Air leaking from PRV's... - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: Pneumatic (/forumdisplay.php?fid=33) +--- Thread: Air leaking from PRV's... (/showthread.php?tid=10568) |
Air leaking from PRV's... - morganaire - 09-26-2015 03:07 Hi all - Recently brought our 1991 SP36 home and have a few issues to iron out. Never had to deal with air systems before - is it normal on shutdown to have air leaking out of the pressure reducing valves (Bendix 281857)? Noticed it several times from two of these valves - one under the coach near the rear differential and one on the driver's side of the engine compartment. doesn't happen every time I shut down, which caused me to notice it. RE: Air leaking from PRV's... - ernie ekberg - 09-26-2015 08:48 I suspect your coach has been sitting for quite a while. All systems probably need some attention. |
