fuel shut off solenoid - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: fuel shut off solenoid (/showthread.php?tid=1036) |
fuel shut off solenoid - dandarst - 07-10-2005 14:01 Has anyone removed the fuel shut off solenoid to know what the mechanical linkage looks like? I am interested in pulling it out and rotating it 180 degrees so that the two electrical connectors point to the rear instead of the front. This in preparation for installing a 320 amp alternator. dandarst86fc35rbhuntleyil. fuel shut off solenoid - Mike Hohnstein - 07-10-2005 14:13 It's not scary, it will rotate with out removing. Mike Hohnstein ----- Original Message ----- From: dandarst To: WanderlodgeForum@yahoogroups.com Sent: Sunday, July 10, 2005 9:01 PM Subject: [WanderlodgeForum] fuel shut off solenoid Has anyone removed the fuel shut off solenoid to know what the mechanical linkage looks like? I am interested in pulling it out and rotating it 180 degrees so that the two electrical connectors point to the rear instead of the front. This in preparation for installing a 320 amp alternator. dandarst86fc35rbhuntleyil. ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] fuel shut off solenoid - Dan Darst - 07-11-2005 00:17 gotcha, thanks Mike. dandarst86fc35rbhuntleyil. >From: "Mike Hohnstein" <MHOHNSTEIN@...> >Reply-To: WanderlodgeForum@yahoogroups.com >To: >Subject: Re: [WanderlodgeForum] fuel shut off solenoid >Date: Sun, 10 Jul 2005 21:13:20 -0500 > >It's not scary, it will rotate with out removing. >Mike Hohnstein > ----- Original Message ----- > From: dandarst > To: WanderlodgeForum@yahoogroups.com > Sent: Sunday, July 10, 2005 9:01 PM > Subject: [WanderlodgeForum] fuel shut off solenoid > > > Has anyone removed the fuel shut off solenoid to know what the > mechanical linkage looks like? I am interested in pulling it out and > rotating it 180 degrees so that the two electrical connectors point to > the rear instead of the front. This in preparation for installing a > 320 amp alternator. > > dandarst86fc35rbhuntleyil. > > > > >------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of >Service. > > >------------------------------------------------------------------------------ > > > >[Non-text portions of this message have been removed] > fuel shut off solenoid - morgooder - 04-14-2007 07:40 I have an intermittent problem with my fuel shut off solenoid. Engin wont start, right now I'm reading 6.5 volts at terminal. Does anyone know where this wire is fed from. Thinking about running a new wire from starter solenoid but would rather fix original wire. Don't see this on my drawings. 84 FC 31' Thanks fuel shut off solenoid - Tom Seitz - 04-14-2007 12:55 Morgooder, I dont know where the wire is fed from. But some where there is a write up on a wiring upgrade where you install a relay and use the LOW voltage hot wire to the sol. to activate the new relay and then run a new GOOD hot wire threw the relay on to the fuel shut off sol.to keep 12v to the sol. at all times. Worked for me. Maybe its in the files sec. not sure. Hope this helps. Tom 90 SP36 Alpharetta GA --- In WanderlodgeForum@yahoogroups.com, "morgooder" <morgooder@...> wrote: > > I have an intermittent problem with my fuel shut off solenoid. Engin > wont start, right now I'm reading 6.5 volts at terminal. Does anyone > know where this wire is fed from. Thinking about running a new wire > from starter solenoid but would rather fix original wire. Don't see > this on my drawings. 84 FC 31' > Thanks > fuel shut off solenoid - Richard Hayden - 04-15-2007 04:43 This is common problem on the FC's. I solved it by installing a 70amp Bosch relay in the engine space near the fuel solenoid. I used the existing wire off of the the fuel solenoid and got 12vdc from the back of the alternator. It is important to use a heavy duty fuse on the alternator wire. I can't remember the size but try 30 amp to start. The original wire comes from a circuit breaker on the left front behind the access door on the outside. Changing this circuit breaker this won't necessarily solve the problem but you could try. I didn't, I just installed the new relay as described above. Good luck. Please sign your name and location on your posts. Dick Hayden - '87 PT 38 - Lake Stevens, WA ----- Original Message ----- From: Tom Seitz To: WanderlodgeForum@yahoogroups.com Sent: Saturday, April 14, 2007 5:55 PM Subject: [WanderlodgeForum] Re: Fuel shut off solenoid Morgooder, I dont know where the wire is fed from. But some where there is a write up on a wiring upgrade where you install a relay and use the LOW voltage hot wire to the sol. to activate the new relay and then run a new GOOD hot wire threw the relay on to the fuel shut off sol.to keep 12v to the sol. at all times. Worked for me. Maybe its in the files sec. not sure. Hope this helps. Tom 90 SP36 Alpharetta GA --- In WanderlodgeForum@yahoogroups.com "morgooder" <morgooder@...> wrote: > > I have an intermittent problem with my fuel shut off solenoid. Engin > wont start, right now I'm reading 6.5 volts at terminal. Does anyone > know where this wire is fed from. Thinking about running a new wire > from starter solenoid but would rather fix original wire. Don't see > this on my drawings. 84 FC 31' > Thanks > [Non-text portions of this message have been removed] |
