Stuck Retarder switch - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Stuck Retarder switch (/showthread.php?tid=1083) |
Stuck Retarder switch - cudjoekeytom - 07-22-2005 12:01 Just picked up my 91 WB from the Detroit Deisel Allison shop in Orlando (pretty bad experience overall). Still have a Check Transmission light on although they say ther are no active transmission or engine codes (they checked with their handheld device). Their story is that it's probably a short in the wiring that is causing the light to come on. I'm suspect at best. Spoke with Bennie at BB today and asked if stuck retarder switch (stuck in the Apply position and the "On" light is not lit) might have something to do with the check trans light. He plans to speak to a transmission engineer on Monday and let me know. I'd like any input that anyone might have on the subject and also like to know where I can get the switch to replace the one that is stuck. I live in the FL Keys so mail order or internet will be th best sources for me. Stuck Retarder switch - mrdonut12 - 07-22-2005 12:48 --- In WanderlodgeForum@yahoogroups.com, "cudjoekeytom" > Just picked up my 91 WB from the Detroit Deisel Allison shop in > Orlando (pretty bad experience overall). Still have a Check > Transmission light on although they say ther are no active > transmission or engine codes (they checked with their handheld > device). Their story is that it's probably a short in the wiring that > is causing the light to come on. I'm suspect at best. > > Spoke with Bennie at BB today and asked if stuck retarder switch > (stuck in the Apply position and the "On" light is not lit) might have > something to do with the check trans light. He plans to speak to a > transmission engineer on Monday and let me know. > > I'd like any input that anyone might have on the subject and also like > to know where I can get the switch to replace the one that is stuck. > I live in the FL Keys so mail order or internet will be th best > sources for me. It's customary on the forum to sign your post with name, year and model and location. Thank you. Order it from Bennie. He's the one busting his butt for you. George Witt 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) Lincoln, Nebraska Stuck Retarder switch - Tom Warner - 07-22-2005 22:55 Bennie normally does know what BB has in stock since he gets many calls everyday. There is another number for Parts and I agree most times they have the part. I bought some oil impregnated wire loom from them when I rewired some of the coach and they were actually cheaper then NAPA. Tom 1982 FC35 Vernon Center,NY At 09:18 PM 7/23/2005 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > Well said George. Bluebird has almost any part that you need >and > > sometimes the price is not much more than anywhere else. In fact I >have > > bought parts that were cheaper than anywhere else. It's only a >phone > > call away and they know what you want and need. Plus the technical > > advice we receive from them etc,etc. It's a good thing to Support >them > > when possible. I bought this retarder switch from them a few years >ago > > for my 93 and I believe it was only a couple dollars. If you need >it > > right away they'll overnight it. Bob 93pt Illinois (HOT) > > > > > > It's customary on the forum to sign your post with name, > > > year and model and location. Thank you. > > > Order it from Bennie. He's the one busting his butt for >you. > > > > > > George Witt > > > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > > > > > Lincoln, Nebraska > >Thanks, > >I'll try to remember that. > >Bennie didn't mention that they could supply the part. He told me >to try Radio Shack which I thought was odd > >Tom Gibbs >91WB40 >Cudjoe Key, FL Stuck Retarder switch - Bob & Carol Howald` - 07-23-2005 01:02 Well said George. Bluebird has almost any part that you need and sometimes the price is not much more than anywhere else. In fact I have bought parts that were cheaper than anywhere else. It's only a phone call away and they know what you want and need. Plus the technical advice we receive from them etc,etc. It's a good thing to Support them when possible. I bought this retarder switch from them a few years ago for my 93 and I believe it was only a couple dollars. If you need it right away they'll overnight it. Bob 93pt Illinois (HOT) > > It's customary on the forum to sign your post with name, > year and model and location. Thank you. > Order it from Bennie. He's the one busting his butt for you. > > George Witt > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > Lincoln, Nebraska Stuck Retarder switch - cudjoekeytom - 07-23-2005 09:18 --- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > Well said George. Bluebird has almost any part that you need and > sometimes the price is not much more than anywhere else. In fact I have > bought parts that were cheaper than anywhere else. It's only a phone > call away and they know what you want and need. Plus the technical > advice we receive from them etc,etc. It's a good thing to Support them > when possible. I bought this retarder switch from them a few years ago > for my 93 and I believe it was only a couple dollars. If you need it > right away they'll overnight it. Bob 93pt Illinois (HOT) > > > > It's customary on the forum to sign your post with name, > > year and model and location. Thank you. > > Order it from Bennie. He's the one busting his butt for you. > > > > George Witt > > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > > > Lincoln, Nebraska Thanks, I'll try to remember that. Bennie didn't mention that they could supply the part. He told me to try Radio Shack which I thought was odd Tom Gibbs 91WB40 Cudjoe Key, FL Stuck Retarder switch - cudjoekeytom - 07-24-2005 03:33 --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > Bennie normally does know what BB has in stock since he gets many calls > everyday. There is another number for Parts and I agree most times they > have the part. I bought some oil impregnated wire loom from them when I > rewired some of the coach and they were actually cheaper then NAPA. > > Tom > 1982 FC35 > Vernon Center,NY > > At 09:18 PM 7/23/2005 +0000, you wrote: > >--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > Well said George. Bluebird has almost any part that you need > >and > > > sometimes the price is not much more than anywhere else. In fact I > >have > > > bought parts that were cheaper than anywhere else. It's only a > >phone > > > call away and they know what you want and need. Plus the technical > > > advice we receive from them etc,etc. It's a good thing to Support > >them > > > when possible. I bought this retarder switch from them a few years > >ago > > > for my 93 and I believe it was only a couple dollars. If you need > >it > > > right away they'll overnight it. Bob 93pt Illinois (HOT) > > > > > > > > It's customary on the forum to sign your post with name, > > > > year and model and location. Thank you. > > > > Order it from Bennie. He's the one busting his butt for > >you. > > > > > > > > George Witt > > > > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > > > > > > > Lincoln, Nebraska > > > >Thanks, > > > >I'll try to remember that. > > > >Bennie didn't mention that they could supply the part. He told me > >to try Radio Shack which I thought was odd > > > >Tom Gibbs > >91WB40 > >Cudjoe Key, FL Thanks. I'll call Bennie back tomorrow and see if it's available. Tom Gibbs 91WB40 Cudjoe Key, FL Stuck Retarder switch - Marv & Jean Wheeler - 07-24-2005 04:34 Tom: I really think you could get a better answer about parts availability by calling the Parts Department direct. Their number is 800-495-7787. Bennie will not know what items are in stock. He would simply relay your information to Parts. Marv 2004 M380 Ocean Shores, WA --- In WanderlodgeForum@yahoogroups.com, "cudjoekeytom" > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > Bennie normally does know what BB has in stock since he gets many > calls > > everyday. There is another number for Parts and I agree most times > they > > have the part. I bought some oil impregnated wire loom from them > when I > > rewired some of the coach and they were actually cheaper then NAPA. > > > > Tom > > 1982 FC35 > > Vernon Center,NY > > > > At 09:18 PM 7/23/2005 +0000, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > > > Well said George. Bluebird has almost any part that you need > > >and > > > > sometimes the price is not much more than anywhere else. In > fact I > > >have > > > > bought parts that were cheaper than anywhere else. It's only a > > >phone > > > > call away and they know what you want and need. Plus the > technical > > > > advice we receive from them etc,etc. It's a good thing to > Support > > >them > > > > when possible. I bought this retarder switch from them a few > years > > >ago > > > > for my 93 and I believe it was only a couple dollars. If you > need > > >it > > > > right away they'll overnight it. Bob 93pt Illinois (HOT) > > > > > > > > > > It's customary on the forum to sign your post with name, > > > > > year and model and location. Thank you. > > > > > Order it from Bennie. He's the one busting his butt for > > >you. > > > > > > > > > > George Witt > > > > > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > > > > > > > > > Lincoln, Nebraska > > > > > >Thanks, > > > > > >I'll try to remember that. > > > > > >Bennie didn't mention that they could supply the part. He told me > > >to try Radio Shack which I thought was odd > > > > > >Tom Gibbs > > >91WB40 > > >Cudjoe Key, FL > > Thanks. I'll call Bennie back tomorrow and see if it's available. > > Tom Gibbs > 91WB40 > Cudjoe Key, FL Stuck Retarder switch - Tom Warner - 07-24-2005 05:15 Have you tried Parliment Coach in Florida who is now a BB dealer and repair center? http://www.parliamentcoach.com/ tom 1982 FC35 Vernon Center,NY At 03:33 PM 7/24/2005 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, Tom Warner >wrote: > > Bennie normally does know what BB has in stock since he gets many >calls > > everyday. There is another number for Parts and I agree most times >they > > have the part. I bought some oil impregnated wire loom from them >when I > > rewired some of the coach and they were actually cheaper then NAPA. > > > > Tom > > 1982 FC35 > > Vernon Center,NY > > > > At 09:18 PM 7/23/2005 +0000, you wrote: > > >--- In WanderlodgeForum@yahoogroups.com, "Bob & Carol Howald`" > > > > > > > Well said George. Bluebird has almost any part that you need > > >and > > > > sometimes the price is not much more than anywhere else. In >fact I > > >have > > > > bought parts that were cheaper than anywhere else. It's only a > > >phone > > > > call away and they know what you want and need. Plus the >technical > > > > advice we receive from them etc,etc. It's a good thing to >Support > > >them > > > > when possible. I bought this retarder switch from them a few >years > > >ago > > > > for my 93 and I believe it was only a couple dollars. If you >need > > >it > > > > right away they'll overnight it. Bob 93pt Illinois (HOT) > > > > > > > > > > It's customary on the forum to sign your post with name, > > > > > year and model and location. Thank you. > > > > > Order it from Bennie. He's the one busting his butt for > > >you. > > > > > > > > > > George Witt > > > > > 81 WL FCSB 35 (Wanderlodge Front Control Side Bath) > > > > > > > > > Lincoln, Nebraska > > > > > >Thanks, > > > > > >I'll try to remember that. > > > > > >Bennie didn't mention that they could supply the part. He told me > > >to try Radio Shack which I thought was odd > > > > > >Tom Gibbs > > >91WB40 > > >Cudjoe Key, FL > >Thanks. I'll call Bennie back tomorrow and see if it's available. > >Tom Gibbs >91WB40 >Cudjoe Key, FL > > > > >SPONSORED LINKS ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+vehi\ cles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=\ Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=DAUkCKkU7Dzhn_\ ObWmSYTw>Recreational >vehicles ><http://groups.yahoo.com/gads?t=ms&k=Wanderlodge&w1=Recreational+vehicles&w2=Wa\ nderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=Used+recre\ ational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=Z-8HJdysB3QLPj9U0JvqYQ>W\ anderlodge ><http://groups.yahoo.com/gads?t=ms&k=Automotive+maintenance&w1=Recreational+veh\ icles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5\ =Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=IF4u_5wI8Pmy3\ 4cC1O9CxA>Automotive >maintenance ><http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+dealer&w1=Recreationa\ l+vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deal\ er&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=z6_Xahae\ YHfELr6o72IW1A>Recreational >vehicle dealer ><http://groups.yahoo.com/gads?t=ms&k=Used+recreational+vehicles&w1=Recreational\ +vehicles&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+deale\ r&w5=Used+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=UGEY5km4L\ -kXbDI4ZSadEw>Used >recreational vehicles ><http://groups.yahoo.com/gads?t=ms&k=Automotive+radiators&w1=Recreational+vehic\ les&w2=Wanderlodge&w3=Automotive+maintenance&w4=Recreational+vehicle+dealer&w5=U\ sed+recreational+vehicles&w6=Automotive+radiators&c=6&s=163&.sig=ePNVMmISsCWgTnM\ q_4GlXA>Automotive >radiators > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
