Bendix Brakes won't air up - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Bendix Brakes won't air up (/showthread.php?tid=2923) |
Bendix Brakes won't air up - Al - 07-19-2006 12:31 Update on my problem. I purchased the following kits to fix my dryer: DQ6026 - General Service Kit which Includes: Desiccant Cartridge, Coalescing Filter, Relief Valve, Purge Shield and Associated Hardware DA33115 - Purge Assembly Kit Installed all the items and expected my problem to be fixed and still not fixed. The dryer is still hissing from the bottom. Should I re-installed the new air governor? What else can it be? Do I need to buy a new replacement dryer? Al, Kathy Johnson '96 BMC Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "Al" > > To everyone that responded, thanks! > > Ok to bring everyone up to speed, we were able to get off the > mountain in Spruce Pine by taking the 1/4 air hose off and the > system started building presssure. We got to Gastonia, NC and the > dryer started purging air again. Thank God it did not act up in the > mountains on our way off Spruce Pine. > > So we tried to repeat the process and that did not fix it. So we > went down to Napa and purchased an air governer and installed it. > That did not fix it. We had two friendly truckers stop for breakfast > and Kathy pounced on them to ask questions. She is good at that. > LOL Anyway before I knew it one of the truckers pulled out a > fitting to join the two hoses ( in & out ) and eliminate the dryer > till I get home. I spoke to Bob Loomas the night before and he > suggusted we do that as well. So we joined the two hoses together > and did not need the trucker's fitting since we had all the fittings > we needed on the dryer. It was a close fit with no room to spare. > > Anyway so I spent the next two days calling every Haldex Dist. in > Charlotte and no one has the purge assembly. But I did locate one > in Atlanta which is on our way home. Also the unit has a purge > valve which is part of the major repair kit. > > Just want to make sure the everyone is in agreement that the purge > assemble which is different from the purge valve is what I need to > make the repair. I am leaning towards waiting till I get home on > Friday to start the repair so I don't dampen anymore of the trip. > > Again thanks goes out to everyone that responded to my help call. > Hopefully someday I can return the favor. > > Al, Kathy, Alfred & Daniel Johnson > '96 BMCCharlotte, NC ==> Atlanta, Ga. > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > I had a similar situation...after some searching, and obtaining > professional > > help, we found and replaced the air governor (about a $50 part, > and a > > thousand in labor...also rebuilt the air dryer). No problems > since. Before it was > > fixed, the air would air up to 30 lbs, and just stay > there...hissing sound > > somewhere near the top of the engine. > > > > Best of luck. > > > > Kevin McKeown > > Yorba Linda, CA > > 1986 38' PT > > > > > > [Non-text portions of this message have been removed] > > > |
