Celing Panel in BR Coming Down - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Celing Panel in BR Coming Down (/showthread.php?tid=1039) |
Celing Panel in BR Coming Down - Jack and Liz Pearce - 07-11-2005 00:43 Howdy, Y'all. One of the ceiling panels in the bedroom is coming down. It is the panel where the air conditioning grill is located. Standing in front of the window, on the curb side, the lower right corner of this panel has lifted up. At the lower left corner of this panel, I can see a slight water mark on the on the strip directly below it. Now I don't know how long that water mark has been there. When Jack comes home from work, we will try and ease some paper toweling behind that panel to see if there is some moisture in that area. My question is what keeps those ceiling panels up? Are they glued at the corners? Thanks, Liz Fulltiming in a Wanderlodge Regards, Jack and Liz Pearce 1993 Wanderlodge WB40 Homesick Texans in Lantana, FL Celing Panel in BR Coming Down - ronmarabito2002 - 07-12-2005 04:58 Liz: Sounds like you found your leak from a while back. The corners are probably glued. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > Howdy, Y'all. > > One of the ceiling panels in the bedroom is coming down. It is the > panel where the air conditioning grill is located. Standing in front > of the window, on the curb side, the lower right corner of this panel > has lifted up. At the lower left corner of this panel, I can see a > slight water mark on the on the strip directly below it. Now I don't > know how long that water mark has been there. When Jack comes home > from work, we will try and ease some paper toweling behind that panel > to see if there is some moisture in that area. > > My question is what keeps those ceiling panels up? Are they glued at > the corners? > > Thanks, > Liz > Fulltiming in a Wanderlodge > Regards, > Jack and Liz Pearce > 1993 Wanderlodge WB40 > Homesick Texans in Lantana, FL |
