Rear Window on 1984 PT40WL - Printable Version +- Wanderlodge Gurus - The Member Funded Wanderlodge Forum (http://www.wanderlodgegurus.com) +-- Forum: Yahoo Groups Archive (/forumdisplay.php?fid=61) +--- Forum: WanderlodgeForum (/forumdisplay.php?fid=63) +--- Thread: Rear Window on 1984 PT40WL (/showthread.php?tid=1125) |
Rear Window on 1984 PT40WL - pt40wl1 - 07-30-2005 15:52 Does anybody have any reason for the rear window and metal cover on the rear of the '84 PT40WL??? I am doing a complete rejuvination on my bird and am considering replacing the rear window and cover with some new 16 gauge smooth galvanived steel. This would save some weight as well as provide better insulation on the rear. My bus is the rear bedroom model and the rear window is not usable from the inside due to closet space and air conditioning equipment in the rear of the bus. I think it is a hold-over from the commercial bus design and serves no useful purpose on this model. What do you folks think??? Roger Sadler '84 PT40WL, Little Rock Rear Window on 1984 PT40WL - bbwlwb88 - 07-31-2005 10:15 Roger: Wanderlodge used the rear cap from the forward control coach on the rear of the PT40 in order to save money. In 1985 and 1986 the factory had lots of complaints about the poor appearance of the window in the rear. They came out with a metal panel to cover the window. I'm not sure if the panel was their idea or a Wanderlodge owner's idea. In any case what you have in mind should not cause a problem. My first Bird was a new 1984 PT40. --- In WanderlodgeForum@yahoogroups.com, "pt40wl1" > Does anybody have any reason for the rear window and metal cover on > the rear of the '84 PT40WL??? > > I am doing a complete rejuvination on my bird and am considering > replacing the rear window and cover with some new 16 gauge smooth > galvanived steel. This would save some weight as well as provide > better insulation on the rear. My bus is the rear bedroom model and > the rear window is not usable from the inside due to closet space and > air conditioning equipment in the rear of the bus. > > I think it is a hold-over from the commercial bus design and serves no > useful purpose on this model. What do you folks think??? > > Roger Sadler > '84 PT40WL, Little Rock Rear Window on 1984 PT40WL - pt40wl1 - 08-01-2005 17:12 Thanks bbwlwb88, I believe I will remove the window and cover and replace with a smooth metal panel to clean up the rear end a little. This group is amazing with the vast amount of experience with these great motorhomes. Thanks again!!! Roger Sadler '84 PT40WL - Little Rock --- In WanderlodgeForum@yahoogroups.com, "bbwlwb88" > Roger: Wanderlodge used the rear cap from the forward control coach > on > the rear of the PT40 in order to save money. In 1985 and 1986 the > factory had lots of complaints about the poor appearance of the > window > in the rear. They came out with a metal panel to cover the window. > I'm not sure if the panel was their idea or a Wanderlodge owner's > idea. In any case what you have in mind should not cause a problem. > My > first Bird was a new 1984 PT40. > > --- In WanderlodgeForum@yahoogroups.com, "pt40wl1" > > Does anybody have any reason for the rear window and metal cover on > > the rear of the '84 PT40WL??? > > > > I am doing a complete rejuvination on my bird and am considering > > replacing the rear window and cover with some new 16 gauge smooth > > galvanived steel. This would save some weight as well as provide > > better insulation on the rear. My bus is the rear bedroom model > and > > the rear window is not usable from the inside due to closet space > and > > air conditioning equipment in the rear of the bus. > > > > I think it is a hold-over from the commercial bus design and serves > no > > useful purpose on this model. What do you folks think??? > > > > Roger Sadler > > '84 PT40WL, Little Rock Rear Window on 1984 PT40WL - bbwlwb88 - 08-04-2005 00:36 Good luck on your project. Royal Washburn Conway, AR --- In WanderlodgeForum@yahoogroups.com, "pt40wl1" > Thanks bbwlwb88, I believe I will remove the window and cover and > replace with a smooth metal panel to clean up the rear end a > little. This group is amazing with the vast amount of experience > with these great motorhomes. Thanks again!!! > Roger Sadler > '84 PT40WL - Little Rock > > --- In WanderlodgeForum@yahoogroups.com, "bbwlwb88" > > > Roger: Wanderlodge used the rear cap from the forward control > coach > > on > > the rear of the PT40 in order to save money. In 1985 and 1986 the > > factory had lots of complaints about the poor appearance of the > > window > > in the rear. They came out with a metal panel to cover the > window. > > I'm not sure if the panel was their idea or a Wanderlodge owner's > > idea. In any case what you have in mind should not cause a > problem. > > My > > first Bird was a new 1984 PT40. > > > > --- In WanderlodgeForum@yahoogroups.com, "pt40wl1" > > > Does anybody have any reason for the rear window and metal cover > on > > > the rear of the '84 PT40WL??? > > > > > > I am doing a complete rejuvination on my bird and am considering > > > replacing the rear window and cover with some new 16 gauge > smooth > > > galvanived steel. This would save some weight as well as > provide > > > better insulation on the rear. My bus is the rear bedroom model > > and > > > the rear window is not usable from the inside due to closet space > > and > > > air conditioning equipment in the rear of the bus. > > > > > > I think it is a hold-over from the commercial bus design and > serves > > no > > > useful purpose on this model. What do you folks think??? > > > > > > Roger Sadler > > > '84 PT40WL, Little Rock |
