Soft Water for your 'Bird - Printable Version
+--- Forum: Plumbing (/forumdisplay.php?fid=27)
+--- Thread: Soft Water for your 'Bird (/showthread.php?tid=10165)
Soft Water for your 'Bird - cmillsap - 03-15-2014 02:26
If this system lives up to its great reviews; it would be ideal to install and use in our coaches. Filter lasts 6 months (maybe longer in a bus?)and costs $50. Anyone have experience with this product?
http://www.nuvoh2o.com/nuvo-systems/nuvo-studio-system.html\
RE: Soft Water for your 'Bird - ernie ekberg - 03-15-2014 08:15
pay in full for $474?
RE: Soft Water for your 'Bird - dentmac - 03-15-2014 11:45
I seem to remember reading about this before:
Not very good:
ReadNuvo reviews
Some better
Amazon reviews
I think--- look elsewhere!
Ross
Looking for softeners: Here are 2:
http://www.amazon.com/Watts-RV-PRO-1000-M7002-Water/dp/B0050EITTK/ref=pd_sim_sbs_hi_1?ie=UTF8&refRID=1DB6QCZEF9FKK3FTWD15#productDetails
http://www.amazon.com/SoftSpot-Portable-Softener-Reducer-P400-Ivory/dp/B00B4T160Y/ref=sr_1_2?s=hi&ie=UTF8&qid=1394894786&sr=1-2&keywords=portable+water+softner
I'd like to find someone with one first. I've seen them, just haven't stopped by---yet--- easy to see as they sit outside.
RE: Soft Water for your 'Bird - ryanjm - 06-09-2026 00:09
Worth separating two things here: salt-based portable softeners (like the Watts RV-PRO) genuinely reduce hardness, while citric acid systems like NuvoH2O condition the water without actually softening it. If you want to avoid hauling salt bags, a quality Salt Free Water Softener using template-assisted crystallization is a closer middle ground than the NuvoH2O approach. Not the same as salt-based, but a real step up from citric acid.
