Jack Issue - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Discussions (/forumdisplay.php?fid=21) +--- Forum: General (/forumdisplay.php?fid=37) +--- Thread: Jack Issue (/showthread.php?tid=10667) |
Jack Issue - al perna - 02-11-2016 13:14 Hello WaGu, When I retract the jacks , the motor runs and they attempt to Extend . I believe this a stuck solenoid , if so how do I determine which one , or am I wrong, and it is some other issue ? Thank you all in advance
RE: Jack Issue - cvaughn - 02-14-2016 12:41 There is a shuttle valve in the main manifold. It keeps the jacks from letting flow back thru the circuits to keep the coach level. I got caught sometime back with jacks the would not retract. I turned everything off, i tapped the main body between the frame rails. Restarted, everything worked fine. The shuttle valve was replaced that week. No problems since. RE: Jack Issue - al perna - 02-15-2016 13:52 thank you Charlie, how do I identify the shuttle valve ? Guys , any idea which one I need ? VALVE - HYDRAULIC - MANUAL - MECHANICAL "SHUTTLE VALVES" PARTS MANUAL DIAGRAMS SHUTTLE VALVE RAP7964 ORDER RELATED PART: O-RING KIT R7430 ORDER SHUTTLE VALVE - TALL RAP6064 ORDER RELATED PART: O-RING KIT R7430 ORDER SHUTTLE VALVE RAP3623 ORDER RELATED PART: O-RING KIT R7430 ORDER RE: Jack Issue - cvaughn - 02-17-2016 11:38 The shuttle valve is is under a bolt head maybe 3/4" or 1". It is located near center of the manifold body. I would not remove it under pressure.I do not know if it is tall or not. RE: Jack Issue - al perna - 02-17-2016 12:54 thank you Charlie , I was able to look up the part on HWH web site and plan to order it once they help me determine which one it is . RE: Jack Issue - al perna - 02-22-2016 14:28 here is the link to the shuttle valve I ordered today . HWH not only answered the phone, but had the part in stock for a delivery today . http://www.hwh.com/mi158813.pdf thank you for the info here , wagu is a great source for saving $$$$ and learning
RE: Jack Issue - GregOConnor - 03-04-2016 03:22 https://www.youtube.com/watch?v=YXzL2NXrQZU |
