CLOCK - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: General (/forumdisplay.php?fid=37) +--- Thread: CLOCK (/showthread.php?tid=10090) |
CLOCK - csprenger - 11-22-2013 13:26 Fascinating - Have you ever seen a clock like this one? Click here http://www.poodwaddle.com/Stats/ RE: CLOCK - davidbrady - 11-22-2013 15:32 Thanks Curt, Very impressive! I don't think that's bad news at all! It's quite an impressive machine we run here on spaceship Earth!
RE: CLOCK - RetDA - 12-09-2013 12:18 (11-22-2013 15:32)davidbrady Wrote: Thanks Curt, Nice clock, but I sure wish somebody would come up with a replacement for the nice overhead bedroom clock that quit working 4-5 years ago.
RE: CLOCK - davidbrady - 12-09-2013 17:09 Tommy, Are you referring to the digital clock with the alarm feature? I think that's a PMMI Electronics product. I haven't checked in on PMMI in quite some time, but I believe they're still around. Here's an email address for you: sales@pmmi-electronics.com RE: CLOCK - ernie ekberg - 12-09-2013 21:27 I have found on a couple of my clocks that there appears a small crack or void in a soldered joint, that when resoldered, makes the clock usable, again. your mileage and results will vary RE: CLOCK - pgchin - 12-11-2013 12:44 (12-09-2013 21:27)ernie ekberg Wrote: I have found on a couple of my clocks that there appears a small crack or void in a soldered joint, that when resoldered, makes the clock usable, again. your mileage and results will varyYup, what he said, I've fixed many a panel, clock, logic board, tucked into the "caverns" of birds over the years with solder and an old iron. Always carry an old iron with 5 different wattage tips. Over 40 years old!!!!!!!! Still works!
RE: CLOCK - mikebulriss - 12-12-2013 00:20 (12-09-2013 21:27)ernie ekberg Wrote: I have found on a couple of my clocks that there appears a small crack or void in a soldered joint, that when resoldered, makes the clock usable, again. your mileage and results will vary Yes and the same exact thing happens to the boards on the rooftop AC units. I have had mine out for re-soldering multiple times. Re-did virtually every solder on the front one about two months ago. Freezing cold now. Easy fix. I wonder how many ACs have been replaced over the years due to poor solders on the boards? |
