Another generator problem? Two questions? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Another generator problem? Two questions? (/showthread.php?tid=4990) |
Another generator problem? Two questions? - Larry - 05-28-2007 15:28 Tom, I hope you did not let the smoke out!!! Sea Ya Larry NYC 84 35FCSB ----- Original Message ---- From: thomas_sorrentino To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 28, 2007 4:05:03 PM Subject: [WanderlodgeForum] Re: Another generator problem? Two questions? Ralph, ok I'm done painting now! My wife thought painting was more important than fixing the generator LOL! not pushing start switch pushing start switch P=12 vdc 1=0 vdc 1=0 vdc 2=0 vdc 2=0 vdc 3=12 vdc 3=0 vdc 5=0 vdc 5=0 vdc All wires and connections look good. There is a faint smell of burnt electrical, when I took off control box cover. Tom Sorrentino 1987 PT38 Bedford Hills, NY --- In WanderlodgeForum@ yahoogroups. com, "Ralph L. Fullenwider" > > Morning Tom: > > Did you remove the wire from the post and check it as well? OK I know this > is redundant but double check the fuse holder to be sure a wire is not > burned off inside the control box. Next remove the top off the control box > and locate the terminal strip in the bottom of the box. Now make a drawing > of the terminal strip so you can make check marks as you do electrical > measurements. The terminal strip from left to right is > P,1,2,3,4,5, 6,7,8,9,20, 34,35,55 > > Set your meter, with the fuse in place, to dc volts, and put the black lead > of your meter with an jumper clip lead to ground. The do your measurements > with the red lead. You should have 12vdc on the terminal strip marked P. If > no 12 vdc then the fuse, fuse holder or wire is bad or connection corroded. > If you have power there, then with the red lead on terminals 1,2,3 you > should not read voltage until you switch the start switch. With the start > switch held in the start position you should have 12 vdc on 1,2,and 3. > Terminal 4 is the common or ground, Terminal 5, we are going to check if C > relay is pulling in. With the red lead on Terminal 5, switch the start and > if you have power then C relay is pulling in. This also checks the normally > closed contacts of the CR (110vac) relay. Terminal 6 is the pre heat > switch. Terminal 7 there is no connection. We will stop there for now, > because you should have proved there is power somewhere in the above. If > not then we will do a diode check on 4 diodes. The diodes, in this case, > will be square body units about 1/4 inch or so square with two tabs on each > end. > > So do those checks above first then we can go on after we find out where it > is or is not. > > Safe travels, > > Ralph and Charolette Fullenwider > 84FC35 > Ralph's RV Solutions, Duncan, Oklahoma > > At 03:22 PM 5/28/2007 +0000, you wrote: > >Ralph, > > > >I checked the voltage on the small terminal on the starter solenoid. > >0 vdc, when I hit the start switch. Next step please? > > > >Tom Sorrentino > >1987 PT38 > >Bedford Hills, NY > > > > > <!-- #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean, sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family:Georgia; } #ygrp-text p{ margin:0 0 1em 0;} #ygrp-tpmsgs{ font-family:Arial; clear:both;} #ygrp-vitnav{ padding-top:10px;font-family:Verdana;font-size:77%;margin:0;} #ygrp-vitnav a{ padding:0 1px;} #ygrp-actbar{ clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;} #ygrp-actbar .left{ float:left;white-space:nowrap;} .bld{font-weight:bold;} #ygrp-grft{ font-family:Verdana;font-size:77%;padding:15px 0;} #ygrp-ft{ font-family:verdana;font-size:77%;border-top:1px solid #666; padding:5px 0; } #ygrp-mlmsg #logo{ padding-bottom:10px;} #ygrp-vital{ background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;} #ygrp-vital #vithd{ font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp\ ercase;} #ygrp-vital ul{ padding:0;margin:2px 0;} #ygrp-vital ul li{ list-style-type:none;clear:both;border:1px solid #e0ecee; } #ygrp-vital ul li .ct{ font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri\ ght:.5em;} #ygrp-vital ul li .cat{ font-weight:bold;} #ygrp-vital a { text-decoration:none;} #ygrp-vital a:hover{ text-decoration:underline;} #ygrp-sponsor #hd{ color:#999;font-size:77%;} #ygrp-sponsor #ov{ padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;} #ygrp-sponsor #ov ul{ padding:0 0 0 8px;margin:0;} #ygrp-sponsor #ov li{ list-style-type:square;padding:6px 0;font-size:77%;} #ygrp-sponsor #ov li a{ text-decoration:none;font-size:130%;} #ygrp-sponsor #nc { background-color:#eee;margin-bottom:20px;padding:0 8px;} #ygrp-sponsor .ad{ padding:8px 0;} #ygrp-sponsor .ad #hd1{ font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%\ ;} #ygrp-sponsor .ad a{ text-decoration:none;} #ygrp-sponsor .ad a:hover{ text-decoration:underline;} #ygrp-sponsor .ad p{ margin:0;} o {font-size:0;} .MsoNormal { margin:0 0 0 0;} #ygrp-text tt{ font-size:120%;} blockquote{margin:0 0 0 4px;} .replbq {margin:4;} --> ________________________________________________________________________________\ ____Building a website is a piece of cake. Yahoo! Small Business gives you all the tools to get online. http://smallbusiness.yahoo.com/webhosting [Non-text portions of this message have been removed] Another generator problem? Two questions? - Ed Gardels - 05-28-2007 17:13 --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > Gregory... The problem was the pins in the cannon plug corrode over time, thereby causing arcing, which burnt the pin. Thatwas the second time a wire has been added to bypass the cannon plug. Now the gen set fires right off, where as before it wouldnt fire. Thanks.. Ed Gardels 89sp Arlington Texas > Ed, was the pin connection under sized as engineered, or is there > issue with a ;glow plug ;wire between plugs ;wire size from 12v > source ;glow not shuting off ;over glow? > > The burnt pin may not be the cause of your problem, it may be a > result. > > GregoryO'Connor > 94ptRomolandCa > > --- In WanderlodgeForum@yahoogroups.com, "Ed Gardels" > wrote: > > > > --- In WanderlodgeForum@yahoogroups.com, "thomas_sorrentino" > > > > > > > > > Tom... I have a 8.0 kabota(89sp)and had gen set problems since I > > bought it two years ago. I finnaly took it to a onan dealer here > and > > had it fixed($300). Problem was the cannon plun on the control box. > > The pin that supplied 12 vto glow plugs waqs burnt. They bypassed > the > > plug with new wires. This plug can cause a lot of gen set problems. > > > > Ed Gardels 89sp > > Arlington Texas > |
