M450 of 30 amp hookup - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Classifieds (/forumdisplay.php?fid=17) +--- Forum: Coaches at Large (/forumdisplay.php?fid=18) +--- Thread: M450 of 30 amp hookup (/showthread.php?tid=10414) |
M450 of 30 amp hookup - tcandt - 01-31-2015 23:18 Have any M450 owners successfully hooked up to 30 amp without popping breakers? if you have, what did you sacrifice? RE: M450 of 30 amp hookup - dentmac - 02-01-2015 01:46 Hi, When using 30 amp, the top EMS should show 30 amp. Everything is automatic then. Shunts as required. If batteries are low and both inverters want to go to full bulk charge.. nothing left. I have shut down one inverter until charge goes to float. RE: M450 of 30 amp hookup - GregOConnor - 02-01-2015 04:40 not sure if your inverters works like my one inverter but. I never shut off the inverter in my bus.. however I throw the circuit breaker off that feeds the charger side of the inverter when I am on 30 amps and I then use one Xantrex +40 charger to maintain the batteries. |
