lxi air toilet replaced - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: General (/forumdisplay.php?fid=37) +--- Thread: lxi air toilet replaced (/showthread.php?tid=10597) |
lxi air toilet replaced - GregOConnor - 10-18-2015 03:11 I replaced the toilet in my lxi with a dometic 320. the air operates fine but The 12 volt compressor was bad when I got it and I cant find the air leak so after the rebuild I switch it on and off. I pulled everything china is perfect as well color is bone. compressors not included . In Romoland CA 92585 $200.00 Condition: good for crap Greg 951-830-5997 RE: lxi air toilet replaced - ernie ekberg - 10-18-2015 21:37 mine is next- parts will be unavailable as unit will be in dumpster RE: lxi air toilet replaced - GregOConnor - 10-18-2015 23:25 I can not understand why my bus had this toilet. The new sewer line is 30 inches shorter. I was confused on why the air toilet used a 1.5 inch line? Ii used. 3 inch to 2 inch close to the tank. My thinking is the 2 inch will keep the water from separating from the solids. If this proves to be an issue I will make the tank fitting 3 inch or change my diet RE: lxi air toilet replaced - timetravelers - 10-22-2015 08:50 I fixed mine with new factory redesigned air control unit, regulators on air and water to reduce pressure. Set air pressure regulator on Thomas to max of 60, so it doesn't run so long. Got rid of air leaks on air system for toilet. Toilet works like new, like low water usage for dry camping. |
