer light. I am just going to remove it. Thanks Nelson Westminster, Md 40' WB --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > Its probably a circuit that someone added for a particular reason.à Does it look like someone just attached the Orange wire to the battery terminal or does it look like a factory job.à As long as you put it back where it belongs there is no reason to fret. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Sat, 5/7/11, nelsons > > From: nelsons > Subject: [WanderlodgeForum] Re: Need to replace starting batteries. > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, May 7, 2011, 11:57 AM > > > > > > > > à > > > > > > > > > > Thank You for the information Fred. > > I just checked my batteries and could not find a Cole Hersee battery switch. It looks like the hot side of the batteries are attached to an isolated bolt on a piece of aluminum behind the bank of batteries. The negative sides are also attached to two bolts on the piece of aluminum. One at the start of the batteries and one on the other end of the batteries. My only concern is this orange wire with an inline fuse attached to the plus side of the first battery. Not sure what this is for. Could not find any info in my documentation. > > Thanks > > Nelson > > Westminster, Md 40ft WB > > > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > > > Hi Nelson > > > To buy batteries for your chassis itâââ‰â¢s a good idea to buy from a supplier you do business with and will be there for you if you have any warranty issues in the future. > > > There should be a Cole Hersee battery switch just above the batteries on the firewall you need to turn to the off position before doing any work.Also remove any 110 V > > > source and turn of the inverter(s).Use baking soda and water for cleaning the tray and cables also.Just remember battery acid is corrosive. > > > It is also a good idea to take a picture of the setup before you begin in case you are interrupted for any reason. > > > Fred & Jeanne Hulse > > > Morristown,Arizona > > > 97 WLWB41 > > > > Need to replace starting batteries. - Gary Smith - 05-07-2011 07:55 Ron, I am not against taking that picture, but a bunch of those cables will look alike once disconnected. Labeling them eliminates the concern over hooking up incorrectly. It also helps you to know that you arenââ¬â¢t missing a cable (fell out of sight behind the batteries) when you think you are done.
Gary
SOB
Sent: Saturday, May 07, 2011 2:52 PM
Subject: Re: [WanderlodgeForum] Need to replace starting batteries.
Need to replace starting batteries. - Ron Thompson - 05-07-2011 11:42
Need to replace starting batteries. - nelsons - 05-08-2011 02:38 Hello Ron, I traced the wire to the trailer plug. It was on a terminal that usually not used. My son reminded me that we might of used this wire to power the lights and fans on my horse trailer when my daughter used to show horses. Thanks Nelson --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > Make sure it is not there for electric brakes on a tow or charging a break away battery. > > Ron Thompson -Waller, Tx. > > 1995 WLWB 42' > > (cockyfox@...) > > --- On Sat, 5/7/11, nelsons > > From: nelsons > Subject: [WanderlodgeForum] Re: Need to replace starting batteries. > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, May 7, 2011, 2:31 PM > > > > > > > > à > > > > > > > > > > > > Hello Ron, > > I just traced the "Orange Wire". It went back to the Electrical connection for the trailer Hitch. I was the second owner of the coach. The previous owner must have used this to charge his car battery or maybe a trailer light. I am just going to remove it. > > Thanks > > Nelson > > Westminster, Md 40' WB > > --- In WanderlodgeForum@yahoogroups.com, Ron Thompson > > > > > > Its probably a circuit that someone added for a particular reason.Ãâà Does it look like someone just attached the Orange wire to the battery terminal or does it look like a factory job.Ãâà As long as you put it back where it belongs there is no reason to fret. > > > > > > Ron Thompson -Waller, Tx. > > > > > > 1995 WLWB 42' > > > > > > (cockyfox@) > > > > > > --- On Sat, 5/7/11, nelsons > > > > > > From: nelsons > > > Subject: [WanderlodgeForum] Re: Need to replace starting batteries. > > > To: WanderlodgeForum@yahoogroups.com > > > Date: Saturday, May 7, 2011, 11:57 AM > > > > > > > > > > > > > > > > > > > > > > > > Ãâà > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Thank You for the information Fred. > > > > > > I just checked my batteries and could not find a Cole Hersee battery switch. It looks like the hot side of the batteries are attached to an isolated bolt on a piece of aluminum behind the bank of batteries. The negative sides are also attached to two bolts on the piece of aluminum. One at the start of the batteries and one on the other end of the batteries. My only concern is this orange wire with an inline fuse attached to the plus side of the first battery. Not sure what this is for. Could not find any info in my documentation. > > > > > > Thanks > > > > > > Nelson > > > > > > Westminster, Md 40ft WB > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" > > > > > > > > > > > > > > Hi Nelson > > > > > > > To buy batteries for your chassis itÃÆââââ¬Å¡Ã¬Ã¢ââ¬Å¾Ã¢s a good idea to buy from a supplier you do business with and will be there for you if you have any warranty issues in the future. > > > > > > > There should be a Cole Hersee battery switch just above the batteries on the firewall you need to turn to the off position before doing any work.Also remove any 110 V > > > > > > > source and turn of the inverter(s).Use baking soda and water for cleaning the tray and cables also.Just remember battery acid is corrosive. > > > > > > > It is also a good idea to take a picture of the setup before you begin in case you are interrupted for any reason. > > > > > > > Fred & Jeanne Hulse > > > > > > > Morristown,Arizona > > > > > > > 97 WLWB41 > > > > > > > > > > > |
