Update on My Reno Status - My 3 Choices.... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Update on My Reno Status - My 3 Choices.... (/showthread.php?tid=5664) |
Update on My Reno Status - My 3 Choices.... - crissrace - 09-17-2007 00:56 --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > > Bob What happened to the old Cat & how many miles did it have on it > Don > 89 SP 36' > Butler, PA > > Andy > I had a cat remanufactured engine, with 2 year warrentee, installed > receintly in my 90SP36. Everything including a new turbo (300hp) and a > new radiator was under 20K--only just. It was at the Clevland Brothers > shop in New Stanton, PA. I think the engine componet was around 7K. > Good luck--I love my new engine. > Bob Criss > 90SP36 > Pittsburgh > > > > > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > Don The old engine had 140,000 miles on it. It overheated when the driver--thats me--with his limited high frequency hearing--failed to hear the high temperature alarm. This happened in Fairmont WVa on the way to Flordia for the Daytona 500. It was 5 degrees outside. Reason it happened was the fan switch failed, and, believe it or not, the shop failed to replace it. When they changed the engine they changed the bad switch over to the new engine. Then they ran the coach on their chassis dyno with the fan over ride switch engauged thereby omitting the only test-other than a test ride-that would have picked up the bad switch situation. I test drove it and the temperature went right up. Three hours later we had a new fan switch and were on our way. The old engine was traded in (core). They would have let me have it if i wanted to pay the core charge but I chose to give it to them. There were no cracks in the heads or block but both head gaskets were gone. There were other problems inside the engine having to do with bearing on some shaft-not the crank. That old engine with 140,000 miles on it was a 2 ring engine (the pistons had 2 rings). The new one has 3 ring pistons and I think a little less power but it doesn't blow vapors out the breather like the old one. Of course those vapors ended up in my radiator as you are well aware. Bob Criss 90SP36 Pittsburgh |
