Coach Batts overcharging - Ernie Ekberg - 11-26-2010 12:28
Well, Fred, since you were in the auto parts "bidness" thought you may have something going!! Ernesto- Enid, Ok
83 PT40
Weatherford, Tx 76086
817-475-3991
--- On Fri, 11/26/10, Fred Hulse wrote:
Subject: Re: [WanderlodgeForum] Re: Coach Batts overcharging
Date: Friday, November 26, 2010, 5:51 PM
 Just kidding, Ernie
Fred |
Coach Batts overcharging - Fred Hulse - 11-26-2010 13:05
I suppose that you and I could create some "snake oil"
consisting ofblue food dye and battery acid and distilled water to "supercharge your battery" for only $29.95 + $8.95 shipping and handling charge and if you call in the next 5 minutes, we will add a second Voltage Fertilizer absolutely FREE!!!
How's that Ernie, think we can sell some??
Fred
Coach Batts overcharging - Ernie Ekberg - 11-26-2010 14:08
You bet, Fred-- but since you and I are quite alike- could we sleep at nite selling something that is bogus? I couldn't and I know you could not
83 PT40
817-475-3991
Date: Friday, November 26, 2010, 7:05 PM
Fred |
Coach Batts overcharging - Robert Johannesen - 11-26-2010 14:21
You could make it Blue for cold weather and redfor hot weather!
Sent: Fri, November 26, 2010 8:08:29 PM
83 PT40
817-475-3991
Fred |
Coach Batts overcharging - Fred Hulse - 11-26-2010 14:44
You're right,but it was fun talking about it.
Fred
Coach Batts overcharging - Fred Hulse - 11-26-2010 14:46
Good thought, Robert,
I will submit it to our engineering department!! (Cody- the black & white pomeranian)
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
Coach Batts overcharging - Robert Johannesen - 11-26-2010 14:52
You realize that when engineering and legal get involved you'll be back to distilled water?
Sent: Fri, November 26, 2010 8:46:53 PM
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
Coach Batts overcharging - Fred Hulse - 11-26-2010 15:40
And add sales dept and you have an empty bottle
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
Coach Batts overcharging - GARY MINKER - 11-27-2010 04:35
Some really big alternators that are lightly loaded can not regulate properly so the voltage skyrockets.
gary
85pt40
--- On Fri, 11/26/10, freewill2008 wrote:
Subject: [WanderlodgeForum] Re: Coach Batts overcharging
Date: Friday, November 26, 2010, 12:58 PM
Great that the problem is solved. I'd like to se the circuit diagrams to try and learn how a system with no more than 14+ volts available can show 20+ volts on a system volt meter. Fred - maybe your coach has created electrical perpetual motion and solved the world's energy problems?  )
Bob Griesel '84 FC31 WLII
--- In WanderlodgeForum@yahoogroups.com, "Fred Hulse" wrote:
> Hi Ron,
> To simplify the issue,
> The ammeter on the dash pegged to 300+ amps
> The voltmeter for the coach pegged to 25+ volts
> The voltmeter for the engine showed 12+ volts.
> After the fact, I conclude that the solenoid was sending all the power from the alternator to the coach bank of batteries and allowing nothing to the engine batteries.
> After testing I found my engine batteries were all but dead.
> This also did not allow the jumper feature to operate.
> Thank you Ron for your input.
> Fred & Jeanne Hulse
> Morristown,Arizona
> 97 WLWB41
