Wireless rear cameras? - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Wireless rear cameras? (/showthread.php?tid=6742) |
Wireless rear cameras? - Scott Forman - 05-28-2008 14:40 Did you run new cables or use the old ones? Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, Joe Garner wrote: > > I just put in a new camera, used one that I got on > Ebay that just fit in the opening in the bezel. A > few small angle bracket to hold it in and it looks > pretty good. > > No problems with reflections cause its mounted to > the outside... > > One thing, on my '87 PT the 'window' was plastic > and so worn and frosted you couldnt see through it! > > Replaced the CRT monitor with a LCD (also from > Ebay) and now have color for the rear view :} > > Ive got photos if anyone is interested... > > > /Joe > '87 PT40 > San Francisco > > Scott Forman wrote: > > > > > > Ryan, > > > > Been there, done that. If you use a night vision camera with the > > little IR "lights", it will be useless at night as all you can see on > > the monitor is glare of the IR's on the window. However, there is a > > solution: 1) Buy a non-IR camera (hard to find), or 2) cover the IR's > > with electrical tape. I did option 2. The camera couldn't see in > > the dark, but it was still better at night than the original one. > > This was on my 82 FC. > > > > I am going to do something with my 86 PT, not sure what yet. > > > > Scott Forman > > 86 PT38 > > Memphis > > > > --- In WanderlodgeForum@ yahoogroups. com > > > > > > > > > > While we're talking cameras, has anyone replaced the inside- mounted > > > factory camera with another inside-mounted cam? A previous owner of > > my > > > coach removed the original and bolted a different camera outside. I > > > don't like the camera hanging off the coach and prefer the sleekness > > > of the factory camera-behind- the-window idea. > > > > > > Any thoughts on this project would be nice. I haven't looked at it > > > yet, but I presume I could just replace the little camera window and > > > mount a good camera behind it and be pretty well set. Though, it > > seems > > > like others are not retaining the inside-camera idea and I'm > > wondering > > > why? > > > > > > -Ryan > > > '86 PT-40 8V92 > > > > > > On Sun, May 18, 2008 at 4:29 PM, bubblerboy64 > > > > > > > > Don, I took your suggestion and removed the middle light. I ran a > > > > piece of parachute cord from that spot thru the coach up to the > > > > monitor location. I built myself a bracket to mount the monitor. > > > > When the electronics shows up hopefully the rest will be a cake > > walk. > > > > Never seems like it works out that way but to this point it's > > gone > > > > well. > > > > > > > > > > Wireless rear cameras? - joepat50 - 05-28-2008 15:54 Hi Scott, I used the old ones. They looked pretty good and I didnt see any advantage to replacing them. If yours are getting stiff or cracking you might want to, but its not a real critical cable AFAIK. /Joe '87 PT40 San Francisco --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Did you run new cables or use the old ones? > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, Joe Garner > wrote: > > > > I just put in a new camera, used one that I got on > > Ebay that just fit in the opening in the bezel. A > > few small angle bracket to hold it in and it looks > > pretty good. > > > > No problems with reflections cause its mounted to > > the outside... > > > > One thing, on my '87 PT the 'window' was plastic > > and so worn and frosted you couldnt see through it! > > > > Replaced the CRT monitor with a LCD (also from > > Ebay) and now have color for the rear view :} > > > > Ive got photos if anyone is interested... > > > > > > /Joe > > '87 PT40 > > San Francisco > > |
