Air Conditoner Fan Motor Bearings Shot - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Air Conditoner Fan Motor Bearings Shot (/showthread.php?tid=1088) |
Air Conditoner Fan Motor Bearings Shot - Jack and Liz Pearce - 07-24-2005 06:28 Howdy, Y'all. The fan motor bearings are kaput on our bedroom air conditioner. Jack wants to know how to replace that motor. It looks to be very difficult because the drive shaft is so long. Is there a trick to replacing that motor without disassembling the whole world? or comments would be appreciated. Thanks, Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL Air Conditoner Fan Motor Bearings Shot - Tom Warner - 07-24-2005 07:14 What make and model A/C is it? tom 1982 FC35 Vernon Center,NY At 06:28 PM 7/24/2005 +0000, you wrote: >Howdy, Y'all. > >The fan motor bearings are kaput on our bedroom air conditioner. Jack >wants to know how to replace that motor. It looks to be very difficult >because the drive shaft is so long. Is there a trick to replacing that >motor without disassembling the whole world? >or comments would be appreciated. > >Thanks, >Regards, >Jack and Liz Pearce >Fulltiming in a 1993 Wanderlodge WB40 >Homesick Texans in SE. FL > > > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- Air Conditoner Fan Motor Bearings Shot - Ralph L. Fullenwider - 07-24-2005 07:47 Jack/Liz: Assuming it is a roof top AC, replacing the fan motor is pretty straight forward. With the cover off, and the circuit breaker off, note the wiring numbers/color ( don't trust to memory) if not a plug in. The main thing is getting the fan blade and squirrel cage back in the right configuration. If the new motor is the right one but the shaft is too long, it is normal to cut the shaft to proper length. Be sure to check the motor start capacitor if reusing the old one, and of course check the start/run capacitor on the compressor as well. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions,, Oklahoma At 06:28 PM 7/24/2005 +0000, you wrote: >Howdy, Y'all. > >The fan motor bearings are kaput on our bedroom air conditioner. Jack >wants to know how to replace that motor. It looks to be very difficult >because the drive shaft is so long. Is there a trick to replacing that >motor without disassembling the whole world? >or comments would be appreciated. > >Thanks, >Regards, >Jack and Liz Pearce >Fulltiming in a 1993 Wanderlodge WB40 >Homesick Texans in SE. FL > > > > Air Conditoner Fan Motor Bearings Shot - Jack and Liz Pearce - 07-24-2005 09:08 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > What make and model A/C is it? > > tom > 1982 FC35 > Vernon Center,NY Howdy, Tom. It is a Duo-Therm by Dometic, model # 620015.307, roof mounted. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL Air Conditoner Fan Motor Bearings Shot - Jack and Liz Pearce - 07-24-2005 09:11 Howdy, Ralph and Charlotte. It is really nice to hear from y'all. Thanks for the reply. . Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL Air Conditoner Fan Motor Bearings Shot - Tom Warner - 07-24-2005 13:53 Jack its a penguin model and I thought you could get the parts for it at http://www.rvdealership.com but for some reason their site is not working correctly. The parts should be available there however. Sorry to cause you to give additional information. tom 1982 FC35 Vernon Center,NY At 09:08 PM 7/24/2005 +0000, you wrote: >--- In WanderlodgeForum@yahoogroups.com, Tom Warner > > What make and model A/C is it? > > > > tom > > 1982 FC35 > > Vernon Center,NY > >Howdy, Tom. >It is a Duo-Therm by Dometic, model # 620015.307, roof mounted. > >Regards, >Jack and Liz Pearce Air Conditoner Fan Motor Bearings Shot - williamcharrison - 07-25-2005 03:06 What model air cond? Chuck Harrison 90SP36 --- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce" > Howdy, Y'all. > > The fan motor bearings are kaput on our bedroom air conditioner. Jack > wants to know how to replace that motor. It looks to be very difficult > because the drive shaft is so long. Is there a trick to replacing that > motor without disassembling the whole world? > or comments would be appreciated. > > Thanks, > Regards, > Jack and Liz Pearce > Fulltiming in a 1993 Wanderlodge WB40 > Homesick Texans in SE. FL Air Conditoner Fan Motor Bearings Shot - Jack and Liz Pearce - 07-25-2005 04:54 Howdy, Tom. >>>> In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > Jack its a penguin model and I thought you could get the parts for it at > http://www.rvdealership.com but for some reason their site is not working > correctly. The parts should be available there however. Sorry to cause you > to give additional information. Thank you very much for the information. Much obliged, Jack and Liz Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL Air Conditoner Fan Motor Bearings Shot - Jack and Liz Pearce - 07-25-2005 04:57 --- In WanderlodgeForum@yahoogroups.com, "williamcharrison" > What model air cond? > > Chuck Harrison > 90SP36 > Model # 620015.307, Duo-Therm, Dometic unit. Regards, Jack and Liz Pearce Fulltiming in a 1993 Wanderlodge WB40 Homesick Texans in SE. FL |
