Lithium Batteries - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: About the Forum (/forumdisplay.php?fid=49) +--- Forum: Ideas and Suggestions (/forumdisplay.php?fid=50) +--- Thread: Lithium Batteries (/showthread.php?tid=10348) |
Lithium Batteries - dentmac - 11-08-2014 13:21 Hi, Switched my Group 31 Gen start battery (68 lbs) to a lithium at 5 lbs. Mounted beside the headlight so great way to reduce 80+ lbs from front axle. SHORAI LFX36L3-BS12 Lithium Battery 36Ah ,540 CCA In changing it, I suggest that you don't have your head under the big one when you try to take it off the shelf ![]() |
