Coolant Sensor Switch Location - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Coolant Sensor Switch Location (/showthread.php?tid=1042) |
Coolant Sensor Switch Location - chaaur2 - 07-11-2005 06:02 My 81FC35 electric clutch fan will not engage unless I apply 12 volts directly to the fan wiring. I suspect the problem is the thermostat switch, But I can not locate this switch on the engine. Does anyone know he location? When tracing the wiring from the clutch fan the power wire connects to two additional wires. Does anyone have any idea where these wires are coming from? I guess one is coming from the thermostat switch. Thanks Charlie Shannon Saint Albans, WV 81FC35 Coolant Sensor Switch Location - Chet Geist - 07-11-2005 06:27 Charlie, The thermal switch for the electric fan clutch is to the right of the fan on the front of the engine It had three terminals on it and should have either three or four wires. Four wires if you have a dash over-ride switch. It's a cylinder looking switch that screws into the front of the engine. Chet Geist 1981 FC33, Austin, Texas -----Original Message----- From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com]On Behalf Of chaaur2 Sent: Monday, July 11, 2005 1:03 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Coolant Sensor Switch Location My 81FC35 electric clutch fan will not engage unless I apply 12 volts directly to the fan wiring. I suspect the problem is the thermostat switch, But I can not locate this switch on the engine. Does anyone know he location? When tracing the wiring from the clutch fan the power wire connects to two additional wires. Does anyone have any idea where these wires are coming from? I guess one is coming from the thermostat switch. Thanks Charlie Shannon Saint Albans, WV 81FC35 ---------------------------------------------------------------------------- -- YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ---------------------------------------------------------------------------- -- [Non-text portions of this message have been removed] |
