Why MotorCoaches Burn - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: General (/forumdisplay.php?fid=37) +--- Thread: Why MotorCoaches Burn (/showthread.php?tid=10183) |
[split] Parting out writeoffs-- website - Arcticdude - 03-23-2014 13:01 They're in East Bernhart, KY. Interesting to see they've also got 6 Prevost/MCI/etc sitting there. A couple of true wrecks, but mostly fires. So why are RV's so susceptible to fires? I mean, I know we've got numerous ignition sources and lots of stuff that burns way too fast; but shouldn't the owners recognize this and work to prevent them? I realize I've just stirred up the fire demons and won't make it back home! RE: Parting out writeoffs-- website - al perna - 03-24-2014 01:40 John , Just a guess but I can think of 2 reasons for fires . 1. running the exhaust thru the bus . I wish it was down low . 2. failure to allow the engine exhaust to cool down . I always allow 5 or so minutes after a run . RE: Parting out writeoffs-- website - davidbrady - 03-27-2014 15:44 John, I found this in our Document Library -> Theory -> Why Motorcoaches Burn. RE: Parting out writeoffs-- website - al perna - 03-27-2014 18:54 real nice find David . RE: Parting out writeoffs-- website - Arcticdude - 03-28-2014 09:37 I've seen that article before and it definitely offers good for thought. Most of the ignition sources mentioned are easily inspected during the morning walk around. Maybe that's what I'm having a hard time comprehending. Stuff that's easily and should be checked daily is accounting for most of the Motorcoaching fires out there, commercial and private. Why MotorCoaches Burn - davidbrady - 03-28-2014 11:27 This is important enough that I thought I'd break this discussion out into it's own thread. Some of you may have seen this 2007 publication: Why MotorCoaches Burn, From Document Library -> Theory: Taken from the article: Preventative, Periodic, Annual and Daily (Pre/Post Trip) Maintenance and Inspection Items • B+ Cable at alternator secure (stud, bracket and clamps in position) • Alternator oil lines and rear cover plate secure and not leaking • All alternator electrical studs covered with rubber boots • Remote Jump Post secure and stud covered with rubber boot • Starter cables secure and routed properly • Bulkhead connection for B+ cables (starter and alternator) secure • Engine compartment clean/dry of fluids • Engine and Transmission fluid connections/hoses secure and not leaking; sensors not leaking • No leaks dripping onto pavement • Hub-Caps; no visible leaks, rubber plug in place, sight glass is clear, oil at proper level • Oil seals are in good condition, no leaks (only observable from under vehicle) • Disc brake rotors (if visible) clean with no bluing • Dual tires not making contact with each other • Turbocharger oil line(s) not leaking, waste gate pivot pin not leaking oil • Exhaust system; no oil exiting from muffler, no excessive blue smoke (turbocharger oil consumption) • Engine has appropriate performance (torque) • Auxiliary heater not leaking fuel • No active / Illuminated A.B.S. dash light* *The illumination of this light could indicate the potential onset of a loose wheel bearing, hub run-out, wheel bearing failure or a skidding or locked tire/wheel. RE: Why MotorCoaches Burn - Arcticdude - 03-28-2014 14:04 Good point to separate this, David. We've all got everything mentioned in the article and the vast majority is easily checked. We all need to remember a comprehensive VISUAL inspection can prevent the normally seen issues with our coaches. It's even the same routine, no matter what brand we're driving!
