Could somebody anwer this please - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Could somebody anwer this please (/showthread.php?tid=7698) |
Could somebody anwer this please - Kurt Horvath - 03-01-2009 04:13 Boy this tread went off in a different direction, As a proud Vintage Bluebird owner, if I were to get into another coach there is only one direction. A bus chassis with a good solid conversion. In time the BB will be as distinguested a Collectable as Airstream, GMC, Corvette, Picasso, Winchester?????? $ 4 $ pound for pound, the Bird is still and always will be THE ULIMATE ---CLASSIC MOTORHOME.--- I know this from the reactions I get at campgrounds from passer byes WOW a BLUEBIRD, She's beautiful!!! NO WAY THAT THINGS 15 years old!!! Ross, what's going to happen to the re-call and the coaches that were not upgraded? Kurt Horvath 95 PT 42 10AC In ,WanderlodgeForum@yahoogroups.com, "Ross" > > For interest,the handling of the new Wanderlodges with IFS was > great.The new Foretravel IFS should be good,great interiors, but fiber > walls. > As for Newell, nice coach, but far overweight and illegal. They have a > 28,000 drive axle and run 24,000 empty. > Why would anyone consider that. > Ross 2006 LXi > Prevost or tent. > > > > Greg, > > > > Exactly. Newell builds a nice coach but the interior fit and finish > is nowhere near Blue Bird. The Newell advantage is handling. The one > I had was a pleasure to drive and it never porpoised like a > Wanderlodge. With 2/3rds of the weight under the floor, the low > center of gravity kept the coach relatively flat in corners and very > responsive at the wheel. The other nice thing is..I believe the same > people have always owned Newell. It's a tight, closely held company > with long-term employees and a real family atmosphere. But there's no > perfect coach. > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > From: Petrover1@ > > Date: Sat, 28 Feb 2009 16:22:28 +0000 > > Subject: [WanderlodgeForum] Re: Could somebody anwer this please > > > > > > > > > > > > Too much power in reserve has little value. I have a battery bank > for > > the Bus'house with over 700 lbs of Trojan L-16's. they would last > > three to four days without charge but when it comes time to charge > > you have to run the genset 4 times as long as you would have to > > run/charge if you were to charge once a day. My set up would be > great > > for some one like CurtS who visits the desert for a weekend at a > > time and the trip to and from would be charge time via the alts and > > docking shore power. the big problem with a large bank is the > > replacement cost. I understand all batteries are best to renew at > the > > same time. My '90 Newell didnt hold a candle to the Wanderlodge as > > far as quality but I am kinda thinking it is time to revisit that > > last american Coach for my next unit > > Greg ofTim&Greg > > 94ptCa --- In WanderlodgeForum@yahoogroups.com, brad barton > > <bbartonwx@> wrote: > > > > > > > > > I liked the 8-D's in our Newell. We have 4-D's in the LXi now. > > Only disadvantage is how heavy and awkward they are. > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > From: danusa@ > > > Date: Sat, 28 Feb 2009 00:08:12 -0600 > > > Subject: RE: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > > > > > George, Really the 8D's are not expensive. I started with six > > Trojan golfcart batteries and a truecharge 40+ charger. Then I > > changed to six AGM golfcart batteries and a Xantrex RV2512GS > > inverter/charger. The Trojans cost me about $350 and the Lifeline > > about $600. The 8D batteries are blems or refurb exide and cost $40 > > each. I just now installed them so I don't have much history but if > > I get overnight camping out of them I will be happy. I will look > > into the group 31 batts. BTW, I used to live in Rock Hill, SC just > > south of Charlotte and was a member of the Rock Hill Civil Air > Patrol > > and EMS. I really enjoyed the people, the climate and the > > hospitality there a lot and I hope to get back there someday.. > > > > > > Dan Williams, 88WB38, Jackson, MS > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George Burke > > > Sent: Monday, February 23, 2009 3:27 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: Re: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > Dan, 8D batteries are usually used for starting, and I am not sure > > that they would be a good choice to use as house batteries. They are > > expensive however, and if you wanted to replace them with > alternative > > starting batts. you may try these. I have a 1981 Eagle Model 10 with > > a 8V71, that came from the factory with (3) group 31 batts connected > > in parallel, each with its own cutoff so you can check for a bad > > batt. When I replaced these a few yrs. ago I bought the ones with > the > > highest amp ratings that I could find. They have lasted a lot longer > > than the cheap ones that the P.O. used. Good Luck, George Burke 1977 > > FC31 Charlotte > > > > > > > > > On Mon, Feb 23, 2009 at 12:02 AM, Dan Williams > > > > > > > > > > > > > > > > > > Jon, The older coaches used the same batteries for starting and > dry > > camping. That is really not a good idea because then you will be > > trying to start the coach with low voltage batteries after a night > of > > dry camping and that is bad for the starter. Right now I have two 8D > > batteries plus a generator battery in my coach. It takes two 8D's > > because one is not enough CCA to start the 8v92. Each one has 1300 > > CCA. What I would like to do, but I don't know how to do it, is add > > two more high amp starting batteries just for starting the engine > and > > separate the 8D's to be used for house batteries. That way the > > starting batteries should always be at full voltage and the house > > batteries can be run low and then charged by the engine alternator. > > I think the six volt batteries were an attempt to get more camping > > amp hours out of the battery bank but the bigger problem with older > > coaches is the single battery bank IMO. > > > > > > Dan > > > 88PT38 > > > Jackson, MS > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon > > > Sent: Sunday, February 22, 2009 11:28 AM > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > Subject: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > There was a thread on here about battery's just about a week ago > > and I > > > > > > was wondering why can't you use single 12 volt batterys in our > > > coaches? Of course they would be the type that hold a charge for > > > longer durations than a standard 12 volt. I would also install > > > another set of a batterys for the generator itself. Jon > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > Windows Liveâ¢: Life without walls. > > > http://windowslive.com/explore? > > ocid=TXT_TAGLM_WL_allup_1a_explore_032009 > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > > Hotmail® is up to 70% faster. Now good news travels really fast. > > http://windowslive.com/online/hotmail? > ocid=TXT_TAGLM_WL_HM_70faster_032009 > > > Could somebody anwer this please - Ross - 03-01-2009 06:58 Hi, No doubt BB is looking for someone to do the work necessary. This may be a challenge as some companies may be reluctant to be involved in the lawsuits. Ross > Ross, what's going to happen to the re-call and the coaches that were > not upgraded? > > Kurt Horvath > 95 PT 42 > 10AC > > > > > In ,WanderlodgeForum@yahoogroups.com, "Ross" > > > > For interest,the handling of the new Wanderlodges with IFS was > > great.The new Foretravel IFS should be good,great interiors, but > fiber > > walls. > > As for Newell, nice coach, but far overweight and illegal. They > have a > > 28,000 drive axle and run 24,000 empty. > > Why would anyone consider that. > > Ross 2006 LXi > > Prevost or tent. > > > > > > Greg, > > > > > > Exactly. Newell builds a nice coach but the interior fit and > finish > > is nowhere near Blue Bird. The Newell advantage is handling. The > one > > I had was a pleasure to drive and it never porpoised like a > > Wanderlodge. With 2/3rds of the weight under the floor, the low > > center of gravity kept the coach relatively flat in corners and > very > > responsive at the wheel. The other nice thing is..I believe the > same > > people have always owned Newell. It's a tight, closely held > company > > with long-term employees and a real family atmosphere. But there's > no > > perfect coach. > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > From: Petrover1@ > > > Date: Sat, 28 Feb 2009 16:22:28 +0000 > > > Subject: [WanderlodgeForum] Re: Could somebody anwer this please > > > > > > > > > > > > > > > > > > Too much power in reserve has little value. I have a battery bank > > for > > > the Bus'house with over 700 lbs of Trojan L-16's. they would last > > > three to four days without charge but when it comes time to > charge > > > you have to run the genset 4 times as long as you would have to > > > run/charge if you were to charge once a day. My set up would be > > great > > > for some one like CurtS who visits the desert for a weekend at a > > > time and the trip to and from would be charge time via the alts > and > > > docking shore power. the big problem with a large bank is the > > > replacement cost. I understand all batteries are best to renew at > > the > > > same time. My '90 Newell didnt hold a candle to the Wanderlodge > as > > > far as quality but I am kinda thinking it is time to revisit that > > > last american Coach for my next unit > > > Greg ofTim&Greg > > > 94ptCa --- In WanderlodgeForum@yahoogroups.com, brad barton > > > <bbartonwx@> wrote: > > > > > > > > > > > > I liked the 8-D's in our Newell. We have 4-D's in the LXi now. > > > Only disadvantage is how heavy and awkward they are. > > > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > From: danusa@ > > > > Date: Sat, 28 Feb 2009 00:08:12 -0600 > > > > Subject: RE: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > George, Really the 8D's are not expensive. I started with six > > > Trojan golfcart batteries and a truecharge 40+ charger. Then I > > > changed to six AGM golfcart batteries and a Xantrex RV2512GS > > > inverter/charger. The Trojans cost me about $350 and the Lifeline > > > about $600. The 8D batteries are blems or refurb exide and cost > $40 > > > each. I just now installed them so I don't have much history but > if > > > I get overnight camping out of them I will be happy. I will look > > > into the group 31 batts. BTW, I used to live in Rock Hill, SC > just > > > south of Charlotte and was a member of the Rock Hill Civil Air > > Patrol > > > and EMS. I really enjoyed the people, the climate and the > > > hospitality there a lot and I hope to get back there someday.. > > > > > > > > Dan Williams, 88WB38, Jackson, MS > > > > > > > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George > Burke > > > > Sent: Monday, February 23, 2009 3:27 PM > > > > To: WanderlodgeForum@yahoogroups.com > > > > Subject: Re: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > Dan, 8D batteries are usually used for starting, and I am not > sure > > > that they would be a good choice to use as house batteries. They > are > > > expensive however, and if you wanted to replace them with > > alternative > > > starting batts. you may try these. I have a 1981 Eagle Model 10 > with > > > a 8V71, that came from the factory with (3) group 31 batts > connected > > > in parallel, each with its own cutoff so you can check for a bad > > > batt. When I replaced these a few yrs. ago I bought the ones with > > the > > > highest amp ratings that I could find. They have lasted a lot > longer > > > than the cheap ones that the P.O. used. Good Luck, George Burke > 1977 > > > FC31 Charlotte > > > > > > > > > > > > On Mon, Feb 23, 2009 at 12:02 AM, Dan Williams wrote: > > > > > > > > > > > > > > > > > > > > > > > > Jon, The older coaches used the same batteries for starting and > > dry > > > camping. That is really not a good idea because then you will be > > > trying to start the coach with low voltage batteries after a > night > > of > > > dry camping and that is bad for the starter. Right now I have two > 8D > > > batteries plus a generator battery in my coach. It takes two 8D's > > > because one is not enough CCA to start the 8v92. Each one has > 1300 > > > CCA. What I would like to do, but I don't know how to do it, is > add > > > two more high amp starting batteries just for starting the engine > > and > > > separate the 8D's to be used for house batteries. That way the > > > starting batteries should always be at full voltage and the house > > > batteries can be run low and then charged by the engine > alternator. > > > I think the six volt batteries were an attempt to get more > camping > > > amp hours out of the battery bank but the bigger problem with > older > > > coaches is the single battery bank IMO. > > > > > > > > Dan > > > > 88PT38 > > > > Jackson, MS > > > > > > > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon > > > > Sent: Sunday, February 22, 2009 11:28 AM > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Subject: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > There was a thread on here about battery's just about a week > ago > > > and I > > > > > > > > was wondering why can't you use single 12 volt batterys in our > > > > coaches? Of course they would be the type that hold a charge > for > > > > longer durations than a standard 12 volt. I would also install > > > > another set of a batterys for the generator itself. Jon > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > > Windows Liveâ¢: Life without walls. > > > > http://windowslive.com/explore? > > > ocid=TXT_TAGLM_WL_allup_1a_explore_032009 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > > > Hotmail® is up to 70% faster. Now good news travels really fast. > > > http://windowslive.com/online/hotmail? > > ocid=TXT_TAGLM_WL_HM_70faster_032009 > > > > > > Could somebody anwer this please - timvasqz - 03-01-2009 09:01 Then Tent, we gotta start buying only USA made products or demanding USA mfg's make them as good as the Canadian makers build Prevost. Greg nothing against Canada, I like hocky --- In WanderlodgeForum@yahoogroups.com, "Ross" wrote: > > For interest,the handling of the new Wanderlodges with IFS was > great.The new Foretravel IFS should be good,great interiors, but fiber > walls. > As for Newell, nice coach, but far overweight and illegal. They have a > 28,000 drive axle and run 24,000 empty. > Why would anyone consider that. > Ross 2006 LXi > Prevost or tent. > > > > Greg, > > > > Exactly. Newell builds a nice coach but the interior fit and finish > is nowhere near Blue Bird. The Newell advantage is handling. The one > I had was a pleasure to drive and it never porpoised like a > Wanderlodge. With 2/3rds of the weight under the floor, the low > center of gravity kept the coach relatively flat in corners and very > responsive at the wheel. The other nice thing is..I believe the same > people have always owned Newell. It's a tight, closely held company > with long-term employees and a real family atmosphere. But there's no > perfect coach. > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > From: Petrover1@ > > Date: Sat, 28 Feb 2009 16:22:28 +0000 > > Subject: [WanderlodgeForum] Re: Could somebody anwer this please > > > > > > > > > > > > Too much power in reserve has little value. I have a battery bank > for > > the Bus'house with over 700 lbs of Trojan L-16's. they would last > > three to four days without charge but when it comes time to charge > > you have to run the genset 4 times as long as you would have to > > run/charge if you were to charge once a day. My set up would be > great > > for some one like CurtS who visits the desert for a weekend at a > > time and the trip to and from would be charge time via the alts and > > docking shore power. the big problem with a large bank is the > > replacement cost. I understand all batteries are best to renew at > the > > same time. My '90 Newell didnt hold a candle to the Wanderlodge as > > far as quality but I am kinda thinking it is time to revisit that > > last american Coach for my next unit > > Greg ofTim&Greg > > 94ptCa --- In WanderlodgeForum@yahoogroups.com, brad barton > > <bbartonwx@> wrote: > > > > > > > > > I liked the 8-D's in our Newell. We have 4-D's in the LXi now. > > Only disadvantage is how heavy and awkward they are. > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > From: danusa@ > > > Date: Sat, 28 Feb 2009 00:08:12 -0600 > > > Subject: RE: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > > > > > George, Really the 8D's are not expensive. I started with six > > Trojan golfcart batteries and a truecharge 40+ charger. Then I > > changed to six AGM golfcart batteries and a Xantrex RV2512GS > > inverter/charger. The Trojans cost me about $350 and the Lifeline > > about $600. The 8D batteries are blems or refurb exide and cost $40 > > each. I just now installed them so I don't have much history but if > > I get overnight camping out of them I will be happy. I will look > > into the group 31 batts. BTW, I used to live in Rock Hill, SC just > > south of Charlotte and was a member of the Rock Hill Civil Air > Patrol > > and EMS. I really enjoyed the people, the climate and the > > hospitality there a lot and I hope to get back there someday.. > > > > > > Dan Williams, 88WB38, Jackson, MS > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George Burke > > > Sent: Monday, February 23, 2009 3:27 PM > > > To: WanderlodgeForum@yahoogroups.com > > > Subject: Re: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > Dan, 8D batteries are usually used for starting, and I am not sure > > that they would be a good choice to use as house batteries. They are > > expensive however, and if you wanted to replace them with > alternative > > starting batts. you may try these. I have a 1981 Eagle Model 10 with > > a 8V71, that came from the factory with (3) group 31 batts connected > > in parallel, each with its own cutoff so you can check for a bad > > batt. When I replaced these a few yrs. ago I bought the ones with > the > > highest amp ratings that I could find. They have lasted a lot longer > > than the cheap ones that the P.O. used. Good Luck, George Burke 1977 > > FC31 Charlotte > > > > > > > > > On Mon, Feb 23, 2009 at 12:02 AM, Dan Williams > > > > > > > > > > > > > > > > > > Jon, The older coaches used the same batteries for starting and > dry > > camping. That is really not a good idea because then you will be > > trying to start the coach with low voltage batteries after a night > of > > dry camping and that is bad for the starter. Right now I have two 8D > > batteries plus a generator battery in my coach. It takes two 8D's > > because one is not enough CCA to start the 8v92. Each one has 1300 > > CCA. What I would like to do, but I don't know how to do it, is add > > two more high amp starting batteries just for starting the engine > and > > separate the 8D's to be used for house batteries. That way the > > starting batteries should always be at full voltage and the house > > batteries can be run low and then charged by the engine alternator. > > I think the six volt batteries were an attempt to get more camping > > amp hours out of the battery bank but the bigger problem with older > > coaches is the single battery bank IMO. > > > > > > Dan > > > 88PT38 > > > Jackson, MS > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon > > > Sent: Sunday, February 22, 2009 11:28 AM > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > Subject: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > There was a thread on here about battery's just about a week ago > > and I > > > > > > was wondering why can't you use single 12 volt batterys in our > > > coaches? Of course they would be the type that hold a charge for > > > longer durations than a standard 12 volt. I would also install > > > another set of a batterys for the generator itself. Jon > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > Windows Liveâ¢: Life without walls. > > > http://windowslive.com/explore? > > ocid=TXT_TAGLM_WL_allup_1a_explore_032009 > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > > Hotmail® is up to 70% faster. Now good news travels really fast. > > http://windowslive.com/online/hotmail? > ocid=TXT_TAGLM_WL_HM_70faster_032009 > > > Could somebody anwer this please - Stephen Birtles - 03-01-2009 09:34 and mci Learn how to use a spell checker it is hockey not hocky and cynical not synical --- In WanderlodgeForum@yahoogroups.com, "timvasqz" > > Then Tent, we gotta start buying only USA made products or demanding > USA mfg's make them as good as the Canadian makers build Prevost. > Greg > nothing against Canada, I like hocky > > --- In WanderlodgeForum@yahoogroups.com, "Ross" > wrote: > > > > For interest,the handling of the new Wanderlodges with IFS was > > great.The new Foretravel IFS should be good,great interiors, but > fiber > > walls. > > As for Newell, nice coach, but far overweight and illegal. They > have a > > 28,000 drive axle and run 24,000 empty. > > Why would anyone consider that. > > Ross 2006 LXi > > Prevost or tent. > > > > > > Greg, > > > > > > Exactly. Newell builds a nice coach but the interior fit and > finish > > is nowhere near Blue Bird. The Newell advantage is handling. The > one > > I had was a pleasure to drive and it never porpoised like a > > Wanderlodge. With 2/3rds of the weight under the floor, the low > > center of gravity kept the coach relatively flat in corners and > very > > responsive at the wheel. The other nice thing is..I believe the > same > > people have always owned Newell. It's a tight, closely held > company > > with long-term employees and a real family atmosphere. But there's > no > > perfect coach. > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > From: Petrover1@ > > > Date: Sat, 28 Feb 2009 16:22:28 +0000 > > > Subject: [WanderlodgeForum] Re: Could somebody anwer this please > > > > > > > > > > > > > > > > > > Too much power in reserve has little value. I have a battery bank > > for > > > the Bus'house with over 700 lbs of Trojan L-16's. they would last > > > three to four days without charge but when it comes time to > charge > > > you have to run the genset 4 times as long as you would have to > > > run/charge if you were to charge once a day. My set up would be > > great > > > for some one like CurtS who visits the desert for a weekend at a > > > time and the trip to and from would be charge time via the alts > and > > > docking shore power. the big problem with a large bank is the > > > replacement cost. I understand all batteries are best to renew at > > the > > > same time. My '90 Newell didnt hold a candle to the Wanderlodge > as > > > far as quality but I am kinda thinking it is time to revisit that > > > last american Coach for my next unit > > > Greg ofTim&Greg > > > 94ptCa --- In WanderlodgeForum@yahoogroups.com, brad barton > > > <bbartonwx@> wrote: > > > > > > > > > > > > I liked the 8-D's in our Newell. We have 4-D's in the LXi now. > > > Only disadvantage is how heavy and awkward they are. > > > > > > > > Brad Barton 00LXiDFW bbartonwx@ > > > > > > > > > > > > > > > > > > > > > > > > To: WanderlodgeForum@yahoogroups.com > > > > From: danusa@ > > > > Date: Sat, 28 Feb 2009 00:08:12 -0600 > > > > Subject: RE: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > George, Really the 8D's are not expensive. I started with six > > > Trojan golfcart batteries and a truecharge 40+ charger. Then I > > > changed to six AGM golfcart batteries and a Xantrex RV2512GS > > > inverter/charger. The Trojans cost me about $350 and the Lifeline > > > about $600. The 8D batteries are blems or refurb exide and cost > $40 > > > each. I just now installed them so I don't have much history but > if > > > I get overnight camping out of them I will be happy. I will look > > > into the group 31 batts. BTW, I used to live in Rock Hill, SC > just > > > south of Charlotte and was a member of the Rock Hill Civil Air > > Patrol > > > and EMS. I really enjoyed the people, the climate and the > > > hospitality there a lot and I hope to get back there someday.. > > > > > > > > Dan Williams, 88WB38, Jackson, MS > > > > > > > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of George > Burke > > > > Sent: Monday, February 23, 2009 3:27 PM > > > > To: WanderlodgeForum@yahoogroups.com > > > > Subject: Re: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > Dan, 8D batteries are usually used for starting, and I am not > sure > > > that they would be a good choice to use as house batteries. They > are > > > expensive however, and if you wanted to replace them with > > alternative > > > starting batts. you may try these. I have a 1981 Eagle Model 10 > with > > > a 8V71, that came from the factory with (3) group 31 batts > connected > > > in parallel, each with its own cutoff so you can check for a bad > > > batt. When I replaced these a few yrs. ago I bought the ones with > > the > > > highest amp ratings that I could find. They have lasted a lot > longer > > > than the cheap ones that the P.O. used. Good Luck, George Burke > 1977 > > > FC31 Charlotte > > > > > > > > > > > > On Mon, Feb 23, 2009 at 12:02 AM, Dan Williams > > > > > > > > > > > > > > > > > > > > > > > > Jon, The older coaches used the same batteries for starting and > > dry > > > camping. That is really not a good idea because then you will be > > > trying to start the coach with low voltage batteries after a > night > > of > > > dry camping and that is bad for the starter. Right now I have two > 8D > > > batteries plus a generator battery in my coach. It takes two 8D's > > > because one is not enough CCA to start the 8v92. Each one has > 1300 > > > CCA. What I would like to do, but I don't know how to do it, is > add > > > two more high amp starting batteries just for starting the engine > > and > > > separate the 8D's to be used for house batteries. That way the > > > starting batteries should always be at full voltage and the house > > > batteries can be run low and then charged by the engine > alternator. > > > I think the six volt batteries were an attempt to get more > camping > > > amp hours out of the battery bank but the bigger problem with > older > > > coaches is the single battery bank IMO. > > > > > > > > Dan > > > > 88PT38 > > > > Jackson, MS > > > > > > > > > > > > > > > > > > > > > > > > From: WanderlodgeForum@yahoogroups.com > > > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jon > > > > Sent: Sunday, February 22, 2009 11:28 AM > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > Subject: [WanderlodgeForum] Could somebody anwer this please > > > > > > > > > > > > > > > > > > > > There was a thread on here about battery's just about a week > ago > > > and I > > > > > > > > was wondering why can't you use single 12 volt batterys in our > > > > coaches? Of course they would be the type that hold a charge > for > > > > longer durations than a standard 12 volt. I would also install > > > > another set of a batterys for the generator itself. Jon > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > __________________________________________________________ > > > > Windows Liveâ¢: Life without walls. > > > > http://windowslive.com/explore? > > > ocid=TXT_TAGLM_WL_allup_1a_explore_032009 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > _________________________________________________________________ > > > Hotmail® is up to 70% faster. Now good news travels really fast. > > > http://windowslive.com/online/hotmail? > > ocid=TXT_TAGLM_WL_HM_70faster_032009 > > > > > > |
